Which Would You Do?
Started 8 months ago | Discussions
grcolts Veteran Member • Posts: 3,911
Which Would You Do?
A while back I mentioned my K50 developed the aperture block failure symptoms. I followed suggestions on how to keep it going and so far that procedure has worked. I am not sure how long it will work so I have decided to either add a lens that will work with the K50's problem or just add a used K3. I like the K70 but after having gone through two K50's with aperture failure I am gun shy on the K70. It might work without a hitch but then again it might fail too. So, just curious, would you go with a K3 or a new lens?
Pentax K-50 Pentax K-70
The Squirrel Mafia
The Squirrel Mafia Senior Member • Posts: 1,017
Re: Which Would You Do?
It all depends on how much you want to spend. KAF4 lenses are pricey. The cheapest one is the DA 55-300mm PLM at about $396 at the moment. It's normally about $450. Then you jump to $1,300 to $1,900 for DA* or DFA*, FF Limited, & other FF KAF4 lenses. There are currently about 6 of them, but only 2 of them are APS-C specific. The other 4 are FF, but you can use them on the K-50.
The K-70 is still a risk, though it seems like there have been less solenoid failures so far. I personally wouldn't bother with one. I'd rather get a used K-3/3II instead. Yes. The image quality in the K-70 is fantastic, but there's always that chance of another solenoid failure later on. I will never buy another Pentax camera that uses a solenoid to control the aperture. I got burned twice with 2 K-50 bodies that were heavily used, but I fixed them myself.
You can always use older aperture type ring lenses, but manually focusing a lens through the viewfinder is pretty hard. If it had a split prism, it would be fairly easy, but if you change the screen, that might throw off the metering.
There is also the KP, though they're selling for too much at the moment. A used K-3/3II would be the cheapest & easiest. Hahaha!
 The Squirrel Mafia's gear list:The Squirrel Mafia's gear list
Pentax K-3 II Pentax smc DA 21mm F3.2 AL Limited Pentax 11-18mm F2.8 Pentax DA* 16-50mm F2.8 ED PLM AW Pentax K-50 +10 more
JeremieB Senior Member • Posts: 2,041
It's also not really usable with lenses having a small maximum aperture.
 JeremieB's gear list:JeremieB's gear list
Pentax K-70 Pentax K-3 Mark III Pentax smc FA 50mm F1.4 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc D-FA 100mm F2.8 Macro WR +9 more
JohnXLondon Regular Member • Posts: 239
K3
 JohnXLondon's gear list:JohnXLondon's gear list
Canon PowerShot S3 IS Fujifilm X20 Panasonic LX100 Pentax K10D Pentax K-3 Mark III
MrB1 Contributing Member • Posts: 605
If you already have several lenses that won't work on an aperture failed K-50, then it would make sense to get a K-3. Even then, it would also be a good idea to get an inexpensive used lens which has an aperture ring, so you can also keep using the K-50. There are many to choose from, including the F and FA series which have auto-focus - see the Pentaxforums lens reviews.  If you can find one, the SMC Pentax-F 35-70 mm is a great little lens.
Philip
RBIV Senior Member • Posts: 1,295
Another vote for the K3, or KP if you can fine one at a reasonable price.
 RBIV's gear list:RBIV's gear list
Pentax K-5 Pentax KP Nikon Z fc Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 40mm F2.8 Limited +3 more
OP grcolts Veteran Member • Posts: 3,911
Yes, I looked at used KP prices and they are too high right now. Used K3's are much more realistic. Thank you for your input. It is appreciated.
JohnXLondon wrote:
K3
That is what I am leaning towards. Thanks.
Philip
Your post makes sense. Used lens are pretty cheap and used K3's are reasonable too. I think that is probably what I am going to do. Thanks for your input.
I checked used KP prices and right now they seem too high. I am leaning towards a used K3. Thanks for your input.
The Squirrel Mafia
Yes indeed! At one point the KP was down to about +-$696 or so during one of the Black Friday sales. Can't remember if it was in 2019 or 2020. I refuse to pay more than that for a used KP. I also refuse to pay more than $730 for a used K-3II, since that was about the lowest price B&H/Adorama/Amazon had sold it for new.
There is also the filtered K-5II & unfiltered K-5IIs, though they're not KAF4 compatible & don't have focus peaking in live view. They do put out some very nice images, especially the K-5IIs without the AA filter. They range from about $250 to $450 or so on eBay.
kypfer Contributing Member • Posts: 985
I'm probably the last person you want to ask, so … my K-3iii has a problem which Ricoh UK insist I need to speak to their repair agent about, who in turn insists they're waiting for information from Ricoh UK … it also suffers from the intermittent lock-up problem which requires the camera to be switched off and then on again to restart it. Nevertheless, it continues to take pictures most of the time so I'm not too worried, and I'll probably never want to sell it, but it's certainly not as reliable as either my K-70 or my KP, neither of which have any major issues, though I just found out over the last few days that if I try to use the wi-fi on the KP to make videos, the camera overheats after a few minutes and drops the connection!
In the meantime, my K-70 is totally reliable after 25k exposures
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
PentUp
PentUp Veteran Member • Posts: 4,188
K5II
No text.
 PentUp's gear list:PentUp's gear list
Panasonic Lumix DMC-FZ300 Canon G7 X II Pentax K-x Pentax K-5 II Pentax K-50 +12 more
yardcoyote Forum Pro • Posts: 15,754
If you don't want to move to a K3, you could move sideways into a K-5ii.
Instagram: @yardcoyote
 yardcoyote's gear list:yardcoyote's gear list
Fujifilm X10 Fujifilm X100T Fujifilm X-Pro1 Pentax K-5 IIs Fujifilm X-M1 +20 more
Interesting camera experiences. I would love to just bite the bullet and get the K70 as I love the articulating screen other Pentax's don't.  I am just so darn afraid I will get a third Pentax that has that stupid aperture block issue.  I will have to think long and hard. Thanks for your input.
I will look at the K5ii too. Thanks for your input.
jimrpdx
jimrpdx Veteran Member • Posts: 3,954
I've recently added catch-in focus to my Ks-2 routine, with good results. No guarantee that the AF module won't need adjustment for a specific lens, but my M85/2 seems to perform well this way.
I do own the white solenoid for future surgery, but for now I'm having fun
 jimrpdx's gear list:jimrpdx's gear list
Olympus E-M1 Sony a7 II Pentax K-S2 Pentax 18-50mm F4.5-5.6 Panasonic 12-60mm F3.5-5.6 OIS +2 more
wed7 Regular Member • Posts: 312
This is similar to my two K-30's. Now they are both glorified paper weight. Should have kept my K-5ii's instead but I then opted for the similarity/simplicity in controls.
 wed7's gear list:wed7's gear list
Fujifilm X100F
Yep, I hear you. I just have just kept my old PZ1P film camera.
