24-105 SOS - is it normal for the front of the barrel to rattle?
Started 8 months ago | Discussions
howellls Regular Member • Posts: 193
Canon 24-105 L SOS! Hello, I just took delivery on a very clean 24-105 L lens that I paid good money for. While I own about 7 Canon zooms my only other L lens is a 17-40 (no IS) The 24-105 is very clean but I noticed when you move the front of the lens up and down or right to left, it’s seems like the elements on the front rattle or are a bit shakey, or clunky, basically movement. My other a canon lens are very tight including the L 17-40. However they all weigh significantly less. Is this normal or typical for the 24-105? I took 6 pics so far and it seems to work fine. Will test further later. Any response will be greatly appreciated since I have a few day window where I can return the lens. Thanks
 howellls's gear list:howellls's gear list
Fujifilm X10 Sony RX100 Canon EOS 40D Nikon D700 Pentax K10D +5 more
gipper51 Veteran Member • Posts: 5,904
Re: 24-105 SOS - is it normal for the front of the barrel to rattle?
You shouldn't hear a 'thunk', but it is normal to hear faint rattling or 'moving bits' inside the lens. I believe it's the IS unit which kinda floats around until the lens is powered up. Many stabilized lenses will do this.
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
OP howellls Regular Member • Posts: 193
thanks for your reply. The rattle occurs if the lens is slightly shook, regardless If off or on camera. Also powering on or off makes no difference. I did take 50 photos on 2 cameras in a variety of configurations and they were all excellent. I heard from the seller and he offered to lower the price to 150 from 325. I decided to take the risk and keep it for 150. Other than the rattle it looks great. Thanks for taking the time to reply.
ASR45
ASR45 Forum Pro • Posts: 37,343
I bought a second hand 24-105L MK2 and noticed a lens barrel that moves slightly when extended, never had a problem with any other lens, but using it makes no difference to the photos all sharp and on point, so perhaps worrying about a non issue. Its just annoying if anything else.
Alan.
Great photography is about depth of feeling, not depth of field.
- Peter Adams
Believe in Karma.
 ASR45's gear list:ASR45's gear list
Canon EF 100-400mm F4.5-5.6L IS II Canon EOS 5D Mark IV Canon 6D Mark II Nikon AF Nikkor 80-400mm f/4.5-5.6D ED VR Canon EF 70-300mm f/4-5.6L IS USM +10 more
Andy01 Veteran Member • Posts: 5,191
Wow, that is some reduction (even if the currency is British pounds, 150 seems like a very low price) - is that a red flag ? The original EF 24-105L (some of them, I think earlier copies) had an issue with the control ribbon failing causing camera error.
I had an original V1 lens for a number of years and now have the V2 lens for about 4 years - I don't remember any significant movements or rattles with either of them. I never had the ribbon issue with my V1 lens.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
