What would you pick as a second camera? - X-T4 main, X100V, Ricoh GR III
Started 8 months ago | Discussions
DarnGoodPhotos Forum Pro • Posts: 11,882
Re: What would you pick as a second camera? - X-T4 main, X100V, Ricoh GR III
I find the X100V to be pants pocketable so to me it is compact enough. So to me it would be a choice between camera features.
The X100V has a tilt screen and hybrid view finder and the GR has stabilization and is smaller. Also, the X100V is weather-sealed which is good since you would have to send it in to Fuji to get dust off the sensor.
Since you have both, which one did you use more frequently and why? Which one did you enjoy using more?
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
John Gellings
John Gellings Veteran Member • Posts: 9,743
Maybe Cargo pants and then it will be swinging around while you walk... not really what most people want.
https://www.johngellings.com
Instagram = @johngellings0
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
Relaxed fit jeans work fine with it. Cargo shorts obviously, but front pocket doesn't have it swinging back and forth. However, if you're the skinny-jeans type better stick with the GR.
John Gellings
Very relaxed fit.  I wear normal sized jeans and am 6’1” and 200lbs.  It’s not fitting in any pants pockets I have.
(unknown member) Forum Pro • Posts: 47,805
X100V fits in my shorts fine...
and they are not "Cargo pants."  It doesn't swing.  You can "feel it" a bit though, the GR is like invisible.  But the X100V can fit in a. wide range of pants too.
If you are the skinny type with tight jeans, then I agree that no.
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - Apparently Selwyn Duke and not George Orwell
John Gellings
Re: X100V fits in my shorts fine...
Again, I wear normal size pants and it doesn’t fit.  I’m not skinny.  I’m not fat.  My waist is 36 in the USA and I’m over 6’ tall.  I can’t imagine stuffing that camera in my pants and pretending it’s ok.
RestyPad
OP RestyPad New Member • Posts: 10
Used to shoot a lot of with the X100F, then upgraded to the X100V when it was released. Used it for several trips and then overtime figured out that I enjoyed having a bit more flexibility than the 35mm and added the Ricoh for slighty wider shots, but also easy to hand over to my non-photography girlfriend and snap a photo.
So my X100V used to be my main camera, and Ricoh has always been a second body / pocketable/social camera when a big camera weren't warranted.
Then I got the deal with the X-T4 + 16-55mm and have been enyoing it quite a lot so I decieded to keep that as my new main camera.
So the easy choice would just be to keep them all lol
RestyPad
For me personally I have never been able to pocket my X100V, it only fit in my winter jacket with a relatively large outer pocket.
I have used the capture clip from Peak Design to hang it on my belt, which has worked quite okay actually.
It's securely out of the way, while still being in a draw distance to capture a moment. If you practice you will be the best shooter in the west
It seems we both have different experiences. Maybe there's a Jean type with more pocket, but on my shorts which are fine, not cargo, the X100V does fit.
But it can be "felt" a bit while the GR is invisible.
Marty4650
Marty4650 Forum Pro • Posts: 16,281
"Is that a Fujifilm X100V in your pocket....
 Marty4650's gear list:Marty4650's gear list
Panasonic LX100 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX85 +16 more
Re: "Is that a Fujifilm X100V in your pocket....
Marty4650 wrote:
,,,, or are you just happy to see me?" (parphrasing Mae West)
Yes.
ms18
ms18 Veteran Member • Posts: 3,530
RestyPad wrote:
Would you pick the X100V or the Ricoh GRIII as a second body to the X-T4?
X100V because it has similar controls and experience. Even files and processing technique would be similar as they share same sensor.
X100v also has EVF and I'm comfortable with 35mm equivalent.
If you ask about GRiiix then that comes with 40mm equivalent but still i'll go with X100v considering I already have X-t4
If i don't have X-T4 and if i have to choose between X100v and GRiiix it's tough to decide.
 ms18's gear list:ms18's gear list
Fujifilm X-T20 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +1 more
