Batteries swelling!
Started 8 months ago | Discussions
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Batteries swelling!
I report this as it may be of interest to some:
I have all my m43 cameras since 2009 and up until now have never had any problems with aftermarket batteries for these.cameras: G1, GX7, Gx8, Em1-Mk2. (And a Sony rx100 MK1)
They have always held charge and provided as much power as original batteries, however recently I have noticed something strange...
After getting the Em1-Mk2 except for gx8 I rarely used the others and after a few years their batteries went flat.
After recharging them about a year ago I noticed the aftermarket rx100 battery had swollen a lot and would no longer fit (it was at least 9 yes old). The genuine Panasonic hasn't swollen - yet.
A year later one of the aftermarket GX7 batteries is refusing to charge, but at £7 for 8 years use that's okay.
And last night I went to pop a 4 year old aftermarket battery which I had let go completely flat into the gx8 and noticed the fit was now a bit snugger than it used to be, but has charged fully, so I am wondering whether to bin that one also, even though it still works!
I haven't checked all my em1-mk2 batteries yet, but boy have they had a hammering over the last 5 years!
No genuine batteries have swollen yet!
Note. In use I don't favour any battery when I go shooting, I just grab any out of the drawer.
I draw the conclusion that aftermarket batteries are really good, as long as you don't leave them flat for very long periods of time, in fact maybe I shouldn't ever leave any li-on go flat?
What are other people's findings and routine?
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Sony SLT-A77 Olympus E-M1 II Panasonic Lumix DMC-G1 +1 more
Olympus E-M1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 Sony Cyber-shot DSC-RX10 Sony RX1 Sony RX100
jalywol
jalywol Forum Pro • Posts: 12,301
Re: Batteries swelling!
My OEM (Panasonic) batteries are all still good.  My GM5 aftermarket batteries, purchased in 2016, both started getting snug this year, so I replaced them with new aftermarket ones.  No problem with my similar vintage aftermarket GX8 batts yet, though
Had a cheap tcl smartphone have its battery get big enough to pop the back off the phone after about a year and a half.  That was .. interesting.
It happens.
-J
uniball Veteran Member • Posts: 3,075
I go through this every few years. Like you, 3rd party batteries only. I toss mine at the first sign of swelling. I’m not concerned about leakage, more about getting one out of the camera if it decides to swell more while inserted. Been in that situation, don’t want to go back.
Panasonic OEM batteries are quite cost effective. They’re all I now buy.
Mud Flap Junior Member • Posts: 36
I only use genuine OEM batteries for safety. Chargeing a swollen battery may cause it to catch fire and burn you house down, yes it has happened to some people.
I also never charge any Lipo unattended.
We left a camera to charge overnight but the battery exploded - our house burned down & we've been left with nothing | The Sun
I also never charge a battery in the camera always outside, and when storing my camera I remove the battery and store it at a storage charge level of around 80%.
Wu Jiaqiu
Wu Jiaqiu Forum Pro • Posts: 29,319
got a couple of cameras that only have third party batteries, never had a problem, one of the batteries is now 7 years old as well
the computer says no
 Wu Jiaqiu's gear list:Wu Jiaqiu's gear list
Fujifilm FinePix X100 Nikon 1 V1 Nikon D2Xs Nikon 1 J3 Nikon AF-S Nikkor 300mm f/4D ED-IF +3 more
Samuel Dilworth
Samuel Dilworth Senior Member • Posts: 1,391
8
That does not surprise me.
The genuine batteries have load-balancing circuitry that is seldom found in third-party batteries (= much longer lifespan in charge cycles before the cells are destroyed).
In the Olympus case – not sure about Panasonic – they also use flat rather than generic cylindrical cells to better fill the container (= higher capacity when new, whatever the claimed capacities).
And they have a special expansion zone (a layer of compressible foam) so that swelling cells won’t cause a swelling battery (= battery lasts even longer).
