Can i use Sigma 70-300mm on Canon 200d?
Started 8 months ago | Discussions
eArafat New Member • Posts: 1
I have a Sigma APO DG 70-300mm 1:4-5.6 macro lens and a Canon 200d camera. Can i use both together or  Is Canon 200d are compatible with Sigma 70-300mm?
Canon EOS Rebel SL2 (EOS 200D / Kiss X9)
Len Philpot
Len Philpot Contributing Member • Posts: 625
Re: Can i use Sigma 70-300mm on Canon 200d?
As per https://www.dpreview.com/products/sigma/lenses/sigma_70-300_4-5p6_apo the lens is available with a Canon EF mount so the answer is apparently, 'yes'. It will be a 112-480 full frame equivalent lens on that (APS-C) camera.
Len Philpot
Retirement: 4th best thing to happen to me
https://www.instagram.com/lphilpot01/
https://flic.kr/ps/doiTr
 Len Philpot's gear list:Len Philpot's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF 70-300mm f/4-5.6 IS USM Topaz Adjust Topaz DeJPEG Topaz Detail +13 more
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Try them together and you tell us.
Should be ok, but older versions of Sigma lenses ("DL" or no "D-" designation) worked with earlier EOS (pre-1997 models) but would fail with "ERR 99" with later EOS bodies. Typically would AF ok and work with wide-open aperture, but throw the ERR if the aperture were stopped down.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
