3 WEEKS WITH THE FUJIFILM X-H2S AND XF 150-600 LENS (STILLS ONLY)
Bjorn Moerman PHOTOGRAPHY Regular Member • Posts: 145
15
Used the new Fujifilm X-H2S and XF150-600 lens extensively during a three week period in a variety of shoots from Airshows, Aerial photo flights and some limited birding shoots.
More at: https://bjornmoerman.blogspot.com/2022/07/fujifilm-x-h2s-xf150-600-3-weeks-field.html
Happy shooting,
BJORN
ChrisGibbons001
ChrisGibbons001 Regular Member • Posts: 234
Re: 3 WEEKS WITH THE FUJIFILM X-H2S AND XF 150-600 LENS (STILLS ONLY)
Really good read Bjorn and some really good points.
I was thinking the other day while aking some animal picture, why is the fastest auto iso shutter spedd 1/500? Life would be alot nicer if it was 1/1000+.
 ChrisGibbons001's gear list:ChrisGibbons001's gear list
Fujifilm X-T5 Fujifilm XF 23mm F2 R WR XF 150-600mm
JK5700
JK5700 Senior Member • Posts: 1,757
Excellent post. Thanks.
I am using a X-T3 with 100-400 for aviation, avian & wildlife photography. No videos.
I am very disappointed with the less than 10% keeper rate. The X-T3 with the 55-200 gives good results, the 100-400 is usually soft. I have been shooting for over 40 years and should by now have good technique. So it must be the gear.
Did you try the X-H2s with the 100-400? Any improvement in keepers?
At the moment I can only afford to upgrade either the lens or body. Which do you think will make the most difference?
I swapped to Fuji as I could no longer manage the weight of my Nikon D4s and 500vr. And have been happy with my landscape and other images. But not with Fuji for wildlife and aviation.
I am even thinking of getting a used D500/200-500 combo just for aviation and wildlife. I am still not convinced that Fuji is any good at it,
 JK5700's gear list:JK5700's gear list
Nikon D4 Nikon D7100 Fujifilm X-E2 Fujifilm X-T1 Fujifilm X-T3 +10 more
Dino2000 Regular Member • Posts: 138
I think the sample shots are pretty convincing on the combo's capability at aviation, avian & wildlife photography. The 100-400 will certainly benefit from the improved AF speed in X-H2S. Why don't you rent the body to test on your 100-400?
hotpot65 Regular Member • Posts: 130
Hi ChrisGibbons001,
I also wondered about this limitation but I recently watched a video on Manual mode plus Auto ISO.
If you put the camera in M mode, set ISO to one of the auto modes (it won't matter) and set your max ISO value  (min shutter speed you can set to  1/500 although it won't matter !)  , set your shutter speed to say 1/1000 and your aperture to what you want, then the camera will ignore the min shutter speed set in the auto iso settings as the shutter speed diallied in will take precedence.
That way you get auto iso functionality but min shutter speed dictated by the current shutter value.
Try it, it seems to work on my X-H1.
 hotpot65's gear list:hotpot65's gear list
Fujifilm X-H1 Fujifilm X-S10 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Samyang 12mm F2.0 NCS CS Fujifilm XF 35mm F2 R WR +4 more
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Hi ChrisGibbons001,
With this method the shutter speed is fixed - its no longer a minimum.
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
Okand Regular Member • Posts: 118
Happy shooting,
BJORN
I have to say I really like your shots, most pleasing and super sharp images
 Okand's gear list:Okand's gear list
Canon EOS R5 Canon RF 70-200mm F2.8L IS USM
JK5700
Are there any of the igames on your blog taken with the X-F2s and 100-400?
Not myself ad I haven't received my copy. I have friends who have reported improvement in keepers rate with above combo.
Artur Darulewski Senior Member • Posts: 1,209
Hi, I also have X-T3 and both 55-200 and XF100-400 and I'm a bit surprised with what you wrote here. I agree, keeper rate is worse that you can get from Sony A7x or Action DSLRs from Canon and Nikon but I wouldn't estimate it as 10% in my case, rather about 40-50% and I don't have 40yrs of experience (maybe we have different acceptance thresholds). In fact significantly 1.4xTC affects AF-C efficiency, but bare lens is OK - at least for me (considering X-T3 limitations).
I'm also wonder what you mean by 100-400 is usually soft - is it related to optical IQ or OOF? This lens is rather good and many owners say it's sharp (even at 400mm it's more than acceptable)
Would be nice if you put some examples of soft images
Here are few samples of aviation/BIF photos from my XF100-400 (some are taken with 1.4xTC or X-T20) :
Well, X-T3 + XF100-400 kit is far from being perfect and not the best possible combo, but it works and if your equipment isn't damaged, I would venture to say you probably don't use it properly. You can look what Morris could do with the same gear.
I assume that H2s + XF100-400 should be better than X-T3 + XF150-600 even though new lens must have much faster AF system. We all know that the Fuji AF-C was a one of the biggest drawbacks and it looks H2s is much better.
I'm in similar position and I'm rather not interested in XF150-600 as 600/8 seems to be a bit too slow for me - that's why I mostly using Sigma C150-600/5.6-6.3 today.
I would rather buy new body first and test it with my lenses first.
Waiting for Morris's comments
Artur
 Artur Darulewski's gear list:Artur Darulewski's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +16 more
OP Bjorn Moerman PHOTOGRAPHY Regular Member • Posts: 145
No I did not, as I sold my XF100-400 lens a few weeks back. I do have lots of sharp images on the 100-400 however. This is just a sample gallery of mine where all of the in-flight images are shot with the 100-400 and X-T3: https://www.bjornmoerman.com/Galleries/Aviation/Events/Oldtimer-Fliegertreffen-Hahnweide-2019/
Most of my other work in the Aviation > event galleries is 100-400 as well.
Changing to the X-H2S or X-H2 is probably going to have a better outcome than only changing the lens.
No all images on the blog are taken with the X-H2S, XF150-600 and XF16-55 lenses.
