Limits of my camera and lens?
Started 8 months ago | Discussions
stevet1 Senior Member • Posts: 1,300
I'm wondering if you guys could give me some advice.
I took these last night. It was about 7:30 PM in the first week of August. I wanted to capture the moon shining through a gap in the leaves of a nearby tree, and I wound up with a hazy, blurry mess.
I was in aperture priority mode, and in looking at the EXIF data, I noticed that the camera had maxed out the ISO at 12800 and set the shutter speed at1/13.
So, my questions are:
Was 1/13 too slow for handheld? Should I have used a tripod?
ShouldI have put the camera in Manual and deliberately set a faster shutter speed? Was the blurry moon the result of the 1/13th speed, or just trying to do it handheld?
Was there just not enough light for autofocus to work? Should I have switched over to manual focus? The light was so dim, I can't tell if the leaves are in focus, and the moon is out of focus - which is not what I wanted. I had the camera in single point and aimed at the moon, but I'm wondering if the camera overrode me and chose the nearby elements of the leaves.
The night sky wasn't nearly so bright blue as it seems in the photos. It was actually quite dark. Should I have taken it out of auto ISO?
It looks like I've got lens flare going on in the first photo. Is that the result of pointing the camera directly at the light source?
Thanks for any advice you can give me.
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
Oldpanda Forum Member • Posts: 96
Yes and no.
There is a lot to consider when imaging the night sky. Obliviously, your equipment has limits, but there is a lot out of your control.
To my eyes, the leaves look in focus (or close to in focus) and therefore you probably have a depth of field problem in these images. Or atmospheric haze could be degrading the image of the moon as well. But there is more to deal with than that.
I found this thread on shooting the moon:
https://www.dpreview.com/forums/thread/3684935
It seems to have a lot of good suggestions. Taking good images of the moon is more difficult than you would think. The apparent motion of the moon and stars is faster than you perceive when looking up. The dynamic range of a bright moon and a dark sky adds complications as well. Spot metering is called for and even then bracketing is necessary. You will still have a lot of throwaways. In addition there is often fog or haze and light pollution that must be dealt with. Here in the Atlanta area I find the best evenings to shoot sky pictures typically are in the winter. There is much less haze producing ozone in the atmosphere since plants are not growing and the relative humidity is typically lower. A clear, chilly night in 30's (or lower) Fahrenheit with steady light winds seems best.
Using a tripod helps, but it is really not hard to do handheld. I usually don't use one on the moon.
I put my equipment in ziplock bags to cool down outside before shooting and warm back up after shooting. This cuts down on condensation. This is especially important when coming back inside. Dampness is not the camera's best friend.
Here is a good discussion of shooting the night sky in general:
https://shuttermuse.com/how-to-avoid-star-trails/
There is a lot of information online about this. Just do searches on what you are looking for.
Hope this helps.
Glenn
 Oldpanda's gear list:Oldpanda's gear list
Canon PowerShot G11 Canon EOS Rebel SL2 Canon EOS Rebel T8i (EOS 850D) Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +4 more
Len Philpot
Len Philpot Contributing Member • Posts: 625
Re: Limits of my camera and lens?
Yes to both.
A general rule of thumb (in the absence of IS / VR) is your shutter speed should be at least as fast as the reciprocal of your focal length. E.g., at 55mm it should be at least 1/55 second more or less. Of course that's just a general rule but it's a starting point. I certainly can't handhold 1/13.
I'd never attempt a low-light shot without a tripod or resting the camera on something solid.
Should I have put the camera in Manual and deliberately set a faster shutter speed? Was the blurry moon the result of the 1/13th speed, or just trying to do it handheld?
Again, yes to manual. To get you started you can fiddle with ISO, shutter speed and f/stop to get some kind of acceptable exposure, then tweak the up/down to get the best combination of noise, DOF and clarity. The T8i will show a live histogram in Live View, so use that to get in the right area.
I suspect the shutter speed was less of a factor than handholding. I usually bracket quite a bit under difficult circumstances. Electrons are cheap.
The camera won't override a chosen focus point but at 1/13 second any breath of wind will blur the leaves. There may well be no way to get both perfectly sharp. Stopping motion blur will require 1/125 or faster, depending on the motion. Getting the moon at that shutter speed is a stretch to say the least. For example this image...
https://photos.app.goo.gl/56qRdrZuCKAxpQ6E6
...per the on-image notes was taken at 1/160 at f/9, but that was through a telescope with 4" aperture on a tracking mount. That's much more aperture (and hence, light-gathering ability) than a camera lens.
Also the moon is at true infinity, so you'll need to either stop down or focus stack to get the tree in focus as well. Don't try autofocus in the dark. Use Live View, zoom in 10x and focus on whatever is your primary target -- probably the moon in this case, and given the low light. Pick a sharp edge or detail and manually focus it as well as possible. Make sure Focus Peaking is turned on so when you go back to 1x on the LCD you'll see (by default) red highlights on what's in focus.
What you're trying to do -- both near leaves and infinity moon in focus -- might be tough at best.
Yes -- Always manually set ISO. I never use Auto ISO at all. There might be some isolated uses for it, but certainly not at night. Offhand, I might be tempted to start around 1600 ISO and go up / down from there after testing. Also, the moon is gonna move if your exposure is too long. You can read up on the "500" or "300" rule of thumb about that, although I think both are optimistic. Also there's basically no way around it - With a nighttime shot you're gonna have to do some noise reduction in post.
Yes. Some lenses are more or less prone to flare, too. Also, stop down one f/stop from the max open aperture your lens will do. The image quality will almost always be better.
And you are shooting raw, right? Don't shoot JPG.
Len Philpot
Retirement: 4th best thing to happen to me
https://www.instagram.com/lphilpot01/
 Len Philpot's gear list:Len Philpot's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF 70-300mm f/4-5.6 IS USM Topaz Adjust Topaz DeJPEG Topaz Detail +13 more
OP stevet1 Senior Member • Posts: 1,300
Thanks for your comments and suggestions.
Steve Thomas
Useful info on shooting the Moon
Re: Useful info on shooting the Moon
Oldpanda wrote:
I found this and thought you might enjoy reading it. A lot of info about shooting the Moon.
Thanks Glenn.
Steve Thomas
Dunlin Senior Member • Posts: 2,611
Regarding the flare problem, were you using a UV filter?
A UV, or "protective" filter can actually make flare worse, especially (IMO) when shooting directly at the moon. I've suffer from such a problem. In the end I stopped using a UV filter all the time.
BTW I only (so far) use a really cheap filters.
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
Jethro,
Yes I do.
I'll have to give your suggestion a try. I have a Hoya filter mounted all the time. I'll have to try taking it off for a while.
Steve Thomas
Digirame Forum Pro • Posts: 41,857
If you are using a protective filter for the lens, you might try using a lens hood instead. I have hoods on all my lenses and no protective filters. The hoods also reduce the chance of water getting on the lens where there might be an occasional sprinkle of rain. I buy my hoods on Ebay from reputable sellers.
