GX7 centering single focus target
Started 8 months ago | Questions
AlainAntoineTurgeon Forum Member • Posts: 54
I cannot reset the focus target to the center, it stays shifted to the upper right
tried with the 42,5 and the 20, same thing
Thank you very much
Alain Antoine Turgeon
 AlainAntoineTurgeon's gear list:AlainAntoineTurgeon's gear list
Panasonic Lumix DMC-LX5 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +4 more
Danielvr Veteran Member • Posts: 6,863
Re: GX7 centering single focus target
Depending on what screen you're in, pressing the Disp button might do it.  If not, one of these previous discussions will probably hold the key:
https://www.dpreview.com/forums/post/57164520
https://www.dpreview.com/forums/post/55443130
https://www.dpreview.com/forums/post/57800007
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
richj20 Forum Pro • Posts: 10,181
Thank you very much
1. Press the button you have assigned to "Focus Area Set"
2. Press the DISP button
Suggestion: If you configure one of the Custom Modes for your every day use, every time you power ON, the camera uses your default settings (which would include focus area in the center).
Thus, if you changed the focus area, ISO, WB, etc. for a particular scene, all would reset to the default settings on next power ON.
OP AlainAntoineTurgeon Forum Member • Posts: 54
Thank you very much
Thank you very much. I found the menu to assign the buttons and assigned the Fn3 to "Focus Area Set" and it works perfectly.
I did configure C1, thank you again.
I have more to learn from the camera even if I got it in 2014.
Alain
Thank you very much
It's fine camera. I got mine in 2015. I don't have a large hand, but found an added Fotodiox thumb grip to be very helpful.
Thank you very much
I saw your site, félicitations!.
My mother is from Mexico City and we spent many summer vcations in the sixties at my abuelitos house in San Miguel de Chapultepec near the now famous Roma neighbourhood. The pictures are taken on kodachrome with my Nikon FE at the dia de muertos fiesta in 2000 in front of the Merida (Yucatan) cathedral. So i am a blend of quebecois father, mexican mother and her father german, mexicanized in 1922.
Tanichio en disfraz, dia de muertos, 2000
La muerte y sus charros, Merida, 2000
and I forgot to say my problem is solved by putting off the direct focus area as it was working on C1 but not on the general use like P, S or A.
Ciao
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
My GX7 focus area also used to keep getting stuck in the top right, eventually i found it was something I was accidentally doing. I can't remember if it had an touch control rear screen, but I now never use touch active rear screens!
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
