X100 Pro
Started 8 months ago | Discussions
The Lamentable Lens Senior Member • Posts: 1,112
Re: X100 Pro
GSharp87 wrote:
Jeff Biscuits wrote:
GSharp87 wrote:
It would be awesome if Fuji would start developing a Pro version of the X100 series with the following features
  • 18mm f1.4 lens
  • New high MP sensor rumoured for the X-H2
  • X-Pro body ergonomics and build quality
  • NP-W235 battery
  • IBIS
  • Priced around $2.5k
Would anybody else be interested in such camera? I’d take that over something like a Leica Q2 every time.
What advantage would it have over the Q2? It would be half a stop behind the Q2 in terms of light gathering and depth of field, ”X-Pro build quality” is behind the IP-rated Q2, the rumoured new sensor is (as I recall) still of lower resolution than the Q2…
OK, there’s the price… but if price is the sole reason to take something over a Q2 every time, then you might as well argue in favour of a Canon P&S 😉
As someone else noted, if as a camera manufacturer you’re going to make something that’s like a Q2 but not quite as good as a Q2, yet still more expensive than pretty much any other fixed lens camera, then you’re looking at a vanishingly small market—especially when much of that market is served by one or two of your own cameras.
Image quality between the XF 18mm f1.4 and the 28mm “Summilux” is indiscernible. Check out the comparison done by Samuel Streetlife on YouTube. He did a blind comparison of the same scene and the majority actually preferred the Fuji.
And yes, half the price would be a huge advantage and a big reason for me buying one, especially if it performs on par with the Q2 in IQ. I personally wouldn’t feel comfortable daily carrying a $5k camera.
Whether you're right or wrong, the Leica crowd won't agree that there is parity between those two lenses, and their belief is what drives their purchasing decision.  And of course there is more to that camera than the lens -- the sensor and the ergonomics play a large role, too.
My point isn't that the Q2 is a "better" camera -- there's no such thing from an objective standpoint.  My point is simply that there aren't likely many people who like, want, and can afford the Q2 who would be lured away by an X100 Pro.  Instead, an X100 Pro would most likely be competing with the X100, which really doesn't make sense for Fuji.
And I suspect it would mostly lose that competition, too.  Once you get to that size, weight, and cost, I think most people would just go with one of the ILC versions (the very unscientific anecdotal evidence from this thread certainly suggest as much).  I suspect the X100 would still be the camera of choice for most people wanting to add a fixed-lens camera to their kit.
 The Lamentable Lens's gear list:The Lamentable Lens's gear list
Sony a7R III Sony a7C Sony FE 85mm F1.8 Sony FE 24-105mm F4 Sony FE 135mm F1.8 GM +9 more
forest dream Senior Member • Posts: 2,796
Re: X100 Pro
Foskito wrote:
I would be interested in an “XL100” the size of the X-Pro with a medium format sensor and a 18-35mm (full-frame eq) f2 lens.
My other wish is an X-Pro5 with IBIS and the same minimalistic back and no grip as the X-E4.
X-Pro series (MILC) should be completely irrelevant to this conversation (X100 series is fixed lens camera).
Foskito
Foskito Senior Member • Posts: 1,412
Re: X100 Pro
"I would be interested in an “XL100” the size of the X-Pro with a medium format sensor and an 18-35mm (full-frame eq) f2 lens."
 Foskito's gear list:Foskito's gear list
Canon EOS 5D Leica M8 Panasonic Lumix DMC-G1 Leica M9-P Canon EOS 6D +14 more
DirkPeh
DirkPeh Contributing Member • Posts: 520
Re: X100 Pro
Leave it as it is. Just add better AF and a better sensor, when both are available - and IBIS. And in a few years: Fullframe - if it then will still have advantages.
It is already an expensive camera for what it is, but the quality and design of the camera convinces people to buy it. Well done Fuji. But it should stay in its price range.
 DirkPeh's gear list:DirkPeh's gear list
Panasonic LX10 Ricoh GR III Fujifilm X100V Sony a6400 Sony E 50mm F1.8 OSS +5 more
X100VI which X-H2 part
  • 40MP BSI-CMOS X-Tran sensor (which used in X-H2)
  • X-Processor 5 (which used in X-H2s/X-H2)
  • Subject based AF algorithm (which used in X-H2s/X-H2)
  • Rework 23mm F2 lens so that suitable for 40MP sensor
  • Single UHS-II SD card slot (which used in X-T2)
Above not rocket science, just recycle existing part.
100% agree. $1,399 fixed prime APS-C already consider enough "premium".
Jeff Biscuits Senior Member • Posts: 1,167
Re: X100 Pro
5
…says the person who introduced a portable speaker to the conversation 🤪
 Jeff Biscuits's gear list:Jeff Biscuits's gear list
Ricoh GR Digital II Ricoh GR Digital IV Fujifilm X20 Fujifilm XF10 Ricoh GR IIIx +14 more
ISO 1 Million Contributing Member • Posts: 691
Re: X100 Pro
I'd definitely be up for one except my list of requirements are different from yours.  What I want in this order is:
1. Far more extensive weather sealing around the entire body - I killed my first X100V at Niagara Falls and damn near killed my second one in Costa Rica from rain.
