It seems hard to find the App minimum requirements now?
Started 7 months ago | Discussions
wklee Veteran Member • Posts: 9,950
Google Play Store doesn't openly display Apps minimum requirements now? My Android 9 OS seems too old for a lot of newer Apps. I cannot find the minimum requirement for Apps in Google Play.
Google has changed the layout for finding requirements.
Never buy version 1.0 of anything.
Don't it always seem to go
That you don't know what you've got
Till it's gone
They paved paradise
And put up a parking lot
Joni Mitchell's Big Yellow Taxi
Sagittarius Veteran Member • Posts: 8,676
Re: It seems hard to find the App minimum requirements now?
I've just looked at the app I've downloaded yesterday - Jabrasound+. Scrolled down to About this app. Touched arrow to the right. Scrolled down to the App info. Required OS.
Best regards
 Sagittarius's gear list:Sagittarius's gear list
Nikon Z6 II Nikon Z7 II Nikon Z9 Nikon Z 14-30mm F4 Nikon Z 85mm F1.8 +4 more
Rodolfo Contributing Member • Posts: 837
Yes, the store now requires you to click an arrow to get the app requirements (and warnings about all they access). FWIW, my backup or secondary Sony phone only got through angroid 9, but I haven't found anything that doesn't install and work fine on it --although I am less app-dependent/loaded than most. Picsart, Snapseed, and Polish photo editors have installed fine, for instance.
 Rodolfo's gear list:Rodolfo's gear list
Panasonic Lumix DMC-ZS3 Fujifilm X10 Panasonic Lumix DMC-FZ300 +1 more
I2K4
I2K4 Senior Member • Posts: 1,441
My experience (since 2011, Android 2.3) has been that the Play Store including Google's own preinstalled apps generally supports apps for about five or six years since the release of the Android version.  That said, I repurposed my initial little LG Gingerbread phone as a workout buddy for MP3s, timers and even offline mapping using old version APKs from dependable safe sources APKMirror or UptoDown, but of course it's not functional for online services.
There is a serious problem for photography apps, in particular and regardless of the Android version, that require Android's fully enabled Camera2 API, which is often intentionally sabotaged by manufacturers of mid-range and budget phones. You have to install something like Camera2Probe and test the phone to find out what app functionality it will and won't support.
OP wklee Veteran Member • Posts: 9,950
Thanks for the reminder. My own Sony Xperia X Compact and XZ1 Compact models never did support Camera2 API. I never got the Camera RAW to work with my Sony models. I haven't looked at newer models.
Till it's gone
They paved paradise
I2K4
There are a few apps that generate non-native DNGs on cameras without Camera2 support. On my old ZTE the best DNG output (though not the best overall camera interface) was from Bacon Camera (FGNM), the output from Snap Camera HDR (Marginz) was good DNG but color balance bluish, required PP but that's what RAW is about anyway. Snap has very configurable HDR settings, including zero shutter lag (unfortunately the Play Store free version still seems to be old 8.78 and payment required to get the much enhanced current 8.10.4 upgrade.)
FreeDCam apparently also does DNG, but the app never worked on my phone. As with everything in Android World, device compatibility (and user preference) varies - best to just try them.
