How to remove persistent spot from sensor of X-T4?
Started 9 months ago | Questions
JackEtweather
JackEtweather Regular Member • Posts: 106
Despite repeated usage of a blower and many passes of swabs with either Eclipse or VSGO fluid, this spot persists on the lower-right of the image from the sensor of my X-T4.
I'd like some advice from someone who has dealt with this problem.
The first image is a shot at f/11. The second image is a photo of that image on the screen of the X-T4 (note relation to the grid lines). The rest of the images are frames from 4k video, shot with ND filter on the XF 16-80mm lens at f/4.
I am aware of workarounds in photo-editing software and in Adobe Premiere, but the latter doesn't work for me, and the solution I am seeking is to remove this spot from the sensor. With this spot, I cannot use this camera for shooting video.
 JackEtweather's gear list:JackEtweather's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 18-55mm F2.8-4 R LM OIS 7artisans 12mm F2.8 Fujifilm XF 16-80mm F4 +1 more
hasslebad Forum Member • Posts: 57
Re: How to remove persistent spot from sensor of X-T4?
I dealt with it by sending the camera back to Fuji to clean. It was out of warranty and they charged about $200 to remove the protective glass plate and clean the sensor.
 hasslebad's gear list:hasslebad's gear list
Panasonic Lumix DMC-LX3 Fujifilm X-Pro1 +3 more
biza43 Forum Pro • Posts: 15,074
Send it to a professional service.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
JackEtweather
OP JackEtweather Regular Member • Posts: 106
Thanks.
JackEtweather
Thanks.
Morris0
Morris0 Forum Pro • Posts: 32,181
You need to try a different cleaning solution. Some spots are water soluble and others alphol soluble. Visible Dusts makes a solution for both problems:
VisibleDust Smear Away Solution
VisibleDust Sensor Clean Solution
Eclipse will not address both.  Use compatible brushes so they don't dissolve and create a film you will need to clean off.  The VisibleDust green brushes work with both of the above.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
JackEtweather
Thanks. I've used the Visible Dust dual-fluid kit in the past, and had great success with it. However, although I might try it again, I'm mentally and financially preparing myself for the prospect of sending the camera to Fuji for sensor cleaning, as the problem might be a speck of dust (if not more as well) under the glass covering the sensor.
ksoltys Forum Member • Posts: 55
I have a similar problem with my X-S10 (as posted elsewhere on this forum). I did not know the sensor has a protective glass covering. I assume this would be true for the X-S10 also.
This makes me a little less worried about accidentally scratching it; however, as noted above, the speck could be UNDER the glass.
Regards
Keith
Keith
** Any sufficiently advanced technology is
indistinguishable from magic. - Arthur C. Clarke **
rla1022 Contributing Member • Posts: 762
Regards
Keith
I’ve got a similar one on my Xpro 3, which I have found I can ignore accept when its in bright light. I do clone it out when i see it. I had thought about taking to a local shop, but they are not Fuji experts.
Randy
 rla1022's gear list:rla1022's gear list
Fujifilm X-E4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 16-80mm F4 Fujifilm XF 27mm F2.8 R WR +1 more
JackEtweather
Regards
Keith
Randy
With photos, the spot doesn't pose much of a problem if one is okay with cloning it out. However, in my case, it was persistent in video, even at wider apertures.
The update to this scenario is that I have sent it off to Fuji repair in New Jersey. I'm advised to expect ca. $250, but such comes with the territory.
blink667 Contributing Member • Posts: 944
If you have a local shop that can do sensor cleaning I would bring it there.  $200 sounds a little high for a sensor cleaning.
 blink667's gear list:blink667's gear list
Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
JackEtweather
It's not merely a sensor cleaning; it's a matter of removing the glass that covers the sensor and removing the spot from its underside. I though that I'd made that clear. It's much more than a tech at a local camera shop can deal with. The top tech at the top shop in town told me so.
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
I agree with your experience. If it’s something the best tech states they are unable to remedy then send it to Fuji repair. I had the same experience. My tech uses GFX gear and is a published and awarded photographer. I take his advice and opinions seriously. Fuji repair did the trick.
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
JackEtweather
Thanks.
