Diferences in autofocus performance on 600mm f4 versions
tetsumo Regular Member • Posts: 193
Hey there folks, I wanna hear your experience with 600mm f4 af lenses regarding autofocus on newer bodies (R6 and R7).
I´m a wildlife photographer and I´ve always wanted a 600mm f4 but I´m unable to afford a new one so I´m scouring ebay for the 600 f/4L IS USM and f/4L IS II USM versions. I know the weight differences and will probably decide for the IS II version, but also wanted to know your experiece with the aufotocus with these cameras.
Also if you have advice on what to check for before buying a used version.
Thanks!
 tetsumo's gear list:tetsumo's gear list
Canon EOS R7 Canon RF 800mm F11 IS STM Canon EOS R6 Mark II Canon EF 16-35mm F2.8L II USM Canon EF 70-200mm F2.8L IS II USM +5 more
KevinRA Senior Member • Posts: 1,466
Re: Diferences in autofocus performance on 600mm f4 versions
Thanks!
Just beware if it breaks down - unlikely the version 1 will be able to have any spare parts for repair... Also suspect just like in the 500 Ls - the version 2 sharper and snappier.
Would also suggest a 2nd hand dealer with a warranty rather than ebay - you may pay 10% but no more normally and much better peace of mind and if something goes wrong post purchase in first 6 months.
The 500 f/4 II - which is very similar technology to the 600 mark II - performs incredibly well on the R10 and R5, including with 1.4X TC.
 KevinRA's gear list:KevinRA's gear list
Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon EF-S 60mm f/2.8 Macro USM +14 more
BlueRay2 Forum Pro • Posts: 14,816
Thanks!
i have had my canon 600 f4 II since 2013 and it an awesome big lens. the only issue is if you want to handhold this lens. the weight of it is not much of an issue but it is awkward when you want to focus for more than a few minutes. therefore, you must use a tripod or a monopod, which can put restrain on lens movement of the camera/lens if you are shooting small birds, or moon for that reason. this lens takes TC 1.4 III quite well when you get used to it.
i have been using my 600mm with my FF cameras and that is the reason why i'll be getting the new R7 that will make perfect couple, methinks. if you can find a 600mm II for a good price that you can afford, jump on it, you'd love it.
Unexamined world isn't worth living in. "Socrates"
Norm Neely Veteran Member • Posts: 3,451
KEH Camera has a 7-Day Return & a 6-Month warranty on used camera gear.
https://www.keh.com/shop/canon-600mm-f-4-l-usm-ef-mount-lens-gel-canon-600mm-f-4-l-usm-ef-mount-lens-gel.html
Thanks!
Canon 600mm F/4 at an Aussie football Game, scroll down to the excellent photo.
https://www.dpreview.com/forums/thread/4574916?page=3
Auto focus was good enough to get this photo, I'm sure it will be fine for wildlife.
It will also be great with an EF to RF adapter.
My hiking staff functions as a monopod.
https://www.dpreview.com/forums/post/65838986
Norm
 Norm Neely's gear list:Norm Neely's gear list
Nikon Coolpix 995 Olympus SP-550 UZ Canon EOS 40D Canon EOS 7D Mark II Canon EOS 5DS R +1 more
OP tetsumo Regular Member • Posts: 193
Thanks!
Thanks for your answer, care to share where you recommend buying it from?
thanks!
Thanks!
Victor Engel Forum Pro • Posts: 20,968
I have a 600mm f/4 III. You may have noticed that the previous versions are listed as f/4.0 lenses and this one is f/4. Now why might that be? Maybe it's because it's actually f/4.2, which rounds to f/4. Also Exiftool shows that the focal length is 584mm rather than 600mm. Maybe these are additional reasons why it's lighter than the Mark II version. I've not used previous versions to compare, and I'm still relatively new to this lens. I have used it for handholding photos at a couple parks. It's doable without getting completely worn out. With a decent shoulder mount it should be even more doable.
This lens has had a couple of firmware upgrades to address AF issues. I've read that there is a design flaw that will prevent the problem from being completely resolved by firmware upgrades. I don't have enough data yet to verify that, but I'm generally happy with the lens. I've not had anything comparable before. Closest is a 300mm f/2.8 lens I rented, and I also own a 200mm f/1.8 lens.
Interestingly the 600mm f/4 Mark III is only about an ounce or two heavier than the 200mm f/1.8 lens.
Victor Engel
 Victor Engel's gear list:Victor Engel's gear list
Canon EOS 5D Canon EOS 5D Mark II Canon EOS 600D Canon EOS 5DS Canon EF 50mm F1.8 II +13 more
lonewolf1983 Contributing Member • Posts: 654
i have the original non-IS with the R6
AF is slightly faster i feel on my 1DX, but obviously miss out on a lot of AF functionality.
Speed wise its very good, slightly behind my mk1 IS 400mm 2.8.
Panning side on or angle, no problem.
Subjects at a distance towards you no problem - you may encounter issues at closer distance but i cant say if the mk1 and mk2 are better but I would assume so.
Galah on approach, about a 50% crop of frame, run through LR+Topaz (r6+600mm
 lonewolf1983's gear list:lonewolf1983's gear list
Sony RX100 III Canon EOS-1D X Canon EOS-1D X Mark II Fujifilm X-T3 Canon EOS R6 +11 more
Nice capture   And nice to see a fine old optic still working well.
Guessing from the outer part of one wing, electronic shutter used?
beautiful capture. i am not familiar with R cameras yet - hoping my R7 that i'll be getting will give me the performance i am expecting from it. thanks for sharing.
Yep, mechanical shutter at 6.7fps not cutting it for me
What are you getting at with the wing comment?
Victor Engel
Zoom in on the birds left wing (right hand side of picture) - look at the outer 20% for artefacts/distortion.   It is also longer appearing than the birds right wing.
A lovely shot, just similar effect to what I have got and I have attributed to rolling shutter in electronic shutter on my R5 and R10.
Now that's interesting. I guess the readout is done several rows of pixels at a time to produce that feature?
Maybe significant and maybe not. The bird is in asymmetrical flight at this stroke anyway. It is also presenting at an angle to the camera (note the tail is to the side compared to the head).
I'll keep my eye out for similar artefacts. Maybe I'll browse through my barn swallow shots to see if I find something similar.
Victor Engel
