Almost perfect vacation camera ... ?
Started 8 months ago | Discussions
Genes Pentax Senior Member • Posts: 1,096
5
My 8-yr old GX7 is still great. Have not been using it much at home. Using Fuji more at home. But my Panasonic GX7 is surprisingly good (still).
Compare to Fuji X100F, GX7 is better in three ways:
1. More comfortable grip
2. Image stabilization
3. Tilting LCD panel.
Having the joystick to move focus points, built in ND filter and quiet leaf shutter like X100F would make it much much better, but the GX7 with the 20mm lens is proving to be more handy than X100F.  It's just surprising after almost a year of not using it.  I was thinking about selling it, but I think I just changed my mind.  The grip is so good on GX7, I just keep reaching for it instead of my Fuji.
 Genes Pentax's gear list:Genes Pentax's gear list
Fujifilm X-T3 Pentax smc FA 43mm F1.9 Limited
Fujifilm X100F Panasonic Lumix DMC-GX7
yardcoyote Forum Pro • Posts: 15,754
Re: Almost perfect vacation camera ... ?
I spent a big chunk of last summer trying to like the 20mm on my Olympus E-M10ii. And, frankly, my copy didn't impress me at all with either focus or rendering. Does it work better on a Panasonic camera?
This made me rather sad, since 40mm is pretty much my favorite "wide angle" field of view for walkaround and general shooting, and the package was certainly nice and small. At the end of the summer, I was back to the excellent Oly 25mm f/1.8 as the tradeoff general purpose lens to the 60mm macro.
This summer, of course, the problem is solved. I finally got the gorgeous Fuji 27mm f/2.8 WR to put on my old X-T10, so I have a great 40mm compact with all the advantages of a larger sensor and Fuji full traditional controls, including an aperture ring on the lens. If you can live without IBIS, the X-Txx series offers a tilt screen and a lot more fun behind the camera in a not much larger size, and I like the lens so much more.
Instagram: @yardcoyote
 yardcoyote's gear list:yardcoyote's gear list
Fujifilm X10 Fujifilm X100T Fujifilm X-Pro1 Pentax K-5 IIs Fujifilm X-M1 +20 more
larsbc Forum Pro • Posts: 18,282
My 20/1.7 was equally good on my Panasonic and my Olympus bodies.
timo Veteran Member • Posts: 5,927
I don't think the stabilisation on the GX7 is worth very much, although of course it is true that the Fuji doesn't have any.
 timo's gear list:timo's gear list
Fujifilm X30 Pentax K-5 Pentax K-30 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
Yes, it's funny (peculiar funny, not haha funny) how Panasonic's subsequent GX bodies haven't had a grip as good as the GX7's.
uniball Veteran Member • Posts: 3,075
I have an X100V and a GX9. Shoot mostly primes including the P20. While I like the GX9, it’s been sitting in a drawer for quite some time. I’ve been shooting X100's since the first one and they are an extension of my hand and the evf is sooo much better than the GX’s.
For travel, I used to use GX series bodies and, mostly, the 14-140 II. Lovely combination but, replaced by a couple of RX100's (M3 & M6). So very compact, files at, or below, ISO 1600 are comparable to m43.
I tend to base my purchases more on the intangibles than a bunch of specs. Enjoyment and composition have higher priorities than searching for better pixels. I like my X100, you appear to like your GX7. I think we’re both where we need to be.
The only thing I might add is if you’re looking for a vacation camera, take a glance at the RX100's. Initially I felt they were fidgety and complicated. However, once set up, they are very well thought out and executed marvels, delivering excellent files. Though I do shoot a GM1 so my hands are quite used to small bodies.
We all have our own view when it comes to rendering. I feel like my P20 renders extremely well. When I shot Fuji ILC my least liked lens was the XF27 due to its render. Again, to each his own. However, I shoot the P20 on both Panasonic (GX9) and Olympus (E-P7) bodies. There’s certainly no difference in the render. AF, though poor, if anything is “surer” on the newer E-P7.
