Occasional faint metallic sound with EF 100-400mm mk II while focusing
Mika Y.
Mika Y. Senior Member • Posts: 2,135
Hi,
I noticed a few days ago that my 100-400mm mk II occasionally but not always makes a faint kind of metallic sound when focusing from the infinity towards a closer target. Anyone had a similar change in behaviour?
I've owned the lens for about 6 years and I'm quite sure this hasn't happened until now. Focusing seems to work just fine though, and there's no any kind of noticeable slowdown or pause in focusing even if I hear this.
Other observations:
- If I use manual focus, there's no any kind of extra sound or change in how the focusing ring turns
- This doesn't ever seem to happen if I focus from the minimum focus distance or close to it towards infinity, so this seems to be kind of one-way issue
- Focal length does not seem to matter
- Whether IS is on or off doesn't seem to matter
Thus, I suspect this has something to do with the AF motor or mechanisms transferring the torque to the lens group(s).
Obviously any unexpected sounds with a piece of camera equipment are worrisome and I guess I should get the lens checked by a local authorised Canon repair shop in near future in case this is something that may result to loss of functionality over time. But checking just in case someone has experience about similar issue.
 Mika Y.'s gear list:Mika Y.'s gear list
Canon EOS Rebel T4i Canon EOS 5D Mark IV Canon EOS R7 Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +13 more
BlueRay2 Forum Pro • Posts: 14,816
Re: Occasional faint metallic sound with EF 100-400mm mk II while focusing
Mika Y. wrote:
Hi,
Other observations:
sounds like you are not familiar with canon telephoto lenses. there are many many moving parts inside the barrel so the noise is expected.  there is nothing wrong with your lens. this noise doesn't effect the focus accuracy or anything else. just get use to it and ignore it.
good luck.
Unexamined world isn't worth living in. "Socrates"
Mika Y.
OP Mika Y. Senior Member • Posts: 2,135
BlueRay2 wrote:
Mika Y. wrote:
Hi,
Other observations:
  • If I use manual focus, there's no any kind of extra sound or change in how the focusing ring turns
  • This doesn't ever seem to happen if I focus from the minimum focus distance or close to it towards infinity, so this seems to be kind of one-way issue
  • Focal length does not seem to matter
  • Whether IS is on or off doesn't seem to matter
good luck.
Well, I have had this particular lens for about six years and used it quite regularly, so Canon telephotos are not entirely unfamiliar to me (I do also have an old 200mm EF and a 70-300 DO, but they're obviously not quite as sophisticated)
However, to my surprise I noticed earlier today that this metallic noise seems to have disappeared just as unexpectedly as it appeared last week. It was still happening occasionally in the weekend when I had to use a telephoto. No idea what happened.
Anyway, for now I'll just be happy and not worry anymore unless it makes a comeback.
amm Junior Member • Posts: 37
Hello Mika,
I have quite a few Canon telephotos including 100-400 mm ii, no metallic sound from any of them that I can recall while focusing. By the way, there is a new firmware for 100-400 mm ii on canon website, in case you have not updated yours. It was suggested that the new firmware prevented IS from random jumping (although you had mentioned based on your observation that the noise is not IS related). One never knows what other issues may have been addressed in firmware updates.
Mika Y.
amm wrote:
Hello Mika,
Oh, seems that I have missed the existence of the firmware update, thanks for the tip! No harm in applying it just in case anyway.
