Nikkor AF 180mm 2.8D ED
Started Aug 20, 2022 | Discussions
Igor Sotelo Contributing Member • Posts: 923
I have the excellent Nikkor 180mm 2.8 ED AI-S, and was wondering if to get also the Nikkor AF 180mm 2.8D ED at a fire sale.
I tried the lens few years ago when was buying my Nikon Df and was very impressed by the built quality. Unfortunately didn’t take pictures that time.
It has a different much more complex optical formula and was wondering if it’s worth trying it?
 Igor Sotelo's gear list:Igor Sotelo's gear list
Nikon D800 Canon EOS 6D Nikon Df Canon EOS 5DS Sony a7R II +35 more
Nikon Df
Michael Benveniste
Michael Benveniste Veteran Member • Posts: 6,728
Re: Nikkor AF 180mm 2.8D ED
I don't remember if I used the 180mm f/2.8 AI-s or the AI version.  Either way, it's literally been decades.
I do still own the 180mm f/2.8D.  Unlike the manual focus lenses, it's an internal focus lens, which accounts for the different optical formula.  in 100% crops from a modern dSLR, it shows the expected behavior from a film-era design.  It's a bit soft wide open and at least my copy shows noticeable chromatic aberration.
Is it worth trying?  I'd say yes, under the following conditions:
  • You plan on staying with a dSLR for the foreseeable future.  On an adapter you won't retain autofocus operation, and the manual focus action on the 180mm f/2.8D is sloppy compared to most dedicated manual focus lenses.
  • You won't incur a lot of extra shipping charges should you decide it's not for you and "flip" it.
  • You enjoy shooting with a 180mm prime.  Perhaps that's obvious, but sales of 180mm primes fell off a cliff soon after the 80-200mm f/2.8 AF was released.  In the 25 year run of the 180mm f/2.8D, Nikon only sold about 100 a month.
Light travels at 2.13085531 × 10^14 smoots per fortnight. Catch some today!
 Michael Benveniste's gear list:Michael Benveniste's gear list
Nikon Coolpix 995 Nikon D800 Nikon 1 V2 Nikon D7200 Panasonic Lumix DMC-GX85 +49 more
Stan Disbrow Veteran Member • Posts: 8,069
Hi,
I have the AI 180/2.8 from the FE days. I picked up an AF 180/2.8 when I bought my D1 back in 2000. I haven't used the AI one since. Including on the Df. Poor old lens isn't of much use today. The helicoid grease has greatly stiffened up. That's a problem with the manual focus 180/2.8....
Stan
Amateur Photographer
Professional Electronics Development Engineer
Once you start down the DSLR path, forever will it dominate your destiny! Consume
your bank account, it will! Like mine, it did!
John Crowe
John Crowe Veteran Member • Posts: 3,961
AF could be very useful in this focal length. According to Bjorn Rorslett the AF version is slightly better in all respects.
The AF is not great for manual focusing but you will have the original for that.  Apparently both are a little soft wide open but I find that hard to believe.  All lenses sharpen up one stop smaller.
Give it a shot and let us know how you make out.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
OP Igor Sotelo Contributing Member • Posts: 923
Hi,
I kinda like manual focus lenses. Used them for many decades. Hopefully will continue using the AI-S version.
Will give it a try, the offer was too good to pass, something around $250 shipping included and the lens seems in excellent condition.
Too bad the 180 D isn’t an AF-S lens. But I still have to upgrade to the Nikon D850, so I think will stay with DSLR’s for my Nikon system for long time, God willing.
It seems AI-S are better than screw drive AF lenses for mirrorless since were designed for manual focus. Perhaps Nikon will release an FTZ adapter with a built in motor. I think Sony has one of those for their A screw drive lenses.
Another option are Techart AF adapters Z to M adapters with an additional M to F adapter, but that only works with lighter lenses.
The 180mm 2.8D has some advantages over 70/80-200mm 2.8 lenses, it could make sense to have one of those. Specially since the lens is highly regarded by many people.
Hi,
I did as well. However about the time I could  get a D1 -same issue then as the Z9 now- I also got hot and heavy into circle track racing. I could always make MF work on road course tracks, but it was a really tough row to hoe at the Friday/Saturday night bullrings.
So I went for a new 80-200/2.8 zoom. AF fixed one issue, but that lens is too unwieldy to shoot thru then corners from the infield. Hence switching to the AF 180/2.8 instead. Works great, and has all these years.
Stan
Kazmarov Senior Member • Posts: 1,327
My two pennies worth (mind you pennies are no longer valid currency).
Well made, good value for money lens if the focal length works for you. High CA at wider than 4.5 so you will need to stop down for those situations or mask & deal with fall-off in post processing. I tend to use it for widefield astro so don't have much daylight stuff. Do not agree with comment by poster on hard to focus manually - at least my copy works well for astro which is quite demanding on focusing - I do use a Bahtinov on it for that application. AF is a bit clunky in keeping with its venerable age. All in all, the 200mm f/2 is in my view, a better lens but much more expensive and harder to source here in the UK.
Pembrokeshire fishing harbour
 Kazmarov's gear list:Kazmarov's gear list
Sony RX100 III Nikon D90 Canon EOS 60D Nikon D5500 Nikon D7200 +10 more
Van Griff Senior Member • Posts: 1,938
Igor
Here is a link from Gary's thread where I posted some sample images . . .
https://www.dpreview.com/forums/post/66413641
. . . fab lens . . . relatively lightweight and portable . . . tack sharp . . . great bokeh and isolation wide open . . . does suffer from CA issues when shooting into bright light . . . but with the correct framing and orientation it can be killer . . . relatively inexpensive at 300 bucks or less . . . highly recommended!
Best,
V G
 Van Griff's gear list:Van Griff's gear list
Nikon D700 Nikon D7000 Nikon D810 Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF Nikkor 105mm f/2D DC +35 more
rscott900ss
rscott900ss Regular Member • Posts: 496
I have the AF ED IF version from sometime around 1990 and it's a lens I won't part with.  It's one of those Nikkors that has that little something extra you can see in your images.
It scores poorly on lens tests, but ranks high in my heart.  Some refer to it as "legendary."
 rscott900ss's gear list:rscott900ss's gear list
Nikon Z7 II Nikon Z 24-70mm F4 Nikon Z 50mm F1.8 Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR +22 more
Richard Dutton Contributing Member • Posts: 989
I have that AF Nikkor and used to use it a lot on a D7100/D500 but not for some time.
No idea how it compares to the ai or ai-s versions bu the fast AF is certainly useful if you want to do any sports/action stuff.
There seem to be mixed views on the chromatic aberration:  most say that lateral is low and axial is very low.  I don't remember much of an issue with either.
I have used it a bit on a Z6 in MF obviously and it works very well but I suspect it depends  on whether  you have a newer copy with a helicoid in good shape.  On mine it is very smooth and there is no hysteresis/backlash.
I mainly used it with a Kenko pro300 DG 1.4X tc but then switched to 300/4 primes hence little use recently.
Curiously I use the AF 180mm 2.8D ED IF a lot. It cost not too much (neither did the 180mm 2.8 ED AI-S, that also use a lot). Very fast AF, fine overall rendering, good bokeh.