Wu Jiaqiu
Wu Jiaqiu Forum Pro • Posts: 29,319
i love my X100 for travel and stuff
the computer says no
 Wu Jiaqiu's gear list:Wu Jiaqiu's gear list
Fujifilm FinePix X100 Nikon D2Xs Nikon 1 V1 Nikon 1 J3 Nikon AF-S Nikkor 300mm f/4D ED-IF +3 more
jeffharris
jeffharris Forum Pro • Posts: 11,409
One MAJOR feature you forgot…
4. Tilting EVF
With the GX7 you can move the focus point with your thumb on the LCD when using the EVF. BRILLIANT feature! No clumsy joystick necessary.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
I also shoot with an X100V and GX9.  X100V has become my default street and family camera.  GX9 is for travel.  Although if I'm pressed for space, the GX9 will also serve duty as my street camera while traveling.  It's actually still very good as a street camera, but I just prefer the X100V's more compact size and having a few more pixels & dynamic range.
I'm finding that to be more and more important these days, too.  Using a camera for extended periods means it must be enjoyable and intuitive for me to use.
I've been shooting the XF27, in both versions, for a lot of years, and I think getting good jpegs out of it depends a great deal on camera settings, more so than the other Fuji lenses I own .
I'm considering now that my 20mm, which I bought very secondhand, may be a bad copy?   If I ever get a chance to try another one, I will.
Jamajuel Contributing Member • Posts: 917
I think it’s tragic! The GX9 would be sooo much better with it…
 Jamajuel's gear list:Jamajuel's gear list
Panasonic S1 Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic S Pro 70-200mm F4 OIS Sigma 85mm F1.4 DG GN Panasonic Lumix DMC-GX7 +4 more
4. Tilting EVF
Yes!! And especially in offset mode it is FANTASTIC! Way better than joystick. I think it works so well because the EVF is not centered.
The GX7 was my first ILC and have a real soft spot for it. I had a GX9 for while but sold it again, not the least because of the grip.
I used it again quite a bit on this summer vacation. I brought it as a second body because my wife has taken a shine to the OM-1, which means I often couldn’t get my hands on it. Obviously AF is not as good and the whole camera is a bit slow to react, But many images still came out just great!
If they made a GX10 (or even better a SX1…) with that grip and a better EVF, I would buy it in a heartbeat
James Stirling
James Stirling Veteran Member • Posts: 9,282
I would say that the grip on the GX8 is every bit as good { I used to own a GX7 as well } . One man's meat
Jim Stirling:
“It is one thing to show a man that he is in error, and another to put him in possession of truth.” Locke
Feel free to tinker with any photos I post
 James Stirling's gear list:James Stirling's gear list
Sony RX100 IV Panasonic Lumix DMC-GX8 Nikon Z7 Olympus E-M5 III Nikon Z7 II +10 more
Having never handled a GX8, I won't argue with you.
Agree, I find the GX9 to be a superb street camera. As with you I prefer the X100V. However, if I want more reach the GX9 + O25/1.8 was put to use. Indoors, mount the PL15. Also nice to take pictures via the touch screen when I simply don’t want to be noticed.
jeffharris
PLUS the G8's EVF is great! Then add the much better external controls, handling and ergonomics are steps above the GX7.
Yes, I had a GX7. The grip was fantastic. Probably too expensive… $2 more … for the Panny bean counters.
However, within the first minute using the GX8, the GX7 was rarely used ever again.
eques Veteran Member • Posts: 4,115
GX7 and 8
It is, indeed.
I don't see much improvement here. On the opposite, the exposure compensation is much easier to use on the GX 7. And alas, BQ of these controll wheels is miserable in both cameras.
Well the grip of the G1 and 2 was very good, the one on the GX8 is as well, the GX7 grip is phantastic - here I agree. Just forget about the Olympus grips of the em 5 and 10 models.
Same with me, but because of the imoproved sensor. It just didn't feel right not to use the best bensor I have.
And honestly, the GX7 looks so much better with the smaller M43 lenses. The GX8 is a ugly brick and look ridiculous with the 60mm macro lens.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
Yes!  When I was in Mexico City, I found that a 25 worked better than my 15, which surprised me because at home the 30- and 35-equiv focal lengths are my preference.  So I was happy that I was using my GX9 in Mexico City because I had the option to use a narrower FoV.
Locally, I primarily use the X100V but carry my GX9 + 35-100/2.8 for flattened perspective shots, or for reach.  Although lately I've been considering using the 25/1.4 around here, too.
