The latest Lumix puts a Four Thirds sensor in a full-frame body with boosted AF and a wealth of stills and video capabilities to create a Swiss Army Knife of a Micro Four Thirds camera.
Banding on Z9
Hi,
I've read about the risk of banding showing up in photos, but I seem to remember that this only happens at slow shutter speeds.
I'm currently editing my photos of a live concert by Swedisch guitarist Yngwie Malmsteen and noticed (what I believe to be) banding in some of my photos.
Below you see an unedited RAW photo exported from Lightroom to JPEG at a resolution of 2000 x 3000 pixels. On the photo above and around the head of the guitarist you can clearly see the banding in de red background.
Nikon Z 9 with Z 70-200mm S @ 99mm - ISO1800 - f/2.8 - 1/320s
Is there a way to prevent this from happening?
Or is there a clever way to get rid of this in post-processing?
Or is this just one of the disadvantages of a shutterless camera?
Victor Peters
This is probably Pulse Width Modulisation. Go to 9 min +55 sec in this vid for an explanation.
Firmware v2.10 added High-frequency flicker reduction] has been added to the roles that can be assigned to camera controls using Custom Setting f2 [Custom controls (shooting)]. For more information, see the Supplementary Firmware Update Manual.
areallygrumpyoldsod
ajm057 wrote:
Was there a video behind the player ?
Don’t shoot at 1/60th or 1/50th depending on the country
try the new anti Flickr in v2.1
There was mo video screen behind the band. Just a huge array of Marshall amplifiers and speaker cabinets.
When shooting I didn't notice any flickering so there would've been no way for me to manually dail in flicker reduction.
Victor Peters
It happens faster than you can see - they probably had LED lights and the effect is similar to advertising panels — Try this-- you only see the effect in his vid because he recorded the vid. Similarly with a still photo.
areallygrumpyoldsod
Firmware 2.1 added a feature to fix this that you can assign to a function button.
If you mean that cameras with mechanical shutters would NEVER have this then you are wrong. You can get this sort of effect with any camera, even one with mechanical shutter. It is caused by the light and depending on the shutter speed, captured by the camera.
It is impossible to "fix" this because it depends on how the lights are flickering, different parts of the sensor are exposed at different light intensity.
The effect depends on the position of shutter plane and also on aperture of shutter plane doesn't coincide with focal plane, see https://www.dpreview.com/forums/post/65887363
So the results from cameras with ES and MS are different even if they have the same travel time of the shutter.
areallygrumpyoldsod
The point is that you have to notice that something is wrong in order to enable that feature. If the banding is subtle or affecting only a portion of the image you might not detect it until your review the images and then it's too late. Also, the lighting is usually dynamic during show like that and you might get the issue with some of the light but not the others. It also might happen that the flicker-free shutter speed will be different for different lights so you would have to switch between them on the fly.
Pros and others who shoot under lights know this. AND now so do you.
It occurs with every DSLR/Mirrorless camera and not just a shutterless Z9 issue.
The solution on the Z9 works pretty much the same as a similar solution implemented on the Sony A1. No doubt Canon has a similar solution as well
When shooting indoors or in environments where there are LED lights and ad boards - one takes a few shots and looks at the images on the camera or ipad/iphone using snapbridge. Guys pros do this all the time. Since you have to select/dial-in a very precise shutter speed to eliminate/reduce the effect there are tradeoffs to make.
There is the Flicker Reduction ON/OFF (Reference guide page 518/519 stills and page 585 for vids) and now High-frequency flicker reduction option as well - which was added at the request of pro shooters.
Learn how it works, practice and then use it or don't use it -- that is your choice.
Just don't complain when you have banding on your shots and are using a Z9 v2.10 BUT chose not to follow the guidance or learn to use it correctly.
areallygrumpyoldsod
Good suggestions above.
A short suggestion how to remove it. Add noise. Noise is a photographers best friend.
AND ?
Don't be so negative.
Do or Don't do.
Don't just whine and complain like a Millenial when you won't even try to use the tools that have been provided.
Of course you could just buy an "etch a sketch" or shoot film.
areallygrumpyoldsod
I'm not sure why you target this post at me, I was just explaining that some cases might be more complicated.
However, it certainly doesn't happen with the same extent/look for MS and ES, see this post https://www.dpreview.com/forums/post/66343520
Flicker Detection may be able to show if there are Flicker issues
areallygrumpyoldsod
I had something similar happen at an indoor event that I shot with the silent shutter the first hour or two. Then I saw it when I got the images moved over to my phone. Folks online said to change turn off silent shutter, and that issue went away completely. Unfortunately it was really bad in my photos, and I ended up dumping most of them because there was not a good way of fixing them (and as a hobbyist, wouldn't have been worth my time).
It's not that I choose not to use the option. I've been shooting shows for the past 10 years with DSLR's, MLIC's with and without physical shutter and have never come across it in my photos.
Victor Peters
Yes I know that. Nevertheless it is a fact that even film cameras can give you banding in some lights and under certain conditions.
Well, you are lucky or just didn't see it. Fluorescent lights and other types of lights which flicker have been around for about a hundred years and has always been a problem for photography and moving pictures. Can be more or less obvious but it is there if the conditions are right for the banding.
You won't see this problem with a camera that uses a leaf shutter.
Sorry to hear about your technical problem with Nikon Z9. For my son who is a great fan of this artists, I wanted to ask if this is taken on the concert in Tilburg? Do you know if there are other pictures available?
Kind regards,
Jon
Latest sample galleries
Latest in-depth reviews
The fourth camera in Leica's SL series of full-frame mirrorless cameras sees the 60MP BSI sensor from the Q3 and M11 models arrive with a significant interface redesign.
The Fujifilm X100VI is the sixth iteration of Fujifilm's classically-styled large sensor compact. A 40MP X-Trans sensor, in-body stabilization and 6.2K video are among the updates.
The Nikon Zf is a 24MP full-frame mirrorless camera with classic looks that brings significant improvements to Nikon's mid-price cameras. We just shot a sample reel to get a better feel for its video features and have added our impressions to the review.
This $250 electronic lens adapter is perfect for Nikon Z-mount curious Sony shooters — shhh, we won’t tell anyone.
Latest buying guides
