So there you have an example of that lack of sharpness I am facing with the R5
Started 7 months ago | Photos
Jordi Seyte Junior Member • Posts: 31
This is a photo taken with the old 5DSR at 1/400 f7.1 with the EF 100-400 USM II
Then here's a photo taken with the R5 with the same exposition, so 1/400 f7.1 with the same EF 100-400 USM II lens.
That same story is what I am getting when photographing birds in flight. I used to get razor sharp images with the 5DSR while I am getting disappointing shots with the R5.
The problem can not be the high pixel count, since the 5DSR is a 50 megapixel dynosaur with a mere 4 fps burst at higuest speed if I recall.
I'll keep investigating and experimenting.
 Jordi Seyte's gear list:Jordi Seyte's gear list
Canon EOS R5 Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm F2.8L IS II USM Canon EF 100-400mm F4.5-5.6L IS II Apple iPhone 11 Pro +1 more
Comment & critique:
Canon EOS 5DS R Canon EOS R5
drsnoopy Senior Member • Posts: 1,216
Re: So there you have an example of that lack of sharpness I am facing with the R5
8
Well, it's clearly motion blur, and as its different between the upper jaw and the lower jaw, plus the hand and plant are not affected (though not quite sharp), it implies that the subject is moving.  I've had very sharp results with my 10-400 L mkii (now sold) on the R5, with static and flying birds.  Not tried any horses though!
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
OP Jordi Seyte Junior Member • Posts: 31
I had not considered the possibility that the question could be a horse related issue :)))
Yes, motion blur is what I first thought, but the thing is that there's nothing in focus there. Not even the parts that are not moving (fingers for instance).
Distinctly Average Senior Member • Posts: 2,527
To me it looks like motion blur too, but I am viewing on a phone so challenging to see.
If I were you, I would photograph a flat, stationary subject from a tripod. A cereal box or newspaper taped to a wall for instance. Use that to determine if there is indeed a problem. If you see there is, then you have a series of test shots that you can show to your dealer or Canon to hwlp get the problem resolved. You are so n the EU so have strong consumer rights should it actually be a camera issue.
charlyw64 Contributing Member • Posts: 717
IIRC you said that you were using the electronic shutter. Have you tried the mechanical shutter in these circumstances?
JoeSchmoe007 Contributing Member • Posts: 502
It's horse****!
On a serious note: are both pictures handheld? Could be you were luckier in the first shot.
Even though it does look like a motion blur - shouldn't 1/400 be more than enough to freeze it? OP is not photographing running cheetahs here.
Jablok New Member • Posts: 16
Let me guess, are you shooting with electronic shutter?
 Jablok's gear list:Jablok's gear list
Nikon Z6 Nikon AF-S Nikkor 58mm f/1.4G
danferrin Contributing Member • Posts: 730
6
Your exif data is the same for both photos.  If the second photo was taken with the R5, it would probably be useful to be able to see the actual exif data for the shot.
My life is a circle of confusion - photography is my meditation.
See my work at http://www.danferrinphotography.com
 danferrin's gear list:danferrin's gear list
Canon EOS 60D Canon EOS 7D Mark II Canon EOS RP Canon EOS R5 Canon EOS R7 +20 more
Why would that matter for this image?  Interested to know why you asked that.
While I certainly wouldn’t expect this much difference in sharpness between the 5Dsr and the R5, I would expect some difference in sharpness. The 5Dsr is equipped with Low-pass filter effect cancellation, while the R5 is not. The low pass filter reduces moire at the cost of some loss of sharpness. I believe the R5 low pass filter is not as strong as in some cameras, but it’s effect is not cancelled. The R5 is still capable of producing sharp images, but slightly less so than the 5Dsr. Your example photo, however appears to be a red herring.
I would go down the same route because the time the electronic shutter takes to scan the image frame is much longer than the 1/400th of a second you expose. Every pixel will be exposed for only 1/400th of a second but the image as a whole would take longer. In the second shot (if it really is taken by the R5) at the time of releasing the shutter the subject may have been motionless (not that a horses mouth in the presence of food ever is motionless) but by the time it came to scanning the rows that make up the lips of the bugger it could well have started to nibble on the offered leaves - at which time the shutter speed of 1/400th would be insufficient (gauging from the speed of movement that my wife's horse shows under such circumstances)...
hedleyw
hedleyw Contributing Member • Posts: 539
Why does the exif data say you used the 5Dsr for both images?
Hedley
 hedleyw's gear list:hedleyw's gear list
Olympus Tough TG-4 Ricoh GR IIIx Olympus PEN-F Canon EOS R5 Canon EOS R3 +27 more
... Every pixel will be exposed for only 1/400th of a second but the image as a whole would take longer...
Do you have any idea how long would the whole image take?
It's obviously motion blur, and the real sensor scanning in electronic shutter mode may be about 1/60 or so (the reason of rolling shutter).
Zeee Forum Pro • Posts: 25,627
The flower is not showing any excessive motion blur.
FP
 Zeee's gear list:Zeee's gear list
Canon EOS R7 Canon EOS R6 Mark II Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +1 more
Good catch.
FP
While not tac sharp neither are the teeth.
FP
Sorry, both images show the same exif data because I pasted one over the other to upload the exact same crop sized area.
Here's the R5 crop with its actual exif data.
Note: I used mechanical shutter. The giraffe 5DSR shot was not a lucky one :)), and yes, I think 1/400 shutter speed should be enough to freeze this moment, to me.
Karl_Guttag Senior Member • Posts: 1,884
Looks like a focus problem, but hard to tell from a single crop
First, it is hard to tell exactly what is happening with a small image crop. Secondly, the EXIF data suggests that either they were taken with the same camera or when editing, you layered the R5 image on top of the 5D file and "picked up" the other camera's EXIF.  In cases like this, it would be helpful if you would upload a 100% image without crop. If you only shoot RAW/cRAW, then convert it to JPEG and upload it. Third, many things can go wrong with any single hand-held photograph. Two or 3 pictures show a trend.
Like some others, my first reaction was that the problem was motion blur. Motion blur could be caused by the subject, something wrong with the IS/IBIS, camera movement, and camera movement fighting the IS.
But on closer inspection, it does look like the focus is the primary problem (there may also be motion blur, but hard to tell). Also, assuming the two crops cover the same area, the "magnification" was very roughly 2x as much, which has about a square law effect on depth of focus (2x the magnification reduces the depth of focus by about 4x).
What jumped out to me (figuratively and literally) is the lower left white hair I have circled in red and, to a lesser degree, the upper right black hair circled. That one white hair appears to be sharp AND it appears to be coming out to the camera. The hairs that are further back seem more blurred than the hairs that are closer. The plant being fed appears in-between blurry.
Note the red circled white hair
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
Re: Looks like a focus problem, but hard to tell from a single crop
I understand what you mean.
The photo seen on the camera screen looks ok. Seen on photoshop at 25% size, also looks acceptable, but when inspected up close, to me it is not what I would have expected.
Here is the original image, as you suggested I only opened the Raw file and saved it as jpeg.
