Diagonal tilt - Ts-e lenses. Issue with panorama shift?
Started 8 months ago | Discussions
Martin Erik Andersen
Martin Erik Andersen Junior Member • Posts: 43
The PocketPANO frame has two tripod feet offset by 90°. Their function described at the homepage as this:
“...In combination with the two rotation elements of the TS-E lenses, all imaginable combinations of portrait and landscape format, horizontal and vertical shifting as well as tilting can be realized.”
https://www.pocketpano.de/english/rear-tilt-n-shift-frame/
Not quite sure but I think this solves a limitation of the Canon Ts-e lenses regarding diagonal tilt in combination with shift for panoramas/vertoramas.
I haven’t seen the issue fully described anywhere online. And it is a bit complicated to describe, but I give it a quick try: If you take 3 shifted shots for a panorama one only has the option of the diagonal tilted focus plane going left down or right up. If one wants the planes to go left up or right down, one has to rotate 90° at shifting rotation axis – and this rotation gives you a vertical vertorama instead of a panorama format in the 3 shots for stitching.
I suppose the way around it without the PocketPano frame is to make the 90° rotation at the tripod head, overhanging the camera to the left or right to the side of the tripods centre axis (and adding some instability to the tripod setup).
I might be wrong, diagonal tilt is rather difficult to get ones head around 😊
Here a link to one of Keith Coopers excellent videos on the topic: https://www.youtube.com/watch?v=HcwM8P6SNKw&ab_channel=KeithCooper
Other links visualizing the aspects of diagonal tilt on the Ts-e lenses much appreciated.
 Martin Erik Andersen's gear list:Martin Erik Andersen's gear list
Canon EOS 5D Mark III Canon EOS 5DS R Canon EF 16-35mm F2.8L II USM Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM +2 more
OP Martin Erik Andersen Junior Member • Posts: 43
Re: Diagonal tilt - Ts-e lenses. Issue with panorama shift?
Did some tests, and I actually can't get a 90° rotation on the tripod head to solve the issue. I suppose that also rules out the PocketPANO solving it.
I suppose the way around it without the PocketPano frame is to make the 90° rotation at the tripod head, overhanging the camera to the left or right to the side of the tripods centre axis (and adding some instability to the tripod setup)..
I will take some test photos and post them later to illustrate the problem (which surely might be me not being able to get my head around the possible combinations of the lens rotation axes)
Photos illustrating the issue
Here an attempt at a photo set up to illustrate the issue.
The red gradients approximate the tilted diagonal focus planes in between the tape lines (sorry just a quick setup)
The first 4 shots are single frame. And all is well and fine. All the 4 four diagonal directions of tilt are covered – by rotating the tilt axis ca. 45°, and importantly for my issue by rotating the shift axis by 90°:
But here comes the issue. When taking 3 photos with shift for a panorama, I can not rotate the shift axis the 90° (as it of course is in use for the panorama). And I end up with only 2 of the 4 possible directions for diagonal tilt:
Am I wrong? Or is this a limitation of the tilt axis on the Ts-e only being able to rotate 90°?
I am aware that using diagonal tilt in panorama may seem an unusual feature, but personally I like it a lot for creative purposes. And it is of course important to know what is possible and what’s not when standing in field trying figure out a shot. The diagonal tilt and the combinations of rotations on the ts-e lenses sure is complicated.
Well I hope I am wrong, and hope that someone here can show me the solution, in simple and practical terms (I have given up on the deeper math of Mr. Scheimpflug😊) .
Keith Cooper
Keith Cooper Veteran Member • Posts: 3,270
I'd never bother with tilt and one of the lens holder contraptions, yet alone trying it for panoramic use.
Using tilt and stitching has a lot of potential gotcha's - with very few instances I've ever found a [good] use for it.
One day I'll find a really good example which needs it and use it for an article/video [suggestions welcome]
For basic tilt setting you just need to ignore the click stops...
I've an article about setting tilt on an arbitrary plane at
https://www.northlight-images.co.uk/setting-the-tilt-axis-for-tilt-shift-lenses/
also a video looking at it
Oh, and my book...
bye for now
Keith Cooper
 Keith Cooper's gear list:Keith Cooper's gear list
Canon EOS 5DS Canon TS-E 17mm f/4L Canon EF 8-15mm f/4L Fisheye USM Canon TS-E 24mm f/3.5L II
Keith I have read through all your articles on tilt and shift on your absolutely great homepage. Your articles and your videos on the topic for sure are the most clear and detailed online (and I will buy your book, promise 😉)
My purpose for tilt and panorama I suppose is basically creative. The tilt introduces an atmospheric sense of space which I find very interesting, and creatively highly useful - I am totally aware many will find it rubbish (used to that as a professional artist, mainly sculptural stuff and non-interest by most people is simply a part of the trade).
