EF 70-200 F4L IS 1st gen
Started 8 months ago | Discussions
SteveHU89 Regular Member • Posts: 119
How all this started. Long story short: bought the lens used many years ago, it's been mostly sitting in its Canon pouch for years. Finally upgraded to FF camera and noticed that lens not always focuses accurately. I believed that camera and lens need to be focus calibrated to each other, so I sent it to Canon service center.
Turns out camera is fine and the lens needs "zoom mechanism replaced" (quote from service person). They quoted a price of 400 euros for this. My jaw hit the floor. I love the lens and its output, but does it worth repairing it for 90% of its current price on the used market? How much could I sell it for? I'm completely devastated.
 SteveHU89's gear list:SteveHU89's gear list
Canon EOS 6D Canon EF 70-200mm F4L IS USM Canon EF 35mm F2 IS USM Canon EF 50mm F1.8 STM
jcr67
jcr67 Senior Member • Posts: 1,602
Re: EF 70-200 F4L IS 1st gen
I had the 70-200 F4L IS version 1 and had the auto focus issue which is fairly common with this lens. Auto focus and manual focus doesn't work when lens is pointed up or down. I had to pay to have the USM system replaced. It cost $300 for the repair and I went ahead and had it done, here's why. I decided even though the resale value is pretty low now, the image quality from the lens was worth $300 as opposed to the lens being worth nothing. I made that decision based on the fact that I may never recoup that cost. So if I were you, I would make the decision to repair based on whether or not I will use the lens, not on resale value.
P.S.
I recently traded the lens through MPB and they gave me $425 credit for it. (MPB was informed of repair, I included invoice for repair work done.) With this said, I would still not count on recouping that cost.
 jcr67's gear list:jcr67's gear list
Panasonic Lumix DMC-TS5 Olympus OM-D E-M10 Canon EOS R6 Canon EOS R7 Canon EF 85mm F1.8 USM +19 more
OP SteveHU89 Regular Member • Posts: 119
P.S.
I agree, at least that the sentimental value of the lens is priceless. When it decided to work and focus properly on subject, I got breathtaking results. Basically if I couldn't use this lens, then there would be no point for me to use FF as this is the lens I wanted to use like 99% of the time.
But I have to wonder if we are talking about the same issue ("zoom mechanism replacemen")? And if I were to pay this huge price, then would the problem or any other pricey problem come up in the future? Because if the answer is no, then I would consider paying for repair. If the answer is yes, then a sad goodbye to this lens.
Busleung New Member • Posts: 18
I repaired my 70-200 f4 twice with the same problem of being not able ot AF or even MF. Paid twice 350USD to Canon. For replacement of barrels, the same problems happened again and again. One year after 2nd repair, problem shown up again. Finally switch to 70-300L several years before switched to RF now. Honestly I think that is the only Canon lens I owned such unreliable.
 Busleung's gear list:Busleung's gear list
Canon EOS R5
jcr67
P.S.
It may be possible it is the same issue, my repair was not done through Canon and maybe the shop just used different terminology. As for the future durability, not sure. I remember reading somewhere (maybe here) that Canon revised the part that was failing and it should not happen again, but I can't verify that. If it were me and I thought I would get enough use from the lens, I would pay $400.
jcr67
Re: Busleung...
Now after reading that you had the issue repeatedly I would definitely not pay for the repair, I guess the rumors I read about a fix were false. Also a coincidence, I traded the lens towards a Canon 70-300L.
Re: Busleung...
This is depressing to say the least...
neilt3
neilt3 Veteran Member • Posts: 3,011
It's all about statistics
Mine works great and has never had a repair.
If the the lens was so prone to failure and repair also failed frequently, it would be common knowledge.
First I've heard .
So yes , some lenses will fail , some repairs will fail .
It's a statistical fact for anything.
Type of use , handling and storage play a bigger part on how long an item lasts .
A little bits luck of the draw .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
jcr67
Re: It's all about statistics
First I've heard .
Not sure how common it is, but it is a known issue with this lens. I am including a link to a video that shows the issue I am referring to.
https://www.youtube.com/watch?v=nIl5a1fT8Ow
Little update: Canon service explained this "zoom mechanism replacement" issue a bit clearer. So the problem manifests itself with sometimes front- or back focusing, rarely nails the focus on subject. The whole internal of the lens needs to be replaced. As to why this would happen, the service employee replied confidently that the lens has been dropped before.
I'm going to sell my aps-c gear to fund the repair cost. Drastic step, but those who used the 70-200 F4L IS before and saw the output will understand. By the way, the lens always looked pristine since I bought it from ebay. The owner must have dropped it in its pouch or camera bag etc. as there is no sign of damage on the outside. Be very careful when buying used and don't be fooled by the exterior appearance.
BlueRay2 Forum Pro • Posts: 14,816
P.S.
i had this lens for about 6 years without any issue and i took it overseas with me for 5 years, taking amazing photos. this lens is one of my all time best one. that one fluorite element in it, makes a huge difference.
as far as you predicament is concerned, i would ask myself: can i purchase another one for $400? if no, i'd spend the money on it! hope this answers your question somewhat.
good luck.
Unexamined world isn't worth living in. "Socrates"
GavanM New Member • Posts: 19
I'd get this lens repaired if it were me. Although I don't actually use mine a lot, it's still one of the sharpest zoom lenses i've ever used.
I don't know if that's common or I was just lucky enough to get a good copy. I've owned mine since about 2007 and had no issues.
Nick5
Nick5 Senior Member • Posts: 1,664
I bought my 70-200 f/4 L IS Version 1 brand new in 2009. Still works to this day. I did buy the 70-200 f/4 L IS Mark II in 2019 for a trip to Greece. Although the Version 1 hasn’t seen much action lately, it’s too good to let go.
My Greek Trilogy just returned from Europe on Sunday, the 16-35 f/4 LIS, 24-70 f/4 L IS and the 70-200 f/4 L IS Mark II.
Love the f/4’s for reduced weight while still maintaining great image quality.
 Nick5's gear list:Nick5's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon TS-E 24mm f/3.5L II +8 more
by the way, did you notice any IQ differences between mk1/mk2 of 70-200 f4 IS? from what i hear the owners, there is no difference in IQ except for the IS.
