The 15-45 switch.
Started 7 months ago | Questions
Swerky Contributing Member • Posts: 793
The 15-45 switch.
Looking to add a small m camera with 22mm f2 for street and low light shooting. But seems almost impossible to get without that kit lens. Question is, in case I keep the lens, if I turn the camera off to save battery while walking, do I need to fully retract the lens, or it's ok to keep it at 15 and turn the camera on again problem free?
Nothing to read here.
 Swerky's gear list:Swerky's gear list
Canon G1 X III Canon EOS 6D Fujifilm X-A10 Voigtlander 20mm F3.5 Color Skopar SL II Voigtlander 90mm F3.5 APO-Lanthar SL II +1 more
nnowak Veteran Member • Posts: 9,076
Re: The 15-45 switch.
There is no problem leaving the lens extended.  Some people even stow the lens in their bag with it still extended.
OP Swerky Contributing Member • Posts: 793
Thank you!
Jayson A Forum Member • Posts: 84
why do lenses with the EF adapter require the lens cap when turning the camera off, but native lenses don’t?
What???
nnowak wrote:
What???
Every time I turn my camera off with an EF or EF-S lens on, it says "Keep the Lens Cap On after Camera is Off", but native lenses don't say that. The camera just shuts off normally. I thought the sensor is aways exposed whether you have the camera off or on since there's no mirror covering it. So why is it important to keep the lens cap on when an EF or EF-S lens is attached vs a native EF-M lens?
Jack Calypso Senior Member • Posts: 1,094
Jayson A wrote:
nnowak wrote:
What???
I noticed this myself recently. It shows the message with just the mount adapter, no lens.
Jayson A wrote:
nnowak wrote:
What???
Never noticed that before.
My guess it is due to the difference in aperture mechanisms.  The EF-M lenses stop down to the smallest aperture when powered down. EF and EF-S lenses are wide open when powered off.
Apparently Canon must be seeing a rash of people starting their mirrorless cameras on fire by mounting giant telephoto lenses and leaving the camera pointed at the sun while sitting on the dash of their car in Arizona in July.
Sittatunga Veteran Member • Posts: 5,406
nnowak wrote:
Jayson A wrote:
nnowak wrote:
What???
You're closer to the equator than Arizona is. It was a standard warning / precaution for cameras with focal plane shutters in the days before instant-return mirrors and with rangefinder cameras.
EF and EF-S lenses open up to maximum aperture when the camera is switched off so that you can still see through the viewfinder. RF and EF-M lenses stop down to near minimum aperture without power. The Retract lens on power off menu option refocusses them to near infinity. There have been a couple of threads in the RF forum about unexpected melting damage to the plastic surround to the sensor.
In answer to your first question, it doesn't matter about retracting your lens when not using it, provided you're careful with it. The locking mechanism protects it somewhat from being broken by bumps. I always cap and lock my lenses (or zoom my 18-55mm to 18mm) before climbing around things, just as I always fasten my seat belt, it only takes seconds and it's a safe habit to get into.
nnowak wrote:
Jayson A wrote:
nnowak wrote:
What???
Correct me if I'm wrong, but wouldn't stopping down create a smaller pin of light if your camera is facing the sun, causing more damage than a large amount of light evenly spread over the whole sensor?
I just don't see how stopping down is safer than wide open.
Jayson A wrote:
nnowak wrote:
Jayson A wrote:
nnowak wrote:
What???
Stopping down 6 stops reduces the power by a factor of 64. That makes a huge difference if the lens is focussed at infinity. As it will probably be, by Sod's Law, or if you have the Retract lens on power off menu option enabled.
If you have managed to leave the lens at minimum focus, opening up 6 stops increases the size of the bokeh circle from a point source by a multiple of 8, so it increases its area by a multiple of 64. It also increases the power by a factor of 64. That means the intensity of the light within the bokeh circle from a point source should in theory be constant. In practice, the Sun isn't a point source, and the bokeh circle isn't a uniform brightness, so there's definitely an advantage to stopping down.
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
Just tested it with EF-S 55-250 STM on Canon adapter with M6 II and M100, I don't get any message about lens cap!?
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
