70-300mm f4-5.6 review
Started 9 months ago | User reviews
pharles
pharles Forum Member • Posts: 88
I've been giving this lens a good workout the past few weeks in a nature setting. Though I don't consider myself much of a nature photographer, it's a good excuse for a walk in the woods.
Generally I've been please with the lens. It is sharp, focuses quickly, has excellent close focus for the focal length, handles well and is relatively compact.
I've been using it on the end of an X-S10 so I don't know if this is a camera or a lens issue, but at times the AF can get confused and do nothing. An example would be a situation where there's a bird or an insect with surrounding vegetation. I'm using Single Point AF Mode together with the joystick to pick my focus point. Fairly frequently I find that the AF just can't lock on to the subject. I have to move the camera to point to a more distant object where the FA then works. I recompose to the subject and everything then works fine. I've made the AF box quite small so that not much intrudes, but it still gets these confused moments and nothing happens.
Usually I'm not one of those who obsesses over bokeh and out of focus areas, but I'm not impressed with how these areas look. The out of focus areas are busy and distracting.
Overall I'm very happy with the lens and I can live with the out of focus areas. Again I don't know if it is camera, lens or both, but the AF issue needs some firmware help.
Peter Charles
 pharles's gear list:pharles's gear list
Fujifilm X100V Fujifilm X-Pro3 Fujifilm X-S10 Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 18-120mm F4 LM PZ WR +15 more
Telephoto zoom lens • Fujifilm X
Announced: Jan 27, 2021
pharles's score
4.5
Average community score
4.5
ChrisGibbons001
ChrisGibbons001 Regular Member • Posts: 234
Re: 70-300mm f4-5.6 review
I sold mine for the 150-600, I honestly miss it alot, its almost perfect for what it is, a small lightweight tele with great IQ. Perfect for travel and zoo trips. Fuji did a steller job making it.
 ChrisGibbons001's gear list:ChrisGibbons001's gear list
Fujifilm X-T5 Fujifilm XF 23mm F2 R WR XF 150-600mm
Lettermanian
Lettermanian Senior Member • Posts: 2,389
Just wondering if the focus issues are caused by where the focus limiting switch is set, either at Full (the lens will look for focus through the full focus range) or at 5m-infinity (will not utilize the full focus range)? I had less focus issues once I made sure I had that switch where I wanted it. 🤷🏻‍♂️
"Be yourself. No one can say you're doing it wrong." -Charles M. Schulz
"I love mankind... it's PEOPLE I can't stand!!" - Linus
 Lettermanian's gear list:Lettermanian's gear list
Fujifilm X-T3 Carl Zeiss Touit 2.8/12 Tamron 17-70 F2.8 Di III-A VC RXD Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Jacaustin Regular Member • Posts: 113
Just returned from Patagonia and Machu Picchu/Peru, and my copy performed amazingly. Extremely sharp and perfect for the use case.
robert1955 Veteran Member • Posts: 7,302
I thought that only influenced focusing speed, not accuracy?
GMacF Contributing Member • Posts: 999
It doesn't "influence" either. it is literally just a limiter switch. When it is set to 5m it will not focus on anything closer than 5m to the camera.
The switch was my first thought but the fact that it focusses after a bit of work would suggest it isn't. I would make the focus box larger. The focus box size can be very hit and miss depending on what you're shooting. If you have it set too small it may not be able to detect enough contrast to operate efficiently.
 GMacF's gear list:GMacF's gear list
Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +9 more
pharles
OP pharles Forum Member • Posts: 88
Nope, the limiter is on at "Full" the entire time. The AF is on "Area", the box is set to the second smallest size to prevent too many things being included, and AFS is selected. Yet a half press on the shutter does nothing until I focus on something far away, then recompose on the near subject, then everything works. This only happens occasionally. Most of the time the close focus is accurate and quick, but sometimes it just locks up and doesn't behave until I pick a distant subject.
Peter Charles
JNR
JNR Veteran Member • Posts: 4,652
Two thoughts that should at least isolate the problem. First, if you still have the X-T3, try testing the lens on that body. You'll find out if the issue is with the lens or the body match. Second, experiment with going one size larger on focus spot. Sometimes that has made a difference in low light or low contrast situations for me (X-T2/20).
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
pharles
I've already gone through changing the size of the focus box and it didn't help. Trying it on the X-T3 is next.
Peter Charles
DearZ New Member • Posts: 5
Apart from the issue I have with the OIS (posted a thread in here somewhere few days ago) working only in continuous IS mode, I have to say this became one of my favorites. it is light, landscapers dream, it is very sharp, with enough reach to carry it along side standard zoom and be covered for 90% of situations.
Honestly said, zooms in this range I used to have with other brands were complete (excuse my French) cr** and I was very reluctant with purchasing it - mainly for landscapes, hiking and general carry around purposes. Now, I do not leave my house without it. I was looking yesterday into the my children night party picture and was blown away by number of keepers, micro-contrast, overall feel of the images. To me, this lens has well exceeded my expectation, to be very honest.
If we're to neat-pick, I would like to have an option to add a tripod collar just because having the lens on the X-T4 and nodal slide, it does seem a bit wobbly. But that would probably add some weight or require lens housing redesign.....well, as announced, pure neat-picking :).
Overall, FWIW very very pleased with it.
Greetings to the forum from Croatia!
beneix Regular Member • Posts: 121
Zdravo 😊
You could get a lens support such as this – that is what I use on telephoto lenses without a collar. https://www.bhphotovideo.com/c/product/1698651-REG/neewer_10096285_long_focus_lens_support_holder.html
 beneix's gear list:beneix's gear list
Canon EOS 550D Fujifilm X-T30 Canon EF 50mm F1.4 USM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
