What Is This?
Started 8 months ago | Discussions
John Gellings
John Gellings Veteran Member • Posts: 9,743
Re: What Is This?
5
Shooters on My Squad wrote:
John Gellings wrote:
I guess this is dpreview’s version of a code to crack? Too little info from a bad crop and a hesitant OP to provide anything makes this ridiculous to try to answer.
This is a false statement. Neither am I trying people to "crack a code", nor hiding information that I can share. So far I answered every question as thoroughly as possible.
If you find this ridiculous to answer, why do you even answer, and not just ignore?
I am just trying to get better photos, and I thought that many visitors here have a similar goal in mind. It looks like I might be wrong.
There were already some people in this thread that pointed me to the right direction and were helpful. I will investigate further, and hopefully find an answer.
I just see no point in your comment Mr. John Gellings.
I’m sorry you feel that way, but you have no idea what this looks like from our perspective. I can’t imagine why you’d focus on this one detail. Is the entire photo that great or are you just getting caught up in pixel peeping. Sometimes out of focus areas just do weird things depending on shapes and light, how you expose, the aperture used etc. Unless this is happening over and over in all photos you are taking, forget about it and move on.
https://www.johngellings.com
Instagram = @johngellings0
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
Sebastian Cohen Regular Member • Posts: 228
Re: What Is This?
Recently I got a X-Pro3, and I have taken some lovely snapshots so far. What I discovered though, are some obvious quality issues that I do not see on the X-T4 body.
Here is just one example:
Smeary, wormy & messy outline around the hand, but why?
Where does this smeary, wormy outline come from, and how can I avoid it to take better photos?
Worms usually are jpg compression artefacts…it could be your camera got “confused” and messed up ie a bug.
Perhaps also picking up evaporating moisture at the same time?
A sensor BSOD?
I do have a bunch of “weird” photos that can’t be explained and I keep them in a separate album.
OP Shooters on My Squad Regular Member • Posts: 391
Re: What Is This?
a_c_skinner wrote:
The 27/2.8 is not mediocre, mine is optically more or less the same as my 16-55. Whatever the cause I doubt it is that. I look forward to seeing more images which can be posted complete that show the effect. I'd factory reset before taking more to be sure it isn't the in camera processing.
I am not sure if my posts are getting ignored, or if this is a joke.
If the issue is already present in the RAW files, how would a factory reset help, or how could camera processing (on RAW files?) manipulate the result?
There are some manufacturers that apply e. g. noise reduction or anti-aliasing to RAW files which you cannot turn off, but I am not aware of any other, heavier processing that would apply here.
So why do you still think this might be “camera processing” or some settings gone rogue?
 Shooters on My Squad's gear list:Shooters on My Squad's gear list
Canon PowerShot G5 Ricoh GR III Olympus TG-6 Canon G5 X II Ricoh GR IIIx +41 more
5teveO Forum Member • Posts: 97
Re: What Is This?
I guess the question is - what software are you viewing the 'Raw' files in? All software that can read the raw files processes the files to make them viewable, LR for example applies the film sim, sharpening etc etc by default. Darktable does, as does C1, DXo etc.. otherwise you would be looking at a colourless mess on screen.
Is it possible you could let us know what the screen capture was from (eg LR etc) and just check if any silly value has auto applied to the sharpening etc..
Steve
Erik Baumgartner Senior Member • Posts: 6,894
Re: What Is This?
8
If this is the only instance of this happening, don't worry about it. If it's an ongoing problem, post a full-size image you can share (preferably the RAW). You aren't giving us much to go on here. It could be a lens rendering issue, a motion artifact. a RAW demosaicing artifact, an alignment artifact (if it's an HDR etc.), it could be an electronic shutter artifact too. Do you have a RAW and a Jpeg to compare?  You aren't making it easy.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Re: What Is This?
78_Anthony wrote:
https://youtu.be/4ex72Ssdd1o
Watch the above and scroll to around 6 minutes.
Is this what you are seeing?
Anthony
Thanks for sharing the link! At first I thought that my photo may be just the worst case of the issue presented there, but then I checked the photos from that particular day again, and I do not see these issues at all.
The rendering & IQ of this lens is generally good in my subjective opinion. It seems like I can isolate this to be the rendering between the two OOF planes (and I hope this is not about “X-Trans”, which is my fear, but why should it when both bodies are very similar except their user interface, and I haven’t seen this issue on the X-T4).
