very good CA correction and quite sharp
Started 8 months ago | User reviews
joy8 Forum Member • Posts: 73
++ nice color rendition
++ high sharpness
++ good correction of CAs
- no aperture ring and plastic housing, no manual aperture control with NX 1000
 joy8's gear list:joy8's gear list
Pentax Optio I-10 Fujifilm FinePix HS20 EXR Fujifilm FinePix S2 Pro Pentax K-x Samsung NX2000 +9 more
Samsung NX 50-200mm F4-5.6 OIS
Telephoto zoom lens • Samsung NX • T50200SB
Announced: Jan 4, 2010
joy8's score
4.5
Average community score
4.0
markyboy81 Veteran Member • Posts: 4,778
Re: very good CA correction and quite sharp
++ high sharpness
As far as I know there is no Samsung Nx lens that has an aperture ring.
Also, I'm pretty sure you can control the aperture manually with the nx1000.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
JankHua New Member • Posts: 10
666
 JankHua's gear list:JankHua's gear list
Samsung NX20 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 16mm F2.4 Pancake
armin304 Contributing Member • Posts: 740
markyboy81 wrote:
++ high sharpness
But if your lens has an iFN button, you may use the focusing ring to change the aperture after pressing the button at the lens. The NX100 was the first NX to support this, so the later NX1000 should support it too.
I have both versions of the 50-200, the older without iFN, but with OIS switch and the newer with iFN but no OIS switch. If I compare the two lenses, then the newer Mk II is the better of the two. Especially beyond 150mm my Mk I isn't as good.
 armin304's gear list:armin304's gear list
Nikon Coolpix P900 Sony a7 II Panasonic Lumix DC-GX9 Nikon Z6
armin304 wrote:
markyboy81 wrote:
++ high sharpness
Good point re. iFn button. I try to use it more than I do but I think it's sometimes awkward as in a different place on different lenses. And the 30mm is sadly lacking it. Innovative though.
