This Forum is Apparently Dead - So Where Else for 3D Examples/Discussions?
Brian F Flint
Brian F Flint Regular Member • Posts: 184
Re: This Forum is Apparently Dead - So Where Else for 3D Examples/Discussions?
H Mike
Here is the alignment I did in Resolve on the plant
parallel view ( zoomed in 1.8 times, 1440p )
https://drive.google.com/file/d/1Dy7Se-B5dzt12KZoIt6rjeCuV0GNJW4n/view?usp=sharing
cross-view ( zoomed in 1.3 times , output 4K )
https://drive.google.com/file/d/1OZc0W3aU9CD9hdLnWCE-nVl3nj57T93d/view?usp=sharing
regards
Brian
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
OP Markr041 Forum Pro • Posts: 10,078
How About This?
  1. Brian F Flint wrote:
H Mike
regards
Brian
I do not know why you all insist on this dialogue in this thread, which starts saying the forum is dead.
Let's start new threads based on different topics. A viewer here is not going to know what this thread is about based on the title. You will get more attention if you have a separate thread with an appropriate title
More importantly, can you also provide your examples in anaglyph so more people can view your 3D contributions?
I am happy this forum may not be dead, but it can be better-served.
 Markr041's gear list:Markr041's gear list
Panasonic ZS100 Olympus TG-5 Canon EOS M Panasonic Lumix DMC-GH4 Nikon Z6 +5 more
sludge21017
sludge21017 Veteran Member • Posts: 3,813
shock_me wrote:
sludge21017 wrote:
shock_me wrote:
I'm currently using a dual RX0 II set-up with the VMC-MM2 syncro cable. Those cameras come with some serious limitations but the photos are excellent and the results are superb.
So I would guess one would need 2 of those syncro cables, and 2 of these? Sony FA-WRR1?
So with all things being equal - it mostly works out for generally static type shots?
That is cheaper than getting the commander box.
I'm not sure about the flash situation, sorry. I use the RX0ii's mostly for daytime walk-around shots.
With the VMC-MM2 connected between the cameras the one with the right-angle connector becomes a sub-camera to the other, and you can shoot pictures simultaneously on both by operating the shutter on the main camera.
Hi - Are you help this user on his post?  I'm not sure which cable exactly they are using, or if your setup resolves his problems.
https://www.dpreview.com/forums/post/66402812
sludge21017
Thanks for the tip on the cable.  I ended up picking up another RX0M2, and got a decent plate.
Got it all working and using SPM. Trying a few things on my own before I watch any tutorials.
Elchtest
Elchtest New Member • Posts: 4
shock_me wrote:
I get wildly different results depending upon the viewing platform. I tried Skybox, DeoVR and Heresphere. They all look distorted to one degree or another in the headset.
If you have one of the Meta Quest devices, you can also look at 3D photos in the app immerGallery (immervr.com). Maybe viewing works better there for your images?