Have a look at this:
https://pen-and-tell.de/2018/08/akku-schlachthaus-blh-1/
And this PDF by the same guy:
https://olye.fotografierer.com/olye/download/olyep/olyep201802.pdf
The pictures tell the story even if you don’t understand the text.
I buy only genuine Olympus or Panasonic batteries. Two per camera (so one extra battery plus the one that came with the camera). That adds about 5% to the cost of each camera.
I store these two batteries around half-charged when possible, and almost always above about 20% and below about 80% charge.
When I plan intensive use (e.g. a day trip), I charge both batteries to about 80%. I do this by setting a timer on my phone to remove them from the charger, the time having been established from the user manual’s full-charge time, trial and error, and some knowledge of how these things work (e.g. much slower charge above 80%).
When the battery in the camera depletes to the earliest available low-battery warning (and not further), I switch it out for my other battery.
Under this regime the batteries last for many years without noticeable deterioration, give me as much power as I need for even the longest day of shooting, and cost less over the camera life than buying multiple third-party batteries of worse design and manufacturing quality. Plus I support the manufacturer, avoid the small risk of a lithium fire, and feel warm and fuzzy about my batteries.
But I understand these benefits without identifiable downside are not for everyone. Hence the popularity of third-party batteries.
Tony Rogers Senior Member • Posts: 2,201
The worst thing you can do to a multi-cell lithium battery is to discharge it to a very low level. When a pack contains multiple cells, they inevitably have slightly different capacities. The camera may only measure the charge state of the pack by the total voltage, so when one cell is completely discharged, the voltage of the other cell(s) may fool the camera into thinking the pack still has some charge. Continued use leads to bad outcomes when current is pushed through the empty cell.
When a cell is damaged, the usual outcome is that its capacity is further reduced which compounds the problem. The difference in cell capacity gets larger.
If the cells are unbalanced in that they have slightly different voltages, more problems occur during charging. If there are two cells in series in a 7.2V pack and one cell starts at say 3.2V and the other 3.4V, the higher voltage cell will become fully charged before the low voltage cell. Let's say they get to 3.4V and 3.6V respectively. The pack voltage is only 7.0V so the charger may keep right on going leading to the higher voltage cell being over-charged. It is a very dangerous thing to overcharge lithium based cells!
(BTW The voltage written on lithium packs actually corresponds to the voltage when the pack is mostly discharged. Lithium cells are generally 4.0-4.2 volts when charged).
When a cell is over-charged, it can produce gases which cause the cell to expand. Once this process starts, it can continue even when not charging.
So how do manufacturers avoid this problem? There are a few things you can do. First, match cells as close as possible so that they have the same capacities. Second, program the charger and the camera so that the battery is never fully discharged and conservatively charged. Thirdly, add electronics to the charger to monitor each individual cell during charging to ensure that no cell is overcharged and bleed charge from the higher voltage cells to balance them.
I am not aware of whether camera batteries and/or chargers do balanced charging. Probably not given the cost. Larger, expensive batteries for high voltage power tools from better manufacturers often do include balancers.
So, returning to your third-party batteries. The manufacturers may not have taken as much care to match the cells in the pack and the pack may have charge/discharge profile characteristics that mean measures programmed into the firmware of the camera and charger are ineffective.
If you get a severe battery malfunction, the battery may become stuck in the camera (possibly destroying the camera) or worse, cause a fire (which is unusual these days). Consequently, since cameras are expensive pieces of equipment, I always buy original batteries.
 Tony Rogers's gear list:Tony Rogers's gear list
Sony a1 Sony FE 200-600 F5.6-6.3 Sony FE 85mm F1.8 Sony FE 50mm F1.8 70-200mm F2.8 GM II +1 more
Michael Houston Forum Member • Posts: 93
13
This whole thread illustrates why I am not a proponent of the current charge-it-in-the camera trend. I like to charge batteries with a charger so that I can look at them and also know what they feel like when they slide in and out of the camera.
brentbrent Veteran Member • Posts: 5,766
Aftermarket batteries are so cheap, and you got four years of use out of this one, so absolutely DO recycle (not trash) this one now.   I would never continue to use a battery that has started to swell.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
Adrian Harris
OP Adrian Harris Veteran Member • Posts: 7,708
Thanks everyone...
