R5+100-500+1.4x or R7+100-500?
Started 8 months ago | Questions
drsnoopy Senior Member • Posts: 1,216
I have the R5 and 100-500, and very happy with the combination. I also have an R7 on order but now I'm wondering whether anyone has done a comparison between the R5 with the 1.4xTC (giving 700mm max FL) and the r7 with the bare lens (giving 800mm effective max FL).  I do understand the issue with the TC restricting the short end of the zoom range.  I've also tried crop mode on the R5 (17MP) and the results are mostly good but would like the extra sensor resolution.  My feeling is that the r7 should have the edge, bearing in mind of course the differences in noise, which I am happy to deal with in RAW conversion (DXO) or in post (Topaz).  However the TC would be less expensive...
Thanks for any examples or pointers towards other sources.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Canon EOS R5 Canon EOS R7
R2D2 Forum Pro • Posts: 26,531
Re: R5+100-500+1.4x or R7+100-500?
For me, 700-800mm is my “Goldilocks Zone,” so this would indeed be my preferred max focal length too (I have the R5 + 100-500 + 1.4x).  Love it.  I do a lot of BIFs, so anything longer than this is not ideal for me (harder to acquire/track).  It’ll be good to see how this all shakes out!
R2
Karl_Guttag Senior Member • Posts: 1,883
I think it depends somewhat on what you are shooting. My favorite subject with the RF100-500 is propeller airplanes (warbirds).
I had an R7 on backorder due to the pain it is to use theRF100-500 with TCs. I would have single sequences where I needed to start with 700mm but need less than 200mm (say a plane taking off).
But I decided that the R7 had too many compromises over the R5 unrelated to the sensor. In particular, with planes, I mostly shoot with electronic shutter, and the R7 has a notoriously bad electronics rolling shutter (the R5 is not perfect but "acceptable"). I also decided that most of my "bad" shots were a result of subject and hand motion (trying to take pictures at low shutter speeds when tracking planes) and not one of needing a little more resolution when cropping.
Then there were the issues with the different buttons and dial placement. Still, if the ONLY difference were the resolution of the crop sensor, then I would have gone ahead with the R7 purchase.
The more I thought about the differences between the R7 and R5, the more I realized that I probably could not use my RF100-500 with it when I wanted it the most. Your mileage (and shooting situation) may vary.
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
RDM5546
RDM5546 Senior Member • Posts: 3,654
Losing the full zoom range with R5, RF100-500 + extenders is a real pain.   I love the RF 100-500 without extenders.
I bought the R7 and the RF 100-400 which does support the extenders and preserves the 4X zoom range.  However, it is a little darker at f8 when shooting 400mm.   Still it is a great light weight lens  and it pairs nicely with the R7 for a light package.
For me the R7 is a situational camera.  The R5 is better at many things the the deliver cropped images are sharper using the R7 than the R5 with good lenses and good daylight.  I have tested the R5 and R7 with the same lens at the same distance and the same camera settings and the R7 does generate sharper images when the cropping is large like you might use for small birds.
When cropping is not an requirement the R5 is better but heavier for an all day carry.  So is the RF 100-500.   The R7 pairs well with the RF-S 18-150 along with the RF 100-400.
I also have tested the RF800.  It is a sharp lens and works even better on the R7 than the R5.   However, it is not an action lens and requires more light.   It is also very long which makes it awkward to carry some times.  I like RF zooms more except in special situations like taking pictures of the moon.
I do not find the buttons and dial placement of the R7 limiting but it is different and need train of the muscle memories.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
EBCowboy Regular Member • Posts: 108
Haven't seen any conclusive tests yet, but R5 with 1.4x has approx the same number of pixels as bare R7 when R5 cropped to same FOV, so I'm expecting similar resolution in real world use.
If I add an R7 to my R5, it will probably be with an RF 100-400 for a smaller walkabout rig, but even then I'm hesitating because I think I'll always be wishing I'd brought the R5 with me instead.
 EBCowboy's gear list:EBCowboy's gear list
Canon EOS R5 Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 1.4x III +4 more
RDM5546
I have both R7 and R5. I will bring the R5 on an important shoot in an unknown environment. Maybe I bring both if it is import enough. However which tiny subjects do not have feasible shooting near full frame. The R7 is the king where tiny subjects that hard to get close to. Shooting bugs and much of macro photography can benefit from the R7. I have help from the EF 180f3.5 macro and a 2x TC at times. The R7 will be handy in some of these cases.
When walking around or hiking with a need for telescopic lenses the R7 will reduce the weight of both the camera and lenses vs the R5 in many cases. FF gear gets heavy when you carry it all day.
The R7 with the RF 100-400mm (640 FF equivalent) has more reach than the R5 with the RF 100-500 and it roughy weighs 1lb less.
I will decide case by case which camera and lenses to bring.
MannyV
MannyV Senior Member • Posts: 1,055
Add another dimension to the mix. Get R6 and R7. That way have reach, and backup.
