Weird glow in fujinon 23mm 1.4 at wide open
Started 9 months ago | Questions
Haritsya New Member • Posts: 5
100% zoomed image
I am noticing this weird glow / ghosting in my 23 at 1.4, is this common or am I doing something wrong? Please look at the image attached and help.
I notice this happening mostly in high contrast images. Once I stop down to f2 it almost vanishes. Sometimes I observe black borders appearing at the edge. bokeh near the focus point has some kind of ghosting effect. Please observe the teeth, it has a pronounced ghosting effect.
 Haritsya's gear list:Haritsya's gear list
Fujifilm XF 23mm F1.4 R
a_c_skinner Forum Pro • Posts: 13,047
Re: Weird glow in fujinon 23mm 1.4 at wide open
I'd offer that it is an out of focus effect.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
OP Haritsya New Member • Posts: 5
I specifically kept the teeth in focus to check for the same, I don't believe it's the case here.
Heinz Senior Member • Posts: 1,905
Try manual focus. At wide angle the Fuji focus can be erratic. Don't use any filters. In the end the lens can be the cause but this is rather unlikely imo.
 Heinz's gear list:Heinz's gear list
Fujifilm X-T3
Erik Baumgartner Senior Member • Posts: 6,894
That’s unfortunately all that uncommon with the 23 f/1.4 wide open. Not all are that bad, but many are. If you want top notch performance at f/1.4 in high contrast situations, you really want the new 23mm WR. I gave up on the old 23 after three tries and three lousy copies and bought an X100V instead. Yours actually looks significantly better than the ones I had.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
justinwonnacott Senior Member • Posts: 1,279
Looks like camera shake/image stabilization artifact or internal lens reflection. nt 60mm misbehaves a bit like this wide open and up close. a flaw......
 justinwonnacott's gear list:justinwonnacott's gear list
Canon EF 35mm F2 IS USM
John Gellings
John Gellings Veteran Member • Posts: 9,743
There certainly is slight camera shake here.
https://www.johngellings.com
Instagram = @johngellings0
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
Shutter 1/250, ISO 160 and IBIS was on
I will try it with IBIS off and update here shortly
Reading the other replies and looking again the whole image is soft and the halo effect on the teeth is obvious because of the very marked contrast white to pink gum.
Eric reports more than one copy which was soft and that may be your issue, but it will need more testing to know.
Andrew Skinner
RustyRus Senior Member • Posts: 1,696
That looks like a nice image to me 🤷‍♂️
 RustyRus's gear list:RustyRus's gear list
Ricoh GR III Leica Q2 Fujifilm X100V Fujifilm X-Pro3 Leica M11 +1 more
It is, but a bit soft.  Topaz Sharpen AI makes a lot of difference and leaves the teeth looking OK too.  It is a nice image.
Andrew Skinner
Tried everything, it looks like either I should compromise on print or shoot at f2 or higher.
Human Elements
Human Elements Senior Member • Posts: 1,051
That "glow" looks like the close focus issue that some of Fuji's f/2 lenses suffer from. I didn't think the 23mm f1.4 was prone to this - mine certainly was not. And you're not at minimum focus, so even more of a mystery.
https://www.human-element.me/
Please do not edit my images without permission.
 Human Elements's gear list:Human Elements's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Fujifilm X-T4 Fujifilm XF 35mm F1.4 R +2 more
OnCam Regular Member • Posts: 457
Are you using face or eye detect?
Almost looks like focus might be on the right eye putting the front part of the face slightly out of focus.
Try just using single point AF for your tests while using mechanical shutter for optimal bokeh and try a faster shutter speed like 1/500 just to eliminate any chance of subject movement or shutter shock.
I've had this lens and was always pretty impressive in terms of sharpness and bokeh even at 1.4.
I have the 23 F2 now and it certainly lacks some of the special rendering and pop of the 23 1.4.
 OnCam's gear list:OnCam's gear list
Fujifilm X-T2 Fujifilm XF 23mm F2 R WR