But that aside: from a purely technical point of view couldn’t it interest you if the Ts-e lenses actually have a 50% limitation in their use of diagonal tilt in panorama photos? Only being able to utilize 2 out of 4 angles? Just as a technical curiosity? Probably not enough for a whole video, but just as an interesting appendix on the limitations of the lenses which haven’t been described elsewhere?
Well, I will give it some more effort with the knobs and rotations axes trying to figure out if I am stupidly wrong or if the lenses actually have this limitation.
Keith Cooper
Why is there a limitation?
What is wrong with just rotating the tilt axis by 20º or 17º as desired?
Sure, it's harder to replicate, but I still don't really see what it is you're trying to do that can't be done?
Would one of these help?
https://www.northlight-images.co.uk/ppl-tse-adapter-lens-shift-review/
Not sure where you can get them any more...
bye for now
Keith Cooper
The limitation I am struggling with only apply for panorama or vertorama photos made by multiple shots using shift.
In a single shot (with no intention for stitching to panorama) I have no problem getting any of 4 possible diagonal planes focused.
As far as I can see what is going on is this: The tilt rotation axis can rotate 90°, stetting the rotation around 45° and tilting down results in upper left diagonal focus plane. Tilting up results in lower right diagonal focus planes. Focus planes marked in red:
To get the two other diagonal planes in focus I have to rotate the shift axis 90°:
But the rotation of the shift axis 90° turns the shifting direction from horizontal to vertical. And this is of course not an option if the intention is to stitch photos to a final horizontal panorama.
Setting the tilt axis rotation less or more than 45°, as far as I can see, only refines the diagonal rotated plane within the total of the 90°. The 10° being closer to plain tilt, and 80° closer to plain swing.
The total image circle is 360° and using the tilt rotations axis of 90° in conjunction with “up/down” covers 180°. To cover the remaining 180° the shift axis has to be rotated 90° - this turning the shift direction from horizontal to vertical.
Hope this is a bit clearer, and sorry if my language and vocabulary is of - English is not my first language.
Keith Cooper
OK, I can see this limitation with the TS-E mount if you want the same shift direction (and why the internal cabling causes it)
My only solution would be to use a shift adapter to replace the standard EF->RF one I use - of course it needs electrical connections. No use of course on my native EF mount DSLRs
For my adapted (M645) lenses, with no electrical connections, it's not an issue, but then again I've no parallax cancelling mount for them, so it's a matter of manual camera shift to offset the shift of viewpoint.
Other expensive solutions spring to mind (involving adapters and medium format backs...
Fortunately (well, for me anyway   ), I have very little use for tilt when shooting stitched wide angle shots.
Maybe I'll try some experiments with my assorted adapted lens solution (35-210mm)!
bye for now
Keith Cooper
Thanks Keith. Kind of nice to know this limitation actually is in the Ts-e lens - and not in me not being able figure out the settings. That is to say that I don't have to try to do something that is not possible out in the field.
Now what to do about it...can probably get very expensive very quickly. Well, all gear has limitations....and I find a lot to like in the Ts-e lenses....can't afford any upgrades right now, but I am surely tempted...
Brett8883 Contributing Member • Posts: 852
Martin,
I may not be fully understanding the issue but in your situation as I understand it you would shift the lens 45 degrees with no additional tilt rotation required. Then you’d be able to tilt in all diagonal directions right up, left up, right down, left down.
If you wanted to make a pano from it you could make an X pattern using shift and taking photos from 4 or more different shifted locations instead of 3. So 45 degree shift left up, 45 degree shift left down, shift right up, and right down.  You may not be able to get the full width of the image circle since you are shifting diagonally, it would still be much a much wider pano than the non shifted full frame image circle. The keys is you need a 45 degree shift rotation not 90 degrees.
Again not sure how well 4 different tilt directions will stitch together but that’s how you can them
Thanks a lot. Shift direction in 45° for stitching panorama haven't crossed my mind
Setting the camera up on the tripod like this sure gives the possibility of getting the diagonals right for focus in any of the 4 directions:
I will give it a full try in a couple of days. And see how much cropping in the final stitched panorama it will result in compared to the plain horizontal camera orientation and 90° shift direction.
It was a good challenge question! I probably wouldn’t have thought about it but I had already been exploring diagonal shift panos for other purposes.
Let us know how it goes.
45° stitch direction
I have now tried the 45° stitch direction of five shots in a cross pattern. But after cropping with surprisingly little gain in the final panorama format compared to a single shot. Actually surprisingly next to nothing:
I could probably have been more precise in getting the 45° correct (the clicks at shift axis being at 30° and 60°), and then having to crop less, but still I suppose not terrible much would have been gained.
