GX7 viewfinder query
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
I have recently started taking out my old GX7 again with a small lens for when I want to travel very light.
However I am REALLY struggling to see through the viewfinder!
I have to get my eye dead center and the. However I adjust the adjustment slider, the best I can get is an extremely small clear sharp bit in the middle. The whole periphery of the viewfinder looks like zoom burst blur. I can't actually use it at all.
My eyes: I have one normal focusing eye (cataract done) , and one that needs glasses. Neither eye, with or without glasses can use the viewfinder.
I just don't recall it being that bad. Is it possible I have knocked something out of line?
How is everyone else's GX7 viewfinder?
PS. The rear LCD screen is great. But not what I want to use.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
jalywol
jalywol Forum Pro • Posts: 12,301
Re: GX7 viewfinder query
It was bad, but not that bad.  It sounds like the lens in front of the EVF got displaced a bit.  Maybe get a hold of a service manual and see if you can take the viewfinder assembly apart to see if there's anything you can do?
(Or, if nothing else works, give it a smack and see if you can knock it back into place.....)
-J
barbara j Contributing Member • Posts: 781
-J
LOL my first car came with a rubber mallet, which got used, but never been able to make myself smack a camera :D)
@luredbylight
 barbara j's gear list:barbara j's gear list
Canon EOS M3 Panasonic Lumix DC-GX9 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Panasonic 12-60mm F3.5-5.6 OIS +4 more
Adrian Harris
OP Adrian Harris Veteran Member • Posts: 7,708
That's a great tip. I forgot to mention that the last time I used it was for pole photography where I was using my phone screen to see where it was pointing.
... And that was just after I tripped over bringing the camera crashing down from 20 feet up onto a nice hard granite rock (which broke the lens in half).
So that must have been when it dislodged. So that's what I need to do then. I'll get the pole out and drop it in the opposite direction
jeffharris
jeffharris Forum Pro • Posts: 11,409
If you don't already have one, look for the extended eyecup. It really makes a difference in terms of blocking out a lot of ambient light/glare and getting your eye in the correct position.
Sounds like the EVF isn't in good shape.
Did you clean it? My GX8's EVF was looking funky, so I cleaned it. What a difference!
What about adjusting the EVF focus (diopter)?
Finally sold mine a few months ago. It basically sat in a drawer for 5+ years and never used.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
jeffharris
The GX7 or his head? 😜
Adrian Harris
Yes I've tried the diopter adjustment.
Yes mine has sat in drawer for 5 or 6 years. But have just started using it again in non critical photographic situations where reduced weight takes priority.
Adrian Harris
That comment cracked me up. Nice one
brentbrent Veteran Member • Posts: 5,766
Adrian, should you wish to try a repair route more refined than a rubber mallet, here are dropbox links from which you can download:
GX7 service manual: https://www.dropbox.com/s/fsq0srs48815i84/Panasonic%20DMC%20GX7%20Service%20Manual.pdf?dl=0
GX7 parts list: https://www.dropbox.com/s/zy6sbhf5tn7uy17/Panasonic%20DMC%20GX7%20Parts%20List.pdf?dl=0
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
Adrian Harris
SOLVED - Re: GX7 viewfinder query
Whoopee, and thanks everyone for tips and ideas.
And in case anyone else has the same problem here is the solution...
In the end after googling for a while longer I found someone on Flickr who had the same problem nearly 5 years ago and they undid the screw under the rubber eyecup, removed the eyecup and noticed the diopter lens was loose, so clicked it back into position.
So I have just done the same and it was exactly that. Once the rubber eyecup was removed, I could see the diopter lens was floating about.
My fingers were far to large to use, but with a small screwdriver I could move the little plastic lens around until it clicked into place. Now it's perfect
I was very nervous unscrewing a piece of the camera and risk tugging the eyecup off, but thought well the GX7 is unusable as it is, and as it's very old not worth paying to repair. thus nothing to lose. But in the end it was safe and simple.
Best wishes everyone.
Isola Verde
Isola Verde Forum Pro • Posts: 10,640
Re: SOLVED - Re: GX7 viewfinder query
Nice one!
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
