Is “Live Preview” on an iPad possible?
Started 9 months ago | Questions
AscendPhotography New Member • Posts: 5
It’s been a few years since photography was more than a personal hobby, but I’m in the process of being pulled back in. The majority of my work in the past has been in the pageant industry - mostly headshots, some portfolios, and a smattering of on-stage and “crown” shots.
I’ll be working closely with my wife, and would like a way for her to view the images I’m capturing as I’m taking them. I’ve been using TikTok (of all things!) to catch up a bit with how the industry has progressed while I’ve been away, and I’ve seen a couple of photographers that have a tablet or laptop off to one side. Every time they take a photo, that photo is displayed full-screen on the tablet. Is this workflow possible for me?
My primary camera is a Fujifilm X-Pro3.  I would very much prefer to stick with it - I love my X-Pro3. I made the jump from Nikon to Fujifilm in 2016 - first with an X100s, then with an X-E2 when I decided I couldn’t live without interchangeable lenses. I got six years from my X-E2, and expect to get at least that from my X-Pro3. If I can’t make this workflow happen, I would consider getting a second Fujifilm body. I don’t think it would be worth it for me to jump ship to another brand at this point, though, and it certainly won’t be in a few months once I’ve indulged my desire to buy “all the glass.”
Does anyone here either have a setup similar to what I’ve described, or have ideas on how I can make it happen?
 AscendPhotography's gear list:AscendPhotography's gear list
Fujifilm X-E2 Fujifilm X-Pro3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R
Fujifilm X100S Fujifilm X-E2
Travelerdave Regular Member • Posts: 183
Re: Is “Live Preview” on an iPad possible?
It can be, but I have not found a good or easy solution.
The Fuji remote app can do it, but the preview is small, partly because it works in vertical mode only, although they say Fuji is re-making the remote app at present.
Next is the Cascable remote app, because the image is landscape and bigger.
The Fuji app will connect via Bluetooth easily, for remote release - both Apps need a Wifi connection to stream the image. Good luck getting it to work.
Most users hate the Fuji app, but lately I find it connects more reliably than the Cascable App. For me both are too painful to be useful.
I expect the easiest, and most reliable is an HDMI cable to a small monitor, so not the iPad in this case. A cable works well from Fuji cameras. Cleaner image with the info display turned off too. I expect your camera has a micro hdmi socket.
Next is the CamRanger 2 device, although fairly expensive, and it has reduced features on Fuji cameras. I think it uses a USB cable to connect to the camera.
https://camranger.com/camranger-2/
following this post I have a link to an HDMI transmitter for iPad, expensive, and it’s only a monitoring device, compared to the CamRanger.
Those are all I know of so far
 Travelerdave's gear list:Travelerdave's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H1 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +4 more
Ed Jeffersen Regular Member • Posts: 176
USB tether to a laptop.
bowportes Veteran Member • Posts: 4,337
The last time I checked, the X-Pro3 had no HDMI port (unlike its predecessor), so I'm not sure how you'd send an HDMI out signal from the camera.
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-Pro3 Fujifilm GFX 50S II +15 more
OP AscendPhotography New Member • Posts: 5
Yeah, this is the route I’m probably going to end up going.
