What Is This?
Started 8 months ago | Discussions
Shooters on My Squad Regular Member • Posts: 391
What Is This?
Recently I got a X-Pro3, and I have taken some lovely snapshots so far. What I discovered though, are some obvious quality issues that I do not see on the X-T4 body.
Here is just one example:
Smeary, wormy & messy outline around the hand, but why?
Where does this smeary, wormy outline come from, and how can I avoid it to take better photos?
 Shooters on My Squad's gear list:Shooters on My Squad's gear list
Canon PowerShot G5 Ricoh GR III Olympus TG-6 Canon G5 X II Ricoh GR IIIx +41 more
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Re: What Is This?
Probably your processing - can you post the original?
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
OP Shooters on My Squad Regular Member • Posts: 391
Re: What Is This?
Unfortunately I cannot post the original image due to privacy reasons. The artifacts in the RAW file on a bigger screen look identical, so I don’t see how any EXIF information might lead to a better understanding of the underlying issue.
If this is the processing, this would mean it is basically happening in-camera before the RAW file gets written, so that I cannot influence the behavior?
Re: What Is This?
Just in case it might help: The photo was taken on the X-Pro3 with the XF27mmF2.8 lens at f/4.0 with the shutter speed at 1/250, ISO 320, and EC -0.33.
a_c_skinner Forum Pro • Posts: 13,047
Re: What Is This?
5
Perhaps you can duplicate the issue in some more images that do not show the problem because I cannot work out the image you posted.
A whole SOOC JPG with the EXIF data will help, ideally more than one showing the problem.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Re: What Is This?
The foliage in the background is far away. At the right side is a person + left hand standing near the camera.
The focus distance / subject is somewhere between the person & foliage (cropped away), so both are out-of-focus areas, and this is exactly where this smeary, wormy artifacts appear.
Is this maybe a lens construction issue?
Greybeard2017
Re: What Is This?
There just isn't enough information here for us to diagnose remotely - if you think its a lens issue do you have a different one to try (same settings - same subject)?
Have you tried exactly the same settings and lens and subject on X-T4 and X-Pro3?
io_bg
io_bg Senior Member • Posts: 1,548
Re: What Is This?
6
Does the same happen with your X-T4?
To me, it looks like that's the way the lens renders OOF backgrounds.
Best,
Yoan
 io_bg's gear list:io_bg's gear list
Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +4 more
Re: What Is This?
5
I simply cannot see that in the attached image.
To my untutored mind it looks as if some processing has been applied too strongly.  I'd have guessed far too much sharpening but I still cannot make out the original image.  If you need help then more images that show the problem and you are able to share might help cleverer people than me.
Andrew Skinner
5teveO Forum Member • Posts: 97
Re: What Is This?
Can you at least share what post processing you did? Including what software, what sharpening etc.. I'd hazard a guess at Lightroom.. but may get shot for saying so
Steve
John Gellings
John Gellings Veteran Member • Posts: 9,743
Re: What Is This?
19
I guess this is dpreview’s version of a code to crack?  Too little info from a bad crop and a hesitant OP to provide anything makes this ridiculous to try to answer.
https://www.johngellings.com
Instagram = @johngellings0
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
Re: What Is This?
I never noticed it on the X-T4, but I was using the camera primarily with the 16-55mm.
To me the most plausible explanation so far is the lens construction itself. I will try to use the pancake on the X-T4 body, which then should lead to similar rendering issues for out-of-focus areas.
Thanks for your feedback!
Re: What Is This?
As I already said the issues in the RAW file look the same, and there is no (known) processing applied at this point. I thought I already made this clear enough. I have taken a couple of shots that day that show similar issues, but on this photo it is the strongest.
This leaves either the body or the lens as the root cause, and my suspicion is the lens itself, as it is known to be of a mediocre quality. I will put the 16-55mm on the X-Pro3, and I will also put the 27mm on the X-T4. I hope this will clarify my issues.
Re: What Is This?
This is a false statement. Neither am I trying people to "crack a code", nor hiding information that I can share. So far I answered every question as thoroughly as possible.
If you find this ridiculous to answer, why do you even answer, and not just ignore?
I am just trying to get better photos, and I thought that many visitors here have a similar goal in mind. It looks like I might be wrong.
There were already some people in this thread that pointed me to the right direction and were helpful. I will investigate further, and hopefully find an answer.
I just see no point in your comment Mr. John Gellings.
Greybeard2017
Re: What Is This?
6
Don't be offended - everyone has pointed out that you just aren't supplying enough information for remote diagnosis.
pifilos Regular Member • Posts: 343
Re: What Is This?
Just curious.  Assuming the subject is in focus does it have the same issue around its edges ( i guess it is the face) but not so prominent ?  Also do you remember what shutter type was used ? Try both types and see how it works.
https://www.instagram.com/filippos.drylerakis/
flickr.com/photos/194737069@N06
 pifilos's gear list:pifilos's gear list
Fujifilm X-T2 Fujifilm X-T20 Fujifilm 50-230mm II Fujifilm XF 10-24mm F4 R OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
Re: What Is This?
The 27/2.8 is not mediocre, mine is optically more or less the same as my 16-55.  Whatever the cause I doubt it is that.  I look forward to seeing more images which can be posted complete that show the effect.  I'd factory reset before taking more to be sure it isn't the in camera processing.
Andrew Skinner
78_Anthony Regular Member • Posts: 112
Re: What Is This?
https://youtu.be/4ex72Ssdd1o
Watch the above and scroll to around 6 minutes.
Is this what you are seeing?
Anthony
Morris0
Morris0 Forum Pro • Posts: 32,181
It is an out of focus photo -NT
No text.
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Re: What Is This?
Nope, the subject is in focus and the edges are crisp & clear. I would even go that far to say that the IQ is great there.
I guess that the issue is present in areas where the OOF rendering in front of the focused subject “touches” the OOF rendering behind the focused subject. I will try to take some boring shots with similar compositions to further analyze the behavior.
ECFS. Thanks for the hint, I will try this out, too.