Until reading all your comments I was still tempted to re-use it. I will now be taking it for recycling.
Ranlee Senior Member • Posts: 2,258
I've been using Panasonic cameras for about 10 years - the oldest I still have being the GX8 and GM5.  In that time I have never had an original Panasonic battery go bad.  Over the years I have also tried aftermarket batteries of numerous brands (I don't recall their brand names anymore) all of which have failed within about 2-3 years.  I no longer buy aftermarket batteries.
Randy
 Ranlee's gear list:Ranlee's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix DMC-GM5 Panasonic Lumix DC-S5II Panasonic Leica 200mm F2.8 +10 more
Digital Dick Senior Member • Posts: 2,379
I've had several third party swell for my E-M5 I and II cameras (BLN-1) but only one of the original Olympus BLN-1 started to swell after about 6 years.
How do people get a swelled battery out of the camera?  I had to glue a wire to the bottom of the battery to pull it out.
Dick
 Digital Dick's gear list:Digital Dick's gear list
Olympus OM-D E-M5 Olympus E-M5 II
nearly-an-old-codger
nearly-an-old-codger Veteran Member • Posts: 5,120
Re: Batteries swelling! Dell computer take on this
https://www.dell.com/support/kbdoc/en-us/000128491/swollen-battery-information-and-guidance
and from our mates in australia
https://www.batteryworld.com.au/news/expert-advice/2020/i-have-a-swollen-battery-what-now
which is why i use oem batteries and chargers and as someone mentioned above charge outside the camera
Brian
 nearly-an-old-codger's gear list:nearly-an-old-codger's gear list
Ricoh GR III Leica Q2 Monochrom OM-1 Panasonic Leica 100-400mm F4.0-6.3 ASPH Olympus 12-100mm F4.0 +10 more
maggiemole Senior Member • Posts: 1,988
Dick
I used to paint with oils and acrylics, so I have a jar of palette knives, most of which are very thin blades. I managed to slide one down the side of the swollen battery and  slight twist and pull got a bit of movement. It was just enough to let me grip and pull by hand. I never want to be doing that again, I had no idea what was happening to the camera socket and contacts.
 maggiemole's gear list:maggiemole's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DC-GX9 Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Panasonic 14-140mm F3.5-5.6 II +8 more
MOD Tom Caldwell Forum Pro • Posts: 46,352
Re: Battery case material?
I have a few GM bodies so have a clutch of oem batteries - the originals have never given any issues despite some being 8-9 years in service.  I usually buy a number of after market batteries for each new type of battery that I need.
Have had varying luck with after market batteries for the GM series and also those that fit the E-M1.  Swelling is an issue and there might be something it the the thought that batteries that are allowed to go flat and left for a time might generate enough heat to swell their contents and distort their cases.  In this area I think that the oem batteries for the GM series have a more rigid case than any of the clone batteries.  In fact it seems to me that most if not all the clone batteries come out of the same factory or at least use a common case made of a plastic type that seems more readily distorted by heat.
On the other hand the GX7-GX9 series clone batteries and those that fit the G9 seem less susceptible to swelling - as were my Ricoh battery clones, Nex battery clones, Canon dslr battery clones and NX10 battery clones. Only the GX7-9 batteries have had any issue at all.
Tom Caldwell
PhotoMac503 Senior Member • Posts: 1,057
My OEMs never swell
Yes, aftermarket batteries are cheap but this thread illustrates the risk you take.
Also, if they are not reliable for as long as OEM you may wind up buying more figuring "they're cheap."
