R5 with 100-500 + 1.4tc vs R7 with Canon 100-500
Started 7 months ago | Discussions
drsnoopy Senior Member • Posts: 1,216
Re: Re shoot (more precise focusing)
Steve Balcombe wrote:
drsnoopy wrote:
kristian1 wrote:
drsnoopy wrote:
Interesting comparison. On your second test, I still see a slight advantage to the R5.
However I have a question - what did you do to get the image scale identical? The R7 image should be 14% larger (800mm EFL vs 700mm FL). Did you zoom back to 437mm on the R7 to get 700mm EFL? In which case the different position of the zoom lens elements could affect the results. Or did you match the sizes by using different magnification on-screen in Lightroom? In which case apparent resolution is affected by interpolation (fractional magnifications show best screen resolution at 16.7, 25, 33.3,50, 66.7 and 75%, scales in between appear less sharp) - you would need about 87% on the R7 vs 100% on the R5.
Just interested to know what you did - not intended as a criticism, but to point out that there are confounding factors in such a test.
You forgot that r5 has higher mp count. It is 700mm at 45mp vs 800mm at 32mp.
Both images are at 300% of course , and lens is at 500mm in both cameras.
R5 image has slight higher magnification.
Kristian
Hi - naturally I know the R5 has a higher pixel count, as I own one, and the 100-500. However I do *not* see any difference in image size between the two images (R5 and R7 - both look identical) so if they are both had the lens set at “500mm”, you must have used a different image scale to make them appear the same size, as the R5 is at 700mm FL and the R7 at 800mm EFL, which is a 14% difference. They cannot both be at 300%, as there is a 38% difference between 32.5 and 45 MP. Please explain how you achieved the comparison at the same size on-screen - I’m genuinely interested, not trying to criticise!
The pixel density of the R7 is 38% higher (linear) than the R5, so if you were to shoot both at the same focal length the R7 image would appear 38% larger at 1:1. But by using the 1.4x TC on the R5, its image is made 40% larger (linear) so they appear very nearly the same at 1:1.
I think this is a better way to understand it than the MP count.
Thanks, that is a very good explanation of the (almost) identical image size.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Gaber1 New Member • Posts: 11
Re: R5 with 100-500 + 1.4tc vs R7 with Canon 100-500
Hi there, very interesting post !
I have done this test with this chart r5 with 100 500 at 500 r5 with 100 500 and 1.4 x and R7 with 100 500
All shots were taken from a sturdy tripod in electronic mode shooting with the phone app to avoid vibration.  focal lenght 500 1/25 maximum aperture same WB and tint
To me the results are:
R5 crop vs R7 wins R7 by a thin hair
R5 crop vs R5 + 1.4 x wins R5 and 1.4 x
R5 + 1.4 vs R7 to me negligible difference maybe a litle better R7 but i'm not shure
Hoping this test could be usefull
Ciao!
Gabriele
R5 100 500 500 f7,1 1/25 iso 100 same WB e tint
R7 100 500 500 f7,1 1/25 iso 100 same WB e tint
100 500 + 1.4 x 500 f10 1/25 iso 100 same WB e tint
 Gaber1's gear list:Gaber1's gear list
Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 70-200 F4 L Canon RF 14-35mm F4L IS USM