Re: What Is This?
This seems to be indeed a rare issue. What I have shown in the crop here was the worst case, and similar but less visible issues are present in about a handful of shots (out of about 50). This happens mostly on photos with OOF foliage, and my assumption (thanks to the helpful feedback in this thread so far) is that this happens when something else in front of the focused subject is in the image. I will check that!
I wouldn’t worry so much, if a viewer wouldn’t have pointed this out to me. This was quite embarrassing.
I realize it is not much to work with, but I currently gave every information I could without violating laws. I will try to isolate this issue with some specific test shots. I now also realize how RAW demosaicing could play a role here. Thanks.
Robmas4229
Robmas4229 Senior Member • Posts: 1,272
Re: What Is This?
Haha, I hope it's not mediocre, I just bought one. Mine seems fine on my XE3 and XT30-II.
 Robmas4229's gear list:Robmas4229's gear list
Fujifilm X-E3 Fujifilm X-T3 Fujifilm X-T30 II Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +7 more
RustyRus Senior Member • Posts: 1,696
Re: What Is This?
Blur the face man...Done and done.
 RustyRus's gear list:RustyRus's gear list
Ricoh GR III Leica Q2 Fujifilm X100V Fujifilm X-Pro3 Leica M11 +1 more
a_c_skinner Forum Pro • Posts: 13,047
Re: What Is This?
Sorry, yes.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Re: What Is This?
It is excellent.
Andrew Skinner
FujiShooterCY Regular Member • Posts: 445
Let me guess... this is produced by Adobe!
Looks like
  • there was a RAF processed with some Adobe product at default (actually, destructive) settings,
  • also it was over-sharpened with the dumb USM algorithm,
  • and crop was made afterwards from an OOF area somewhere around the border/corner of the image.
To avoid this kind of discrepancies I'd suggest shooting in "RAW + JPEG Fine" mode, so that in case Adobe destroys the IQ after processing the RAF again, at least you still have the reference OOC JPEG to compare your post-processing results to.
Re: What Is This?
You realize I cannot win this one. When I edit the image I will have to upload a JPEG file, then everybody will want to see the RAW file again, because of “processing” issues, although the problem is already present in unprocessed RAW files with the history stack at the very bottom in Darktable where exposure, color balance, and other things look like crap, because absolutely no processing was applied, but the smeary, wormy pattern is still present. Then I will be in the same position again.
I want to make test shots with this lens on the X-Pro3 & X-T4 as my current assumption is that this is just how the OOF rendering of different planes looks like on this lens where planes cross on the Z-axis. I did buy this lens primarily for its size & focal length, and accepted that I already have other lenses with better optical parameters. I can accept this specific mediocre behavior of the lens, if my assumption is correct, because otherwise it is pretty fine. I am excited about some photos I took with this lens. In the end I just want to know in order to avoid problematic compositions (which aren’t that many to begin with), and have more keepers.
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Re: Let me guess... this is produced by Adobe!
FujiShooterCY wrote:
Looks like
The raw has an embedded 13MP jpeg which should be plenty detailed enough for the comparison
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
In my humble, personal, highly biased opinion, I'd prefer to compare apples to apples - namely, the pictures of the identical resolution, from the same source RAF. Also - being honest - I should confess that I hadn't ever tried to extract JPG previews from RAFs and I have no idea how to do this.
darktable? if yes, which version is it?
After upgrading to darktable 4.0 a few days ago, with its default settings I am observing a few unexpected weird problematic issues, never seen in the old version before.
This may be either sub-optimal default settings for X-Trans or the learning curve for the new version intervened here.
BTW whatever you see in darktable with an "empty" history stack is actually a product of the default history stack applied. The first obvious problem I've met in 4.0 is the misfit between the "raw black/white point" module default preset and the "highlight reconstruction" module default preset when importing X-Trans RAF. Both modules are applied by default at import, with their default preset settings.
Kameratrollet Senior Member • Posts: 1,106
Re: What Is This?
Choose Pass through in Black/White point module, turn off White balance module, debug mode in Input color profile, turn off Highlight recover module, debug mode in Demosaicing module.
That should be a better start for "unprocessed" raw. And that is also why everyone wants you to upload a raw sample.
left eye Veteran Member • Posts: 3,038
Re: What Is This?
Light diffracting around the edge of an object causing lensing. Physics, nothing in particular to a camera or lens.