However, you end up carrying more weight and have more to change/manage. Don't you use m43 to save weight?
If a NonOEM battery ruins your camera you're going to get finger pointing. If a Panasonic battery ruins your Panasonic camera, you know who to contact.
Batteries also take a tremendous toll on the environment, both their manufacturing and disposal. So the fewer you buy and the longer they last the less damage will come to the environment.  And if you're a nature/wildlife/landscape photographer, you should care about the environment.
I buy OEM exclusively, and carry a minimum. I don't need to carry a lot because I trust OEM reliability. I also set up my camera to minimize power consumption. And I don't turn on my camera at all until I have finished previsualization. That also means I have less shots to delete. No spray and pray here!
I also letter each battery (A, B,) and use them in sequence so they are all used a similar amount. So A is never used twice while B goes unused. i do this with a felt pen as soon as I open the box.
 PhotoMac503's gear list:PhotoMac503's gear list
Olympus E-M1 II Olympus 100-400mm F5.0-6.3 IS Olympus 12-100mm F4.0 +1 more
jxh Regular Member • Posts: 268
While OEMs tend to be a bit more reliable, they too can swell and fail. Fortunately for cameras, you can pull the failing ones out of circulation.
My wife has had several Samsung premium phones in a row fail with badly swollen batteries. She carries insurance and the company didn't even question... battery swell, authorized phone replacement. A few years ago the company I worked for had a substantial number of battery failures in salesman's Microsoft notebooks. It was a mess--battery replacement required serious disassembly.
I agree 100 percent about charging outside the camera. That's the most likely time for them to overheat and fail.
Impulses Forum Pro • Posts: 10,039
You should in fact not let any batteries of this kind go flat, nor store them fully topped off, 1/2 change or 2/3 charge should prolong their life better. It's a pain to be really on point with that, so I just make some calendar notes to recharge as much of my little used stuff as possible every once in a while, and if I get a chance (if I'm not gonna be using it) I'll pull it before full charge or use the battery some after it's charged but before storing it... That's the idea anyway, sometimes I'm lazy.
First party batteries not swelling could come down to something as simple as better plastic/construction, but it's likely they're also higher grade batteries (Panasonic is a huge manufacturer of batteries after all). My original GM1 battery is still working fine w/o swelling, tho I haven't really bothered to check how much of a charge it's actually holding. All batteries will lose some capacity over time after and/or a given number of discharge cycles, there's no avoiding that.
I've bought 3rd party batteries a few times in the past, mostly I stick to OEM these days, I'd toss any battery with signs of swelling immediately. Using it will get it warmer and then all bets are off... I do use 3rd party chargers (just cause OEM don't make USB chargers and those are very useful) and even charge in camera at times (handy in a pinch, when traveling by car specially, I don't make a habit out of it as it's slower anyway), but that stuff is usually not left unattended.
I'd always buy a discrete charger for and camera battery, regardless of whether it's the OEM / AC one or a 3rd party USB charger, the current trend of not bundling one when the camera can change in-body is a bit annoying but not the end of the world. I do wonder if it won't cost manufacturers more in the long run tho. I can see bundling phone chargers being wasteful these days (everyone's got loads, and they're cheap), but most people aren't churning thru cameras every 1-2 years.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Panasonic Lumix G 42.5mm F1.7 Olympus M.Zuiko Digital ED 75mm F1.8 Sony FE 20mm F1.8G +31 more
And yet the instructions on many cameras say 'do not use phone charger'. Kind of strange because most everything else (flashlights etc) don't seem to have this restriction.
Many phone chargers are capable of high speed charging which is controlled by the device being charged, and I wonder if camera makers are behind the times with this.
victorav Senior Member • Posts: 2,751
Re: My OEMs never swell
Mining operations yes, do damage the environment. However, large recycling plants are being built and its a growing industry so recovery and disposal is not as bad as it was anymore.
