Hi friends.
Wanted to share some first impressions of the Laowa 10mm F4 cookie lens. It's good 👍.
Arrived shockingly fast. I did regular shipping and FedEx sent from HK to my doorway in Seattle in 24h flat.
It's an interesting lens to use and reviews are accurate. It is hard to attach and detach from camera and you notice that right away but not a big deal to me.
It's super easy to accidentally get your finger in the frame while focusing. So you really need to focus and then move your left hand away and shoot. Either that or turn the focus ring from direct bottom of lens so most out of the way. Despite the focal length and DOF you do need to somewhat focus on APSC.
It's accurate that it's low or no distortion. And accurate about the vignette but I don't mind it.
Testing handholding it's easy to shoot at some slower shutters than usual. I could easily get shots with no blur at 1/30th but would prefer to shoot at least 1/60th.
It doesn't inspire a lot of confidence in sharpness because you take a photo, zoom in on a tree, and all the leaves are blurry. But then again everything is so wide it's hard to compare to other lenses like that. I would be happy with any of these shots for web at least. If you use Fuji for anything professional than maybe this lens image quality won't meet your bar.
You can focus very close to subject, and easy to do because it's about a handlength for min distance. You can use it at close with on camera flash from X-T30 fine at that distance just fine so you could do a macro-like close subject photo in a pinch.
I'll share some samples later but it's kinda "what you see is what you get" with a lens this wide (if you don't pixel peep). Point it in rough direction of your house and whole house is there in frame, not needing as much creativity for framing, at least for far away stuff.
