Infrared panorama with a DiMage 7
Started 7 months ago | Discussions
Turbguy1
Turbguy1 Senior Member • Posts: 1,467
Unmodified camera, IR 720 filter, handheld, stitched with Microsoft Ice:
https://www.flickr.com/photos/turbguy/52290182507/in/photostream/lightbox/
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
Hike Pics
Hike Pics Senior Member • Posts: 2,917
Re: Infrared panorama with a DiMage 7
Wow, I had no idea the 7 could do that. Very nice! That makes me want to try the filter on my 7i.
neilt3
neilt3 Veteran Member • Posts: 3,008
The original DiMage 7 had a weak infrared blocking filter .
The plus side is pictures like this are possible , the downside was that IR light could cause bloat on some images .
Minolta cured that by adding a hot-mirror ( an infrared blocking filter ) in front of the sensor to prevent this .
The downside being that little if any IR light gets to the sensor and prevents you taking these pictures .
Send Wayne a P.M to confirm as I think he's tried one unsuccessfully .
Or if you do already have an IR pass filter , give it a whirl and let us know .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
Turbguy1
OP Turbguy1 Senior Member • Posts: 1,467
A DiMage 7i will not perform as well for infrared as a DiMage 7.  The 7 has a very weak heat mirror (IR blocking filter).  The 7i has a much stronger heat mirror.  That's what the "i" meant!  You will be unable to hand-hold that 7i.  Exposure times will be very long.    Just get a DiMage 7.
Also, to avoid vignetting at the wide angle settings,  use a 49-62mm step-up ring and a 62mm filter.
Wayne
