Canon 100-300 L tripod ring mount?
Started 8 months ago | Discussions
demonboy
demonboy Regular Member • Posts: 391
Hi,
Although this is a relatively light lens I have this attached via an adaptor and would like to mount this on a tripod. Can anyone recommend a tripod ring mount that would fit the 100-300 5.6 L?
Thanks in advance.
Photobygms
Photobygms Regular Member • Posts: 296
Re: Canon 100-300 L tripod ring mount?
Do you really mean the old 1987ish EF 100-300 F5.6L.
There is not a tripod mount available for that ancient lens. Will also difficult to fabricate one, The old 100-300L is a push-pull zoom lens
.....Of course I'm out of my mind. It's dark and scary in there.....
Mostly analog at: https://www.flickr.com/photos/photobygms
Digital and some analog at: https://www.instagram.com/photobygms/
 Photobygms's gear list:Photobygms's gear list
Canon PowerShot SX740 HS Canon EOS 5D Mark IV Canon 6D Mark II Canon EOS R Canon EOS RP +46 more
demonboy
OP demonboy Regular Member • Posts: 391
Yes, that's the one. I was remaining hopeful as there is a gap between the zoom and body-end of the lens, even when closed.
John Crowe
John Crowe Veteran Member • Posts: 3,476
I no longer have the EF 300mm f4 L, but I used to use the tripod mount on other smaller lenses by filling the gap with foam rubber.
You should be able to research the various diameters and I saw a few third party ones on eBay as well.  They aren't cheap.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
demonboy
Problem solved, John. Turns out there's a tripod mount for the adapter itself (Sigma MC-11 EF to E), so this is an even better solution.
