Using manual lenses on an M200
Started 7 months ago | Questions
DavidWright2010 Veteran Member • Posts: 3,729
I can't find the feature 'enable shutter when no lens detected'. I don't remember having to do anything with my M100 - both manual lenses that I have, work with it.
Youtube videos are mostly long and useless, and the only ones that alleged to show the fix used a different model Canon, and a menu choice the M200 doesn't have.
Anybody know the solution?
David
 DavidWright2010's gear list:DavidWright2010's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Merrill Pentax K-1 +1 more
Canon EOS M100
nnowak Veteran Member • Posts: 9,075
Re: Using manual lenses on an M200
David
You need to set the camera to M, Av, Tv, or P mode, and then going into the custom functions.  If you are in the full auto green A+ mode, none of the custom functions are available in the menu.
OP DavidWright2010 Veteran Member • Posts: 3,729
David
I tried that. i'm in M model - no A+ green.
And no menu function about 'enable shutter...'
Got any other ideas?
David
Bingo!
I hadn't noticed that there were 5 custom functions (only 1 visible at a time), and an arrow left and right to navigate. I needed CF 5
On the M100, there are only 2  CFs, and they are both visible all the time..
David
David
Bingo!
David
Glad you got it sorted. You are not alone.  Your question is a regular occurrence in these forums.
dwfrommonterey Regular Member • Posts: 388
Why they don't just enable this is bizarre.
 dwfrommonterey's gear list:dwfrommonterey's gear list
Nikon Coolpix P900 Sony RX10 IV Nikon D7200 Canon EOS M5 Canon EOS RP
I have wondered the same thing.  Maybe they got too many warranty requests from people poking the shutter curtains with their fingers.
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
TYes, this makes some sense to it.
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
Sittatunga Veteran Member • Posts: 5,406
None of my EOS M models have visible shutter blades when I remove the lens, and all defaulted to not firing if no lens was detected.
I think it's more about inviting the user to think about what (s)he is doing before using a manual lens. It might stop people from complaining that the camera won't set the aperture from the body and can't autofocus or use A+, P, Tv, or the scene modes properly with such a lens.
Analog4Ever Regular Member • Posts: 205
I'm pretty sure the OG M had a menu flag you could set.  I had the M2 as well and I know that I shot manual lenses using both.  Haven't tried using manual on my M100.  Not really curious enough to try it.
“Sharpness is a bourgeois concept"
 Analog4Ever's gear list:Analog4Ever's gear list
Canon PowerShot A590 IS Canon PowerShot Pro1 Canon PowerShot SX70 Canon EOS 5D Mark II Canon EOS 10D +14 more
It is not just EOS M.  Mirrorless cameras from many other manufacturers behave the same way.
The problem with that logic is the "manual" nature of a manual focus lens is far more common knowledge than knowing that an obscure firmware flag needs to be set to enable the shutter.
They all have the firmware flag.  Many other mirrorless cameras from other manufacturers also require a similar setting change to enable the shutter.  It's not just a Canon thing, but it doesn't make it any less dumb.
So it's common knowledge for mirrorless camera users, but not necessarily known by people coming from DSLRs.
I'd have thought that too. But there was a thread in the EOS. R forum from somebody who knew that but still wanted to know why a manual RF mount lens sort of fit but wouldn't work on the mount adapter EF - EOS R, so you can't take anything for granted.
Maxmolly7
I guess that the Mxxx line is not suposed to support manual lenses.
I know that it is, and use them regularly
Without exception, ALL M system cameras can be configured to work with manual lenses.
It is only common knowledge for those thst have attempted to use a manual lens AND found the firmware setting.  I am sure there are some thst just give up when it doesn't work the first time.
There are also the few among us who burn up a battery, or two, scrolling through every firmware setting on a new camera.
If you read some of the Amazon reviews for lenses, they are littered with one star ratings because the lens they bought didn't actually fit their camera.
