Can I Limit the ISO Range on the Wheel When in ISO-C Mode?
Started 9 months ago | Questions
Shooters on My Squad Regular Member • Posts: 391
I would like to limit the available ISO range on the wheel, when I have the ISO dial set to C on my X-T4. I don’t need the L- & H-values, and I am also not interested in higher ISO shooting overall, but the Auto ISO options are at the end of the list, and I like to use them on this camera.
Is it possible to limit the ISO range, so that it will be easier for me to reach the Auto ISO options with less wheel movement?
 Shooters on My Squad's gear list:Shooters on My Squad's gear list
Canon PowerShot G5 Ricoh GR III Olympus TG-6 Canon G5 X II Ricoh GR IIIx +41 more
Erik Baumgartner Senior Member • Posts: 6,894
Re: Can I Limit the ISO Range on the Wheel When in ISO-C Mode?
No. It’s easiest to just set up a custom function button for the Auto-ISO presets (I use the right d-pad on all my cameras that have one). Quick and easy to change. I do recommend setting a high max ISO limit to prevent the camera from unexpectedly overriding a too-low minimum SS setting  (I use base ISO and ISO 12800 for all three of my presets with different min. shutter speeds for each. It’s better to have a little noise than motion blur.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
No - it might be useful to select which end of the range the Auto ISO options show up - but you can't currently
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
OP Shooters on My Squad Regular Member • Posts: 391
I already have this set up on the d-pad down button, but this means I need to have ISO set to A, not C. In faster situations I do not want to use the top dial to override the ISO value, but a wheel instead, which feels inherently faster.
ISO 12800 is way above my tolerance level with this camera, and I usually pay attention to the SS on the EVF while shooting, so no worries here, but I will have to experiment more with the Auto ISO settings if it is not possible to limit the ISO range. Maybe I have to dig a little bit deeper to find another fast way to conditionally override the Auto ISO value without using the top dial.
Thanks for the hints!
There are a lot of ways to to set up and use these cameras, but as  AUTO-ISO will always use the lowest possible ISO value and highest possible SS (respective of your other settings), I see no reason to limit the ISO at all. If your SS is as low as it can go to avoid motion blur (either manually set, or with an Auto-ISO preset), and your aperture is as wide as it can go without compromising your desired DOF, if the ISO has to go all the way to ISO 12800 to maintain the desired brightness then I don’t see any good reason to limit it - again, better noisy than blurry. I always want to shoot with as low an ISO as possible, but if it has to go high to get the shot, it has to go high. If I want a darker/lower ISO RAW, I simply dial down the exposure compensation (I always use EC in C mode which effectively adjusts the ISO or the SS depending on the available light with the front dial). The only time I typically override the Auto-ISO is if I plop my camera on a tripod, in which case I simply dial the top ISO dial to base ISO (or whatever).
Erik
Thanks for evaluating the Auto-ISO functionality on the Fujifilm cameras, this inspired me to slightly tweak its setup on my X-T4.
In theory everything you write sounds great, but it simply doesn’t work for me in practice, because how the Auto-ISO functionality is implemented in the camera. At first it will try to keep the base ISO by lowering the shutter speed. Then once it reaches the threshold that was set up it starts to increase the ISO value until it reaches this second threshold. Then it tries to lower the shutter speed until it reaches what it thinks is a correct exposure, hence eventually introducing motion blur. This means that by changing EC while in Auto-ISO you will either change the shutter speed or the ISO value, depending on the state you are currently in, but there is no direct control. So the only way out I currently see is to override Auto-ISO with a manual ISO setting, but this is not ideal if done via a wheel due to the big ISO range which is mostly unused.
Auto-ISO would need something like SS/ISO priority settings, similar to how Release / Focus Priority work in AF. Alternatively it would be maybe enough, although not that sophisticated, if there would be twice as many Auto-ISO slots. This way I could duplicate them with different ISO settings, hence emulating something like SS/ISO priority. Maybe you could get completely rid of the different Auto-ISO settings, and implement it similar to how other manufacturers do it.
The other thing that slightly bothers me is the mapping of the wheels when in A or M mode. On the front wheel I have configured F/EC/ISO, on the back wheel I have SS. When I’m in manual mode, it’s fine, because I can change the ISO value directly with the front wheel and the SS with the back dial. But when I am in A mode the back wheel becomes defunct, and I have to click the front wheel to toogle between ISO & EC. I can configure the wheels for A mode, but then the problem is just the other way around for M. Ideally no dial would be disabled, no matter the mode, but I see no way of configuring the camera this way.
The top dials are great for this use case. They are in my opinion the best usability option we currently have available on the market when using cameras on tripods.
I will continue to find better settings for my use cases for Auto-ISO, and maybe eventually I will also solve my issues with the wheel mappings. Thanks so far for all the precious input.
I’m at work at the moment, but when I have some time this weekend, I’ll be happy to explain how I have my cameras set up and how I can quickly and easily get an optimal exposure in almost any situation with a very simple control configuration and minimal fuss with an X-T camera. At this point I’ve probably experimented with every possible configuration that doesn’t work efficiently, so I can probably offer some worthwhile direction.
I always shoot RAW so I don’t mess much with film sim recipes or incorporate  much in the way of jpeg options into my customized setup. I don’t shoot video, don’t use flash, and I always set my aperture manually. If you need to do otherwise, let me know and I’ll think about a way to work them into a simple, easy to use setup.
I would greatly appreciate any input. I would say that I work in M & A about 95% of the time. What I am used to is to have the front wheel for F control, the back wheel for SS, and then somewhere else direct access for ISO override. This is what I am trying to replicate on this camera, but I start to get the feeling that this might not be possible on the X-T4 body.
Today I already slightly improved the front / back wheel functionality. Now I have a nice & fast setup, but the body is the odd one now where I have to do a slightly bigger mental shift.
I also searched for an option to reverse the directions of the wheels, but couldn’t find one. This is also where I will need to adjust for the first couple of photos taken I guess.
I would really wish the body would have better customizability options.
DarnGoodPhotos Forum Pro • Posts: 11,882
Wouldn't it be easier to just turn the ISO dial to A when you need Auto ISO? Its just one click from the C position, and would be faster than the wheel if you aren't at the end of the ISO range.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
jerryf128 Contributing Member • Posts: 897
Please do a setup for jpeg shooters.
Yes, I think I will eventually have to bite the bullet and use at least the ISO dial on this camera. Maybe I was a little bit too naive thinking that I can set this body up, so that the top dials will be mostly for decoration. The X-H1 was my favorite back then, but the X-T4 was technologically advanced, and the X-H2(S) rumors already everywhere. I thought I could get used to it, but I really don’t like to use the top dials except when on a tripod.
Erik Baumgartner gave me some impulses which already led to some smaller QoL improvements of my setup, and I am still experimenting with the Auto-ISO settings, and basically what will work for my use cases on this camera.
I have to do some more sessions with the down button for Auto-ISO, and keeping the camera in A-ISO, but also while using the front wheel for changing ISO (Auto-ISO included, basically giving me the down button for another function), and keeping it in C-ISO.
Today I used the camera with a slightly changed Auto-ISO 1 setting (max. ISO 400), and it worked flawlessly, but I still have to do the culling to see if I got what I wanted from the shots.
I really worked hard to make the C-AF on this camera work for me, and I think I succeeded.
Now I want to get the last 5% out of this body, to make it the best possible fit for me and my style.
