Shooting mirrorless - viewfinder/lcd switch?
Started 7 months ago | Discussions
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
I've never shot a ML camera underwater before, but I'll be using my Z9 next week there.
Testing in my house I found an issue.  The housing doesn't allow eye-detect to work, so either the viewfinder or the monitor is active, and I have to manually swap between them.
This is a clear disadvantage compared to my D850.  There, of course, the viewfinder always works without having to switch a lever to it, and the menu and playback are always on the back panel monitor.
Is it typical that ML cameras (like the Z9) require one to manually switch the display from the viewfinder to the monitor?  I'd like at least playback to default to the back panel, though I can see times where it would be handy to see it in the viewfinder.  It just takes extra time to constantly hit a monitor lever to swap displays.
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Nikon D850 Nikon Z9
Barmaglot_07 Contributing Member • Posts: 633
Re: Shooting mirrorless - viewfinder/lcd switch?
Unlike a DSLR, you don't need to switch. You can equally well review shots in the viewfinder, without taking your eye off the camera, or compose through the LCD, without ever using the EVF, and not suffer any degradation in performance.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
PHXAZCRAIG
OP PHXAZCRAIG Forum Pro • Posts: 19,651
I guess I need to get used to doing things a different way here.   I would prefer the playback to be on the LCD monitor though, if only for the size, plus the convenience of not having to look through a 45 degree viewfinder while studying settings.
www.cjcphoto.net
Dann-Oh Contributing Member • Posts: 894
I might be in the minority but I tend to shoot with my LCD.  I have my camera set to sleep after 60sec to save battery.  I will capture a few images then review them with a push of a button on my LCD then proceed to capture more or move on if I'm happy.   I just got a 90dep viewfinder but I haven't tried it out yet.
You might be able to set a custom button to make the switch?
I take photos, not particularly good photos, mostly abstract photos. Yeah abstract is what I would call them, you might call them blurry.
 Dann-Oh's gear list:Dann-Oh's gear list
Olympus E-M5 III Olympus E-PL10 Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 +20 more
PHXAZCRAIG
There is already a dedicated lever.  No need to customize a button for it.  I just need to limit selection to viewfinder only and monitor only so I can toggle between them.
I've shot with a 180 degree viewfinder for 7 years, except in the few times I've done video.  I generally like it because pressing the viewfinder against my mask adds a 3rd point of contact that stabilizes the camera.   It's also very easy to take a landscape shot, then spin the camera 90 degrees and get a portrait shot.
www.cjcphoto.net
I must have miss understood your original question/comment.
PHXAZCRAIG
I guess I should specify what I want, or at least what would be acceptable.
Since the auto-detect feature doesn't work in a housing to switch between viewfinder and monitor, I think I have two choices (theoretically):
My 'requirement' is not having to push another button other than the playback button. I want the playback to be on the monitor. So...
1. Have an option to specifically direct playback to monitor, while leaving active viewing to the viewfinder, or
2. Duplicate everything on both monitor and viewfinder at the same time. Let me pick. Obviously a battery drain, but in my case a useful option.
Another option might be to somehow combine the function of the monitor or playback button so that using either switches to the monitor and then displays the image.
The whole point of this is that I want the bigger size of the monitor for playing back images, and I kind of like having them pop up there automatically, the way my DSLR's have done since the D70s.
www.cjcphoto.net
