Anyone use Op/Tech Mirrorless Sling with M6 ii?
Started 7 months ago | Discussions
dedede Junior Member • Posts: 32
I wanted to see if anyone has had experience using this Op/Tech Mirrorless sling with an M6 ii:
Amazon.com : OP/TECH USA 1601512 Mirrorless Sling (Black) : Electronics
Mirrorless Sling - Neoprene Camera Shoulder Sling | OP/TECH USA (optechusa.com)
I’m looking for a sling strap that is compact, but also comfortable. My heaviest lens is the EF-M 32mm, so the total weight is less than the 2.5 lb maximum for this sling.
The reviews are mostly positive but mixed, with some negative comments about the thinness of the strap and the design.
(There’s also a version for a heavier camera:
Amazon.com : OP/TECH USA Super Classic Sling Strap for Mirrorless and SLR Cameras, Black : Electronics )
Has anyone tried out either one?
Thanks for your thoughts!
Canon EOS M6 II
MAC Forum Pro • Posts: 18,487
Re: Anyone use Op/Tech Mirrorless Sling with M6 ii?
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
Bejersey
Bejersey Forum Pro • Posts: 15,383
R2D2 Forum Pro • Posts: 26,528
MAC wrote:
Amazon.com : OP/TECH USA Super Classic Strap - UNI Loop - Padded Neoprene Neck Strap with Control-Stretch System and Quick Disconnects (Black) : Photographic Equipment Bag Straps : Electronics
I love mine
+1 I’ve used their (classic) straps too for years, and love them. The neoprene really absorbs shock nicely.
I haven’t tried the sling style though. I wouldn’t worry too much about the construction, as your setup is very light.
R2
ps. I should mention that you should be VERY careful how tightly you attach anything to any of the M Series tripod mounts.  The bottom plate can get crushed.
dan the man p Senior Member • Posts: 1,201
I have the classic strap with sling adapter (I hate neck straps). I didn't like how the clips slide along the strap, so I modified it so that it's basically an extra-long regular strap:
Then I 3D printed a base plate for my M50 with a loop to attach another clip on the bottom. When I wear it in sling style, this holds the camera at my side pointing down, and the strap does not get in the way of the LCD or EVF when I lift up the camera for shooting.
It's really comfortable to carry it this way even with a large lens. I also like that I can easily take it off and clip on a wrist strap instead.
Some notes based on my experience:
  • Using the Op-Tech sling strap the way it is designed even with just a single clip is plenty strong enough to carry a EOS M camera without any reason to worry about it falling. However, it will swing and twist around a lot as you walk if you use the single clip.
  • Using both clips on the strap helps, but since they can slide along the strap, they tend to slide together and reduce their effectiveness in preventing the swinging and twisting behavior. They also tend to get in the way of the EVF/LCD/grip depending on how and where you attached the clips.
  • The solution above seems to be the best for me at solving all these problems, but it does need a base plate for best results. This setup is pretty similar to how the [much more expensive] Peak Design slings work.
PS sorry for the IQ of these photos -- my good camera was busy getting photographed -- but hopefully these get the point across.
 dan the man p's gear list:dan the man p's gear list
Sony DSC-RX0 Nikon Z6 Nikon Z 24-70mm F4 Nikon Z 40mm F2
Dareshooter Veteran Member • Posts: 5,842
I’ve used one with an M50 plus and a variety of M lenses  the largest being the 18-150 mm and it was fine . I say was as I no longer use as it as I am not that keen on sling straps so I just use the OEM strap wrapped around my hand or worn bandolier style  when I need both hands free.
nwboater33 Regular Member • Posts: 202
I love mine
+1
I find the wide neoprene strap way more comfortable than the thin OEM ones. The quick disconnects are handy too.
 nwboater33's gear list:nwboater33's gear list
Canon EOS M50 Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Sigma 150-600mm F5-6.3 | C +7 more
OP dedede Junior Member • Posts: 32
Thank you everyone for your great advice - all very helpful!
Ignoring the increased cost, I was wondering if anyone thought there is a design advantage over the Op/Tech models for either the Peak Design Slide LIte or Leash.
Amazon.com : Peak Design Slide Lite Camera Strap Ash (SLL-AS-3) : Electronics
Amazon.com : Peak Design Leash Camera Strap (L-BL-3) : Electronics
