Displaycal banding issue
Started Aug 10, 2022 | Questions
Luis Gabriel Photography
Luis Gabriel Photography Senior Member • Posts: 2,621
Hi!
So every time I try Displaycal with any of my monitors (have tried it with 5 different models), and I create a gradient in photoshop, I can clearly see the banding.
I do NOT see any banding when I create a profile with i1 profiler.
Any idea what setting I may need to change?
Currently my monitors are the Dell S3222dgm and the Gigabyte M32uc. Before I was using PD3200 and SW2700pt
With an Asus Strix 3080
Thanks!
 Luis Gabriel Photography's gear list:Luis Gabriel Photography's gear list
Canon EOS R5 Sigma 50mm F1.4 DG HSM | A Sigma 105mm F1.4 DG HSM Art Sony RX10 IV Nikon Coolpix P950 +2 more
kciuk aka Ken60 Senior Member • Posts: 1,502
Re: Displaycal banding issue
Luis, perhaps displaycal has an issue with the backlighting on these two monitors. I don't mean to be offensive , but both of these are designed as 8 bit gaming monitors and not high end imaging units.
Again no offence intended but I have seen the sort of studio portraiture you do and have to suggest that you look at something a little more in keeping with the quality of your photography.
If you want smooth gradation , very accurate soft proofing , and amazingly accurate colours I can recommend and Eizo monitor like the one I am using.
OP Luis Gabriel Photography Senior Member • Posts: 2,621
kciuk aka Ken60 wrote:
Luis, perhaps displaycal has an issue with the backlighting on these tow monitors. I don't mean to be offensive , but both of these are designed as 8 bit gaming monitors and not high end imaging units.
Hello,
Thanks for the kind words.
It has the same issue with the PD3200 and SW2700pt(if I dont use the hardware calibration option).
Just confusing why i1 profiler with all its limitations, does not have such issue :/
Austinian
MOD Austinian Forum Pro • Posts: 14,319
Hello,
Interesting! I've had no problems myself using DisplayCAL for years, but a search turned up this post that might be applicable:
"Ok I fixed the issue 100%. Disabled surface color profile driver in device manager + 3dlut calibration in madvr and it’s perfect. No color tinted greys or banding in video (and on windows desktop). The default profiles have noticeable grayscale color tint and banding now that I’ve seen the display without them enabled."
https://hub.displaycal.net/forums/topic/grayscale-color-banding-after-calibrating/
(Edit: I should add that I may have avoided such problems since I routinely remove any manufacturer-supplied color utilities on all my PCs. I would also speculate that i1 profiler might do some things automatically that DisplayCAL requires the user to deliberately choose.)
 Austinian's gear list:Austinian's gear list
Panasonic Lumix DC-G9 Sony a7R IV Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Macro 30mm F2.8 Panasonic 12-60mm F3.5-5.6 OIS +6 more