Manny
Still draft and working towards it - https://www.digitalphoto.work
OP drsnoopy Senior Member • Posts: 1,216
This is pretty much what I’m thinking, but would like to see an actual comparison of IQ between the R5/1.4x/100-500 and R7/bare 100-500.  The R7 will also be useful as a nice travel/cycling/hiking camera with a smaller lens set (10-18/18-150/100-400).
Robbey TC
Robbey TC Forum Member • Posts: 82
The 1.4 TC reduces the amount of light hitting the sensor by half, or one full stop. (1.4^2 approximates 2)
The 1.4 TC on a 100-500  f4.5 to f7.1 means that you will be either shooting between f6.3 @ 100mm to f10 @ 500mm, or have to double the ISO or halve the shutter speed for each stop foregone  (or a combination to achieve correct exposure).
When the R7's FOV is at 700mm (actually between 580mm to 755mm), with the 100-500, the maximum f-stop is f6.3 . This is 1.3 stops better than the R5 with a 1.4 TC  will achieve for 700mm (f10). (The R7 moves to 7.1 above 755mm FOV and the R5 moves to f10 above 660mm FOV ...(1.6 vs 1.4 comes into play))
So in the end it's a choice between reducing the $5,000 lens's capabilities (IQ, fstop, speed and ISO) to gain 700mm reach. While 800mm  reach is achievable, with better IQ, ISO, fstop and shutter speed, on the R7 for an extra $1,200 above the TC's cost.
Choices... choices
Rob
 Robbey TC's gear list:Robbey TC's gear list
Canon EOS R7 Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 50mm F1.8 STM Canon RF-S 18-150mm F3.5-6.3 IS STM
RDM5546
I just completed my third my third comparison shot session for collecting images from the label on the power pole near my house. I have made several small refinements in technique for each of the three test shooting days.
There is was a great deal of forum interest/attention to the use of the R5/ RF 100-500 with the 1.4X TC vs the R7 using the same RF 100-500 lens. These pictures are of a label that is over 100 feet from the shooter and all pictures are made from same shooting location.
Using the R7 and the RF 100-500 with no TC resulted in 6000 pixels on the label
R7 with RF 100-500 @ 500mm (note that is a shadow from a nearby wire block left side of image)
Using the R5 and the RF 100-500 with no TC resulted in 3000 pixels on the label
Using the R5 and the RF 100-500 with 1.4X TC and 1.96 more pixels on the label resulted in
R5 using as 700mm/f10 equivalent lens with the RF-100-500 and 1.4X TC
Using the R5 and the RF 100-500 using 451mm FL with 2X resulted in 6000 pixels on the label
R5 using as 904mm/f16 lens with the RF 100-500 and 2X TC
Note: the 902mm was the FL because the zoom got bumped changing the 1.4X TC with the 2X TC. Also note the increased number of pixels on the label from using the 2X TC rather than the 1.4X TC.
To judge the images above for detail you should adjust them to be side by side and same physical size on your large computer screen. The R7/RF100-500 without TC and R5/RD100-500 1.4X TC are best compared side side and adjust to make both the same size.
Despite being a f2X TC resulting in the aperture to be f13 at the 904mm the image it generations is pretty competitive with R7 image using only the bare RF 100-500
Ok you lost me. You say all configurations have the same 6000 pixels on the label then show three completely different size and scale pictures so we don't have the same number of pixels to compare?
Your 1st and 2nd images are what interest me, though I think the 2nd (R5 + 1.4x) is unfortunately affected by image movement (looks like camera shake). As a result I don’t think it is a useful comparison.  The 1st image (R7, bare lens) is the best of the series, with numbers clearly legible.  Your test shows the difficulty of creating reproducible conditions, but is a good attempt nevertheless!
And-roid
And-roid Senior Member • Posts: 3,200
There's only 1 winner though and R7 for tele is simply annihilating the others, which is what we all knew already!
17mp might be competitive/enough but usability of the R5 in crop is not ideal, then you have the better af implementation on the R7 and fully optimized for aps-c eg 4:3 ratio on the R7 provides a further 1.125× crop, so ostensibly on the ef 100-400 you have 720mm in camera @400 5.6 and 32mp, its certainly going to take some beating! Sure, you have the 100-500 but personally I want 600+ @5.6 and the R7 and 100-400 seems a very logical choice, crikey it hangs onto f5 all the way to 500mm so essentially is on equivalent parity with 100-500 on FF @7.1 vs f8 equivalent aps-c, but the R5 is shooting 1 full stop slower.
Bridging the R7 resolution gap and to an extent its af is a difficult ask imo for R5. R7 issues are more ergo/no battery grip, evf, RS and the the likes!
Steve Balcombe Forum Pro • Posts: 15,571
You've omitted one mission-critical fact, which is that a 1.4x crop also reduces the amount of light collected, by exactly the same amount as a 1.4x TC. (Canon APS-C is a 1.6x crop of course, which is even worse.) This is why it is so important to use equivalent f-numbers as well as equivalent focal lengths.