A bit better than a 3 shot stitch, but again not much compared to a single non-stitched shot:
As far as I can see getting more of the image circle into play would require a 90° rotation of the shifting direction, and that would again change the possible tilt focus planes to the opposing 2 possible diagonals. And the additional photos would not be able to stitch into a single photo as the tilted diagonal focus planes would not match.
I sure might be doing something wrong. The 45° degree shift direction for panorama certainly ads to the complexity of it all.
But anyway interesting to make exercises at a primitive test setup – I am getting more familiar with the settings and the possible focus planes, it will be useful when making decisions in real life. Hereby recommended 😊
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,601
For myself - I likewise don't see the image ROI of stitching more shots vs less ( say std 3 axis H_V_D _shift or backing up and taking one single frame with adequate DOF and framing from the hyperfocal vs tilting.
For myself, If creativity, shallow DOF is the goal, Fisheye or macro gets the call before TS E.
Analogous to stacking 12 shots at F 5.6 in macro vs backing up a tad and doing one @ F 16. , the former never looks " quite right" they always have some " wonkiness".
I spent much time and effort with macro stacking but ultimately found the simple method offered more success and fewer potential pitfalls.
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
Re: 45° stitch direction
Martin your resulting stitch looks very unexpected to me. Did you rotate the camera 45 degrees instead of the lens? The camera should not rotate.
Martin, I think you used different angles for your crosses and that’s why your images didn’t align properly. I think you also rotated the camera 45 degrees not the lens??
I just tried my idea off my deck and here is the result. I wasn't using a very sturdy tripod so that could be the reason the double diagonal pano didn't meet in the corners. However, as you can see this method very nearly gives you the same width as the 3 shot horizontal pano and is much wider than a single shot. It took me 30 seconds to take all 5 shots so I really don’t think it’s as complicated as you make it out to be.
STEPS:
Step 1: Rotate lens counter clockwise 45 degrees on shift axis
Step 2: Shift lens 12mm down and to the right.
Shot 1: Shift down right
Shift lens back to center.
Shot 2: No shift
Step 3: Shift lens 12mm up to left
Shot 3: Shift Up left
Step 4: Rotate lens clockwise 90 degrees on shift axis
Shot 4: Shift Up right
Step 5: Shift lens 24mm down and to the left (you go from full shift up right to full shift down left)
Shot 5: Shift down left
I didn’t do the tilts and focus stack them but the premise of your original post wasn’t asking the validity of focus stacking a pano with 4 different tilt directions, it was how you could physically manipulate the lens to take those photos assuming you wanted to. You’d have the same issues with focal planes matching up even if you were able to freely rotate the lens 360 degrees on both the shift and tilt axis.
Hi Brett, I think what you suggest only will give you 2 out of the 4 possible directions for diagonal tilt.
The issue is doing the shots for the stitch with consistent diagonal tilt direction - in any of the four possible diagonal directions. That is to say in four different variations of the same panorama view.
"Step 4: Turn lens clockwise 90 degrees on shift axis"
With your step number 4 turning the 90 shift axis the diagonal tilt direction also rotates to an opposing angle. This results in mixed diagonal tilted directions in the photos for the panorama stitch.
I suppose it might stitch together if the contrast between focused and unfocused areas isn't too strong, but it would then be an artificial digital blend of different diagonal angles of focus.
Well, difficult to describe in writing, easier to see it in praxis. But for the experiment one has to try to do the stitched material for all four diagonal directions - for the four different versions of diagonal focus of the same panorama view. It takes some time, but it is fun trying 😊
For a stitched horizontal panorama I still think only these 2 diagonal tilted focus planes are possible:
And these 2 directions are not possible:
One can of course make the less wide panorama format, by 3 stitched vertical shots. This will result in the mirrored options of diagonal focus planes.  Cropping this version down to the wider format could be said to limit the limitation.
(but I certainly will not rule out I am wrong, I have before been getting stuck in repeated errors in multiple variations )
I am aware the issue I am trying to get a hold on here may seem a very minor limitation.
But I have been out trying to get the shots for a landscape panorama while the light is fading and the rain clouds are setting in, and,,, "why the heck can't I get the focus plane to be where I want it to be?.." If I had known there were actual limitations in the options of diagonal tilt, I could more quickly have made compromises in for example distance or composition ...instead of fumbling with the knobs till the light was gone.
Martin, I thought since you had already agreed that doing diagonal panos solved that issue I thought the only question was how much horizontal width the method yielded so I cut the tilting directions out of my instructions. My apologies for not addressing that part of it.
At step #4 you would flip the camera upside down on that mount you reference in your first post and then rotate and shift back to get back to the upper left photo and now you’d have the impossible angles available to you.
And yes it’ is complicated with tilt involved but I assumed that didn’t need to be said. It’s already complicated without the 45 degrees. Remember you can lock the shift rotation at any angle with the screw lock for when you are changing tilt angle btw
