Re: The Canon R5C is NOT the camera For Video Wildlife Shooting on Safari
5
I just created and account to answer you as you seemed soo convinced that you did wrong, and I feel sorry about it as it is not true at all.
I have both the R5 and R5c and heading out to Africa in a week. I will mostly use the R5c for filming.
Let’s start with this 80% of commercial wildlife video are done with RED cameras. Why? Because high res (8k) and slow motion. REDs do not have IBIS, consume tons of big battery, need rigging, but REDs have the resolution/sharpness/fps that are key factor for wildlife.
Guess what the R5c is probably one of the best “semi affordable” wildlife film camera that come close to REDs and here is why it is better than the R5:
8k 60fps RAW (so key to have 60 fps for slow motion, if you watch thinks like Our Planet and so on are basically all in slow motion)
5.9k 60fps RAW in S35 giving you reach if you need/prefer
4k 60fps is much better quality than the pixel binned R5
4k 120fps is better quality than R5 plus you can record audio, R5 cannot.
3k S16 RAW up to 120fps even more reach and slow motion
XF-AVC much easier to edit that R5 h265 Log3 files.
Live waveform for exposure
Focus peaking even in AF. This is a life saver as is much better to judge how the AF works and if you need to bump it or correct something. R5 only has peaking in MF
Prerecording you can have the camera always prerecording so you can react later instead of missing a key moment (it has limitation as no RAW ☹) but works in XF-AVC
No IBIS. I have sometime issues with IBIS and the 100-500 while video as it sometimes jumps especially if you pan fast. Following jets is a big issue and the R5c has no issue. Ibis for video is good only from around 30 to 100mm rest is useless. Wider is wobble wobble, above it creates more problem than solving. Plus, with long lens you need a really good fluid head so no need for IBIS
Bit better DR although not world changing
No overheating. I want to see under the sun the R5 recording at 120fps…… at some point it will be so hot.
What is better in the R5:
Battery life (much better)
No need to rig it (due to the battery)
Animal AF
Object tracking in 120fps
Here a test video done with the R5c, 200mm at 2.8, 1/100, 8K 50fps slowed down to 25fps on a Gimbal all done with AF tracking:
Nufenen Wildlife - YouTube
So enjoy the trip and the camera, the only mistake you did is not getting much more familiar with the camera, but you can learn it in Africa as there are a lot of not so exiting waiting moments that you can use to test things out.
