End of my tether Panasonic G7 - Focus Advice - Do cameras die?
Started 8 months ago | Discussions
OP HRPOWER Regular Member • Posts: 159
Re: Do lenses die?
It is unlikely to be both lenses - as the G85 I am using has not been dropped and is pretty new.
jeffharris
jeffharris Forum Pro • Posts: 11,411
Re: End of my tether Panasonic G7 - Focus Advice - Do cameras die?
HRPOWER wrote:
My G7 is 5 years old. Yes it may have been dropped. It has done around 60 video shoots.
Suddenly the auto focus hunting is terrible. On every mode.
So I did a test and put the camera in manual focus. Still hunts, albeit less.
I normally shoot in a car moving along.... No issues for 5 years,
Camera man shop bloke says - cameras die, life span... sensor goes, board goes etc.
Yep cameras die.
After 7 years, my first GX8 started mis-focusing. It started slowly gradually getting worse. The kicker was when shooting ancient Roman sculptures with the 12-40mm. It would snap to focus, as usual, but as soon as an pressed the shutter button would pop OUT of focus. Lots of blurry shots. Luckily I had a couple of manual lenses, but what a pain.
There’s no other camera like the GX8, so I managed to find and buy a brand new one.
Shall I get another G7?
Why not use the opportunity to upgrade and get a G90/95? Or even a G9?
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
Good to know!!!!!
Had no idea they existed
I have a G85 already which at the moment is working G95 is not that much better.
Besides Ideally I need 12mm and I need something light - something that puts less pressure on the window mounts.
pannumon Veteran Member • Posts: 4,130
jeffharris wrote:
Yep cameras die.
Why do you think it failed? All I can think is IBIS.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