If you do the comparison correctly, the R7 without a TC and the R5 with a TC are equivalent to within a third of a stop. Then, if you also trim the 700 mm (actual) R5 image to match the FoV of the R7's 800 mm (equivalent) image, they become exactly the same with regard to light collected.
Going on from that, the trimmed R5 image is now 7168 pixels wide, compared with the R7's 6960 - 3% difference, which is so close as to be negligible.
This is why the OP and I are so keen to see an actual comparison, without which it is too close to call.
Choices... choices
Rob
And-roid
Honestly, you are fighting a losing battle with tc's already, these high f stops on the 100-500 already playing against it! Its alright saying its f10 equivalent on the r7, which ir is for dof, but physics are physics and the R7 gets a better f stop and can even be used at 6.3 and still out reach the the 100-500 with 1.4* on R5, it works out that you are shooting 1.5 stops slower, 1.75* slower stops equivalent!
Honestly, R7 is the way to go for 600+ and ef100-400 even more so!
Choices... choices
Rob
Physics is physics but you can't cherry-pick the bits of physics to suit your argument while conveniently ignoring others. It would be worth doing some background reading on equivalence for a proper understanding of this.
Ah - for various reasons I also favour the R7, but as I've explained it's not because cropping has an inherent advantage over using a TC.
I look forward to being able to make the comparison for myself, when my R7 finally arrives!
And-roid
Sure things,
Look, here are the facts;
100-500 is 7.1 @ 500, on R3, 24mp, R5, 45mp, R6 20mp
100-500 is 6.3 upto 470mm, on R7 that's 750mm with 32mp
If you crop any of the above FF in-camera, the max you can get is 17mp on R5, and it will be the same as shooting the R7 but with far less resolution, reduced features in 1.6x crop etc.
However,
If you fit a tc to the 100-500, the max you can get is 660mm f9 or 1 full stop slower than the R7 @6.3 and 750mm equivalent (f10 dof), to crop that difference results in a total equivalence of F10 and 35mp on the R5 but you are shooting 1 full stop slower.
My argument would be, don't push the 100-500 past 6.3, either on R5 or R7 as the small amount of focal length doesn't really help, better to do the extra cropping in post imo. But having no tc in front of the 100-500, well, I don't believe that will not have a huge impact in itself on a 100-500 tele, no matter how good it is!
I find it hard to comprehend that a 100-500 with tc will ever out resolve the 32mp of the aps-c sensor without tc, even in the 6.3 scenario above where the R5 will have 35mp vs 32mp as the tc will soften most of that resolution further, imo. On a prime lens, tc's can provide great results but on zooms, it can't perform miracles.
Having said all of that, I am looking forward to your real world results
Sure things,
However,
Like I said, learn about equivalence then we'll talk again.
Me too.
John Sheehy Forum Pro • Posts: 26,688
From any given distance, you will put almost exactly the same pixels on the subject at any zoom position, because the difference in pixel spacing with the two sensors is about 1.36x, very close to the TC magnification.  Since this is true, it is fair to compare pixel-level noise, and the R5 has more pixel-level noise at 2x the ISO, plus, the extra aberration from the TC, even if small, makes the captured detail punch less through the noise at the pixel level.  However, the R5 will have a slightly wider angle of view to aid in visual tracking, and the e-shutter will roll through the subject about 2.3x as fast with the R5.  The R5's AA filter is less prone to color moiré at the pixel level.
You would likely only use both at the same physical zoom position when you are at the long end, because if you zoom out, the two different sensor sizes will give different angles of view when you aren't in "forced crop" mode at the long end.  If you chose to remove the TC in such a situation, you are better off with the R5 in almost every way, if you want to use the largest pupil possible.  If you leave the TC on and just back out as far as you can, most of that benefit would not exist, as zooming out with an unnecessary TC gives you a smaller pupil at any given angle of view.
I believe that I have already graphed what pupils you get over their ranges of angle of view for all three combos mentioned (APS-C, FF, FFx1.4), I have posted it in the past and it is on my other computer.  I'll look for it.
So, if you were hoping for a simple answer, you won't get one from me, but if one is speculating about such things, always think about the pupil; the pupil is the core of imaging with a lens.
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
In the future, we may be using super-high resolution sensors and shorter, faster lenses, and depend upon "digital zoom" for much of what we now use longer focal lengths for.  A 200/2 lens that is free of aberration on a 400MP FF sensor would also have crops "equivalent" to 400/4 with 100MP,  and still have 25MP at the equivalent of 800/8.  This would greatly reduce any compromises between pixels-on-subject and the ability to find and stay on the subject.  You wouldn't have to sacrifice pixel resolution of the subject to get a wider tracking view.  Of course, when you start out with only 32.5 or 45 MP, you can't crop as deeply in post, without pixelation.
John
