R5 with 100-500 + 1.4tc vs R7 with Canon 100-500
Started 7 months ago | Discussions
kristian1 Veteran Member • Posts: 3,035
7
Here I decided to make this comparison as precise as possible , with tripod 10 sec timer and electronic shutter.
Results are almost identical when viewing at 300% , there is small different in focus , but it is close enough in my opinion.
Also bokeh seems to be same as well.
Hope this helps someone.
Left is R5 and right id R7 at 300%
Resolution
Bokeh at 100%
Bokeh
All the best
Kristian
 kristian1's gear list:kristian1's gear list
Canon EOS R Fujifilm GFX 100 Canon EF 500mm f/4.0L IS II USM Fujifilm GF 32-64mm F4 Fujifilm GF 23mm F4 +4 more
Canon EOS R5 Canon EOS R7
Mike Engles Senior Member • Posts: 2,573
Re: R5 with 100-500 + 1.4tc vs R7 with Canon 100-500
Very interesting comparison and very well done.
My sense is that the R5 is very marginally superior, but that could just be with the margin of error and that the R5 has a smaller magnification
R2D2 Forum Pro • Posts: 26,532
Resolution
Thanks for the test.
Actually, focus is very important when doing these comparisons.  Each leaf area in your sample is rendering differently due to the difference in focus.
Another attempt?
R2
spec68 Contributing Member • Posts: 533
Thanks for this. I agree, my initial impression was that the R5 is just a tad sharper. What focal length was that at? Have you tried the 100-500 + TC on the R7 yet? I'd be interested how that combo performs at the far end of the range.
Steve Balcombe Forum Pro • Posts: 15,571
It's very critical to get the focusing the same, and I can see leaves which look sharper in the R5 shot, and others which look sharper in the R7 shot. But hey, this is one of the best comparisons anyone has posted so great work, and I think we can safely say that the image quality is essentially the same.
Yep - which shows how good the TC is.
Only another week or so and I should be able to do my own comparisons!
OP kristian1 Veteran Member • Posts: 3,035
Re: Re shoot (more precise focusing)
Here I give my best to get focusing as close as possible , it was a bit difficult with r7 since it only gives x10 magnification.
Here are crops from different parts of image:
R5 on left , R7 on right , shoot at 500mm wide open.
(I choose to set same exposure and use iso 200 on R5 because there was a bit wind , so to get similiar (or none) motion blur from leaf movement.
All the best
Kristian
TnSkiDude Regular Member • Posts: 182
Thanks Kristian,  that is exactly the comparison I have been hoping to see.  I have the R5, 100-500 and extender.  It would appear the biggest advantage of adding an R7 to the kit would be that the 100-500 would recover full range of motion.
drsnoopy Senior Member • Posts: 1,216
Interesting comparison.  On your second test, I still see a slight advantage to the R5.
However I have a question - what did you do to get the image scale identical?  The R7 image should be 14% larger (800mm EFL vs 700mm FL).  Did you zoom back to 437mm on the R7 to get 700mm EFL?  In which case the different position of the zoom lens elements could affect the results.  Or did you match the sizes by using different magnification on-screen in Lightroom?  In which case apparent resolution is affected by interpolation (fractional magnifications show best screen resolution at 16.7, 25, 33.3,50, 66.7 and 75%, scales in between appear less sharp) - you would need about 87% on the R7 vs 100% on the R5.
Just interested to know what you did - not intended as a criticism, but to point out that there are confounding factors in such a test.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Victor Engel Forum Pro • Posts: 20,968
Right - additionally, the TC could be used on the R7 resulting in detail the R5 cannot touch but with a narrower field of view.
Victor Engel
 Victor Engel's gear list:Victor Engel's gear list
Canon EOS 5D Canon EOS 5D Mark II Canon EOS 600D Canon EOS 5DS Canon EF 50mm F1.8 II +13 more
BlueRay2 Forum Pro • Posts: 14,816
i don't see any difference and that is what i predicted. i can't wait to get my hands on a R7.
Unexamined world isn't worth living in. "Socrates"
Pipps Forum Member • Posts: 54
There was another thread where this was done with a sign on a post. Couldn't read the sign on the R5, but you could on the R7.
You forgot that r5 has higher mp count. It is 700mm at 45mp vs 800mm at 32mp.
Both images are at 300% of course , and lens is at 500mm in both cameras.
R5 image has slight higher magnification.
Kristian
On comparisons like this many things can go wrong, from slight miss focus (or a bit different focus point), motion blur, heat haze…
Kristian
Thats right, and also slight weight advantage.
Kristian
EBCowboy Regular Member • Posts: 108
Thanks for posting this. At last a comparison that some of us were hoping to see, but no one had yet managed!
Looking pretty good either way, nice to have choices!
 EBCowboy's gear list:EBCowboy's gear list
Canon EOS R5 Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 1.4x III +4 more
BigBen08 Veteran Member • Posts: 7,472
I agree. I don't see any significant difference.
My best aviation photos: https://500px.com/kenfm2018
Kristian
Hi - naturally I know the R5 has a higher pixel count, as I own one, and the 100-500. However I do *not* see any difference in image size between the two images (R5 and R7 - both look identical) so if they are both had the lens set at “500mm”, you must have used a different image scale to make them appear the same size, as the R5 is at 700mm FL and the R7 at 800mm EFL, which is a 14% difference. They cannot both be at 300%, as there is a 38% difference between 32.5 and 45 MP. Please explain how you achieved the comparison at the same size on-screen - I’m genuinely interested, not trying to criticise!
That was not a good test, too many uncontrollable issues.
Kristian
The pixel density of the R7 is 38% higher (linear) than the R5, so if you were to shoot both at the same focal length the R7 image would appear 38% larger at 1:1. But by using the 1.4x TC on the R5, its image is made 40% larger (linear) so they appear very nearly the same at 1:1.
I think this is a better way to understand it than the MP count.
And-roid
And-roid Senior Member • Posts: 3,201
Kristian
If you divide 8192 the R5 resolution by the R7 resolution and multiply by 1.4 the tc magnification you end up.with 1.6 ish, the same number as the R7 crop!
So basically using the magnification of the tc and  the extra pixels of the R5 will have the effect side by side of projecting the same images at 100/200/300% etc