2. IBIS
3. Better AF especially for tracking
4. More robust build - the dials, the tiny fragile joystick, the thin metal hinges on the flip out screen all have room for improvement
5. D pad
6. More battery capacity with percentage indicator
www.harrytamphotos.com
 ISO 1 Million's gear list:ISO 1 Million's gear list
Fujifilm X100V Sony a9 Sony a7R III Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 55mm F1.8 +6 more
John Gellings
John Gellings Veteran Member • Posts: 9,743
Re: X100 Pro
The Lamentable Lens wrote:
  • 18mm f1.4 lens
  • NP-W235 battery
  • IBIS
I agree completely. The Q and Q2 are great cameras. Why they sell so well is that you get a Leica body (typically $8000 if you get an M instead) and a fast Leica 28mm lens (Typically $3000+) for half the price of a typical digital M with lens. The original Q was $4200 when released, so it was even more true then. Now, the Q is not an M, but to those who are new to Leica or go to the brand due to its status, that does not matter. They just want a Leica. Fujis are great, but they are not status symbols. I like that about them though.
It is true. I see it on this forum a lot... "$1400 is crazy for a camera in which you cannot change the lens!" If we already see that, then at $2500-3000 it certainly will be a much harder sell. I think we have more of a chance of seeing a fixed lens GFX camera that competes for photographers who otherwise might go for the Q series, then an even higher end fixed lens APSC camera.
https://www.johngellings.com
Instagram = @johngellings0
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
Foskito
Re: X100 Pro
Exactly. He troll me because I mention the X-Pro camera and he brought a set of speakers😂😂😂
John Gellings
Re: X100 Pro
Uhm, no.   It is still a Fuji camera that paired with a lens would be the same price as the proposed X100 Pro.  Of course it would directly compete.
tkbslc Forum Pro • Posts: 17,523
Re: X100 Pro
- 18mm f1.4 lens
This will make the camera MUCH thicker
- New high MP sensor rumoured for the X-H2
- X-Pro body ergonomics and build quality
Adding more weight
- NP-W235 battery
More weight and thickness
- IBIS
- Priced around $2.5k
Severely limits the market
Would anybody else be interested in such camera? I’d take that over something like a Leica Q2 every time. It’d be the ultimate street/documentary camera.
I think you would end up with a camera that has little to offer over just an X-series body and 18mm f1.4 lens.  You've added a big list of features that just makes for a heavy and thick fixed lens camera.  And then what's the point?   X100 series is thin and light and simple and affordable enough.  That's why it is popular.   Having an X-PRo3 with a glued on 18mm f1.4 at the same price isn't very appealing to me.
DarnGoodPhotos Forum Pro • Posts: 11,882
Re: X100 Pro
- 18mm f1.4 lens
- NP-W235 battery
- IBIS
Just get the upcoming X-Pro4.
Except for the leaf shutter, and maybe IBIS, it will be the camera you described. Once you get an 18mm f1.4 lens that can resolve a 40MP sensor, the body won't be compact because the HVF has to move further away from the lens so its view isn't blocked.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Re: X100VI which X-H2 part
It's a camera AND lens for only $100 USD more than the X-E4 and XF 23/f2 lens. Price-wise its not any more premium than the X-E4 and f2 lens is.
The XE4's advantage is ILC, front facing LCD option, and the new AF tracking, while the X100V's advantage is the better EVF, OVF, leaf shutter, closer focusing, and built-in flash.
Fujifilm X-E3 launch in three kit configurations: body-only for $900, with 18-55mm for $1300, or with 23mm F2 R WR for $1150.
The X100V is comparable to the X-E4, not the X-E3, with the XF23 f2 lens; that combo is similar in price (USD) to the X100V.
xtm Senior Member • Posts: 1,405
Re: X100 Pro
Put a 50R sensor in it and make the lens a 58mm 1.4 full frame equivalent and I'm in.
 xtm's gear list:xtm's gear list
Nikon Df Leica M10 Fujifilm X-Pro3
FujiShooterCY Regular Member • Posts: 445
I consider this to a pretty strange approach
Or are you asking Fuji to make  their own breed of Leica? they won't because Fuji already has their own X-Pro camera lineup (not at all bad) and their own Fujicron lens lineup, too, and their own new top-notch F1.4 LM lens lineup, too.
All I post is my own, humble, personal, subjective and highly biased opinion. It may change in time upon new facts and convincing arguments arrival.
John Gellings
Re: I consider this to a pretty strange approach
Yes, he wants a Q2 but doesn’t want to pay for it.
biza43 Forum Pro • Posts: 15,074
Re: X100 Pro
It does not make sense. Might as well get the X-Pro and the 18 f/1.4.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
