Strange Tamron 17-70mm vignetting
Started 8 months ago | Discussions
fernandojval
fernandojval Regular Member • Posts: 428
The Tamron 17-70mm lens with the X-T4 produces a strange double vignetting, which is most noticeable when photographing the sky. It appears at aperture f2.8 and is most noticeable at 17mm focal length. The effect disappears when the aperture is set to f4 or higher.
I hope Tamron service will fix it or replace it with another lens.
I leave some examples in jpg.
I read and write english through Google Translate.
 fernandojval's gear list:fernandojval's gear list
Fujifilm X-T4 Fujifilm XF 50-140mm F2.8 Fujifilm XF 70-300 F4-5.6 R LM OIS WR Tamron 17–70mm F2.8 Di III-A VC RXD +3 more
Erik Baumgartner Senior Member • Posts: 6,893
Re: Strange Tamron 17-70mm vignetting
Do you have a polarizer or any other filter on there?
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
sir_c Contributing Member • Posts: 740
Is it some lens profile that is not correct? If you capture a RAW and view it in a tool that does not enforces the lens profile (e.g. capture one, darktable etc), does it look the same?
 sir_c's gear list:sir_c's gear list
Fujifilm X-T1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
Morris0
Morris0 Forum Pro • Posts: 32,175
That was my first thought and then I noticed there is more than one ring.  Possibly a lens profile issue though I've never seen one do that.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Morris
Or maybe the sun switched to LEDs.
fernandojval
OP fernandojval Regular Member • Posts: 428
Re: Extraño viñeteado Tamron de 17-70 mm
has no filter
fernandojval
The effect appears in the raw files, only with that lens. I have tried with other lenses and the elect does not appear. I have some raw files uploaded here: https://www.dropbox.com/scl/fo/dkd7rm2pa5mm5thtdadiv/h?dl=0&rlkey=aadkrrd72jaoxuyi5s2cekmkz
Morris0
5
Morris
That's it!  The sun is trying to save energy as it's hydrogen bill is getting out of hand.
Morris
Morris0
Profile issue
You are experiencing a profile issue. I opened one the RAW files in Photoshop and it looked the same. The JPEG you posted was processed in Elements, also an Adobe product. I then opened the file with a different RAW viewer and the concentric rings are gone yet the corners are dark.
Morris
fernandojval
Re: Problema con el perfil
Morris
What solution do you propose?
Lettermanian
Lettermanian Senior Member • Posts: 2,389
Interesting, I'll try it with mine this week on my X-T3 and X-S10. I normally just shoot and edit jpeg (🤫) but I'll try some shots like this in raw to see if I get the same effect.
"Be yourself. No one can say you're doing it wrong." -Charles M. Schulz
"I love mankind... it's PEOPLE I can't stand!!" - Linus
 Lettermanian's gear list:Lettermanian's gear list
Fujifilm X-T3 Carl Zeiss Touit 2.8/12 Tamron 17-70 F2.8 Di III-A VC RXD Fujifilm XF 70-300 F4-5.6 R LM OIS WR
5
fernandojval wrote:
Morris
Definitely faulty firmware in the lens. See if there's an update.
I did a quickie edit with one of your RAWs with some manually applied corrections in Lightroom  after first stripping the metadata correction data with Iridient X-Transformer...
fernandojval
fernandojval wrote:
Morris
Thank you !!! I can't find any firmware for this lens on the internet. I think I'll send it to Tamron technical support.
fernandojval wrote:
Morris
Yeah, send it back. There are certainly are people using that lens without problems so they ought to be able to sort it out. Has anyone tried this with Capture One? It can switch from the manufacturer's profile to C1's own profile, or to no profile (I think).
fernandojval
Has anyone taken test shots with the Tamron 17-70mm f2.8 for Fuii and processed them with Adobe software?
sluggy_warrior Veteran Member • Posts: 3,204
Here's my vignetting calibration shot at 17mm/2.8, if you want to see if both my lens and yours have the same problem:
https://drive.google.com/file/d/1-ytthPwITTtUKO2iwvSCz_raUOvocfJu/
If Adobe software is reading the correction profile directly from EXIF, then either it's reading it wrong, or the lens is giving the wrong data.
Here's the SOOC Preview extracted from the RAF's EXIF, both distortion and vignetting looks good, so at least the lens relayed the correct profile to the camera (thus, unlikely to write the wrong info to EXIF?).
SOOC Preview extracted from EXIF
darktable/lensfun doesn't have correction profile for this lens yet, so I had to calibrate one myself:
https://www.dpreview.com/forums/thread/4665938
Here's your shot without and with distortion+vignetting correction in darktable (using my own calibration):
from darktable, with no lens correction
from darktable, with distortion + vignetting correction
My distortion correction is still slightly off in the middle comparing to SOOC. I'll have to calibrate again soon. Better yet, I should adapt the new script to extract the correction data directly from the EXIF:
https://github.com/lensfun/lensfun/discussions/1606
fernandojval
No one else has this problem?
No one has this vignetting when importing/editing RAW files with Adobe software?
fernandojval
Although Adobe has been made aware, in the Adobe community forum, of the double vignetting error of the Tamron 17-70mm f2.8 lens for Fuji, nothing has changed in the latest version of LR, ACR or PS.
If you are thinking of buying this lens and you edit with Adobe software, I give you a recommendation: WAIT, the bug is still there.
Leo y escribo inglés a través de Google Translate.
McNoodle Forum Member • Posts: 86
My lens does not do this.
 McNoodle's gear list:McNoodle's gear list
Fujifilm X-Pro3 Fujifilm X-T5 XF 90mm Fujifilm XF 16mm F2.8 Fujifilm XF 16-80mm F4 +4 more
We pretty much determined this to be a lens firmware/profile issue. I don’t think it’s Adobe that needs to come up with a fix. I would try complaining to Tamron to sort this out.
