R7 IBIS--wow!
Started 7 months ago | Discussions
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
R7 IBIS--wow!
I have never had a camera with IBIS, before the R7, though I've had plenty of IS lenses. I just tried out the IBIS on the R7 with my RF 50 F1.8, which doesn't have IS. All I can say is 'wow!'. Here is a 100% crop from the center of a handheld shot at 1/15:
And here's the same (approximate) view at a full second, also handheld:
I very much doubt whether I'll want to take many handheld exposures at 1 second with this lens, but it's still pretty amazing what modern IBIS systems can do. I can see this being useful with a wide angle lens (perhaps my RF 16 F2.8) to get flowing water nicely blurred while keeping the rest of the scene sharp. I've done that at 1/2 second with my 11-22 IS on my M6II. I think I could easily use a full second with my RF 16 on my R7.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Canon EOS R7 Canon RF 50mm F1.8 STM
Alastair Norcross
OP Alastair Norcross Veteran Member • Posts: 9,874
Interesting e-shutter result
The test images I put in my previous post were taken with EFCS. I thought I'd try out e-shutter, to see how it compares. The interesting thing is that I can't get it anything like as sharp with a 1 second e-shutter exposure. I switched back to EFCS, to see whether my earlier results had been a fluke, but no. In fact, my later EFCS shots were, if anything, even sharper at 1 second than the one I posted. I wonder why IBIS seems to work better with EFCS than e-shutter? At least in my limited testing so far.
Alastair
danferrin Contributing Member • Posts: 730
Re: R7 IBIS--wow!
I’m impressed.
My life is a circle of confusion - photography is my meditation.
See my work at www.danferrinphotography.com
 danferrin's gear list:danferrin's gear list
Canon EOS 60D Canon EOS 7D Mark II Canon EOS RP Canon EOS R5 Canon EOS R7 +20 more
thunder storm Forum Pro • Posts: 10,139
Re: R7 IBIS--wow!
Good stuff!  I don't think my R5 would match it with my 85mm Art....
45 is more than enough, but 500.000 isn't
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
Re: Interesting e-shutter result
Interesting. I had some blurred (well, slightly) shots with my R5 + 12mm fish eye using e-shutter. I thought the focus distance scale would be off, but maybe e-shutter is playing a role here. Or IBIS isn't working correct because the camera doesn't know the focal length.... lots of factors...
juanmaasecas Senior Member • Posts: 1,497
I think that for lenses with no communication with the camera you need to set the focal length manually for ibis to work properly.
 juanmaasecas's gear list:juanmaasecas's gear list
Canon EOS M50 Canon EOS R5 Canon EF 50mm f/1.2L USM Canon EF-M 22mm f/2 STM Sigma 35mm F1.4 DG HSM Art +4 more
Alastair Norcross
Maybe. But that doesn’t apply to the RF 50 F1.8.
Edit: it looks like you were replying to Thunder Storm. Sorry.
Alastair
