Does anyone else have an issue with their pictures being not level?
Started 7 months ago | Discussions
Horrgakx
Horrgakx Regular Member • Posts: 387
I use the electronic guide in my R3, but I've noticed that my photos are off by 1 or 2 degrees clockwise most times. So when I edit in Lightroom I have to rotate them anticlockwise by that amount. Has anyone else got this issue?
 Horrgakx's gear list:Horrgakx's gear list
Canon EOS-1D Mark III Canon EOS-1Ds Mark III Canon EOS-1D X Mark II Canon EOS R3 Canon EF 28-300mm f/3.5-5.6L IS USM +3 more
EJ Fudd
EJ Fudd Senior Member • Posts: 2,150
Re: Does anyone else have an issue with their pictures being not level?
When you press the shutter maybe you put to much pressure and causes a 1 degree tilt clockwise. Put camera on a sturdy tripod, level it and use a remote trigger see if its tilted
"The fact is that relatively few photographers ever master their medium. Instead they allow the medium to master them and go on an endless squirrel cage chase from new lens to new paper to new developer to new gadget, never staying with one piece of equipment long enough to learn its full capacities, becoming lost in a maze of technical information that is of little or no use since they don't know what to do with it."
A Great Quote by Edward Weston...
 EJ Fudd's gear list:EJ Fudd's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS 90D Canon EF 400mm f/5.6L USM Canon EF-S 15-85mm f/3.5-5.6 IS USM +18 more
Kharan
Kharan Senior Member • Posts: 2,487
I could swear I had a camera (not a Canon) that did this, and I'm sure it was the IBIS that was improperly calibrated. It was, as you say, a very small amount (1-3 degrees). I tried the following: instead of the spirit level, I used the rule of thirds grid in the display, went to a big plains and put the lower line of the grid over the horizon. I shot a burst with the electronic shutter, trying my best to not move the camera. And indeed, not a single photo came out perfectly level. I then rotated the body slightly in the preferred direction of the tilt, took another burst and, voilá, level photos.
If you gather enough evidence, you could get the R3 fixed by Canon, especially if you're a CPS member.
"Chase the light around the world
I want to look at life
In the available light" - Rush, 'Available Light'
 Kharan's gear list:Kharan's gear list
Panasonic Lumix DMC-L10 Pentax Q Olympus PEN E-P3 Olympus OM-D E-M10 Canon EOS RP +22 more
drsnoopy Senior Member • Posts: 1,216
If you think it's the IBIS, then turning it off should give the answer...
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
JoeSchmoe007 Contributing Member • Posts: 502
I think it is an excellent point, OP didn't specify whether they use a tripod. Without it this is moot conversation, especially for the body as large as R3.
robgendreau Forum Pro • Posts: 10,917
It would be cool for those of use shooting seascapes and similar if there were a shutter setting that waited for the camera being level before opening the shutter. Or moved the sensor to level it, either by using the level or an AF-like detection of horizon.
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
Gam3r01 Contributing Member • Posts: 572
The R7 uses the IBIS to auto level the sensor, like you describe.
 Gam3r01's gear list:Gam3r01's gear list
Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 16mm F2.8 STM
Kharan
Not if it parks tilted. Like it did on my previous camera, I think. Canon's IBIS doesn't have a hard parking position like Nikon's, so it could be different, but I'm guessing it isn't - the whole assembly probably comes with a slight tilt from the factory.
PicPocket Veteran Member • Posts: 5,897
Above description sounds like a miscalibrated assembly. Basically what the camera thinks is level is wrong. IBIS may just be trying to achieve that, so if this is the case, it would need some recalibration
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
Tristimulus Veteran Member • Posts: 9,998
The level is approximate and not spot on.
Some slack is needed for hand held use. If the level is too accurate then hand held use becomes almost impossible.
Pushing the shutter button seems to offset the horizon by a degree or so, at least so with any in camera level I have used regardless of brand.
