EF-M or EF Wide Angle for M6 Mark II
Started 8 months ago | Discussions
hecthormurilo New Member • Posts: 4
So, I'm not from the US and lenses where I live are too expensive(I'm talking like one sigma lens costing 5 monthly wages) and I need a good, open wide angle lens for M6 Mark II, I was thinking on the Sigma 16mm 1.4 as everyone recomends it, but now knowing how the M system is basically dead and I already have a Speedbooster, should I consider getting a prime EF or EF-S lens? I know they're probably gonna be more expensive than the Sigma, but I could use them in the future since there are lots of EF adapters and not many EF-M adapters when I do get a new camera. Any recomendations? Are my points valid or am I just tripping? My biggest worry is not being able to sell a R$3000 lens because no one actually owns an EF-M camera.
Canon EOS M6 Canon EOS M6 II
nnowak Veteran Member • Posts: 9,075
Re: EF-M or EF Wide Angle for M6 Mark II
A couple of general comments on the speedbooster. In general, the wider and brighter a lens, the more likely it is to have optical problems on a speedbooster. Wide angle zooms tend to be especially bad on a speedbooster. The EF 24mm f/2.8 IS USM might be OK on the speedbooster.  Second, you can only use a speedbooster with full frame EF lenses. Crop sensor EF-S lenses will show very heavy vignetting, and the extended rear element may prevent the EF-S lens from even mounting on the speedbooster.
Basically, using a speedbooster for your wide angle needs will likely end in disappointment.
dan the man p Senior Member • Posts: 1,201
I think it's up for debate whether EF-M lenses will lose value faster than EF/EF-S. As for your question, I'm a little confused because you originally said Sigma lenses are too expensive, but then you said you were considering a Sigma lens. How wide and bright are you looking for? Zoom or prime? Manual or autofocus? The EF-M 11-22 is basically the same price as the Sigma 16mm F1.4, at least here in the US. There's also the Rokinon 12mm F2, which is significantly cheaper, if you don't mind a manual focus prime.
 dan the man p's gear list:dan the man p's gear list
Sony DSC-RX0 Nikon Z6 Nikon Z 24-70mm F4 Nikon Z 40mm F2
dwfrommonterey Regular Member • Posts: 388
Get the EF-M 11-22.
It's a real bargain.
Keep the M around even after you move on, just to use that lens.
 dwfrommonterey's gear list:dwfrommonterey's gear list
Nikon Coolpix P900 Sony RX10 IV Nikon D7200 Canon EOS M5 Canon EOS RP
OP hecthormurilo New Member • Posts: 4
I need a fast and autofocus lens, that's why I'm thinking about getting a non-EF-M lens, since all the fast and AF lens(EF-M or not) are really expensive, why would I get the EF-M? The 11-22mm seems great but it's not fast at all.
Sittatunga Veteran Member • Posts: 5,406
The Sigma 16mm f/1.4 is about the same price as the Canon 11-22mm and fast, but it's huge (the same size as the full-frame Sony 24-70mm f/4) and it doesn't zoom. It's said to be nearly as good as the reasonably sized Samyang 12mm f/2 at â…” the price. That Samyang doesn't zoom or AF, but it has a focussing scale and a huge depth of field.
The Canon 22mm f/2 is your cheapest AF option new, but 35mm FF equivalent isn't thought of as particularly wide these days. The Canon 11-22mm is slow, but it's just as good in low light as the 22mm f/2 if your subject isn't moving, because of its IS. What you lose in possibly stopping subject movement is more than made up for in having more of your subject in focus.
<i>The 11-22mm seems great but it's not fast at all.</i>
Can you explain a bit about how you intend to use your new lens such that the need for speed dominates all other factors?
Alan WF
Alan WF Veteran Member • Posts: 3,806
EF-S 24 mm f/2.8 STM?
You might consider the EF-S 24 mm f/2.8 STM on a plain adapter. I don’t know if that’s wide enough or fast enough for your needs.
New, the lens costs about R$1000, but you might be able to find one second-hand. The Canon EF-M to EF adapter is also about R$1000 new, but you can find the Viltrox plain adapter for about R$250 new.
One advantage of an EF or EF-S lens is that if you need or want to change to a new system, you can for the cost of an adapter (and possibly some AF performance). One disadvantage is that they tend to be larger. In this particular case, the EF-M 22 mm f/2 lens is also slightly wider and significantly faster.
Alan
 Alan WF's gear list:Alan WF's gear list
Canon EOS M50 II Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EF-S 24mm F2.8 STM +21 more
KevinRA Senior Member • Posts: 1,456
24mm f/2.8 IS USM is not that sharp in the corners wide open on full frame so likely the speedboosted APS-C edges also affected. Also strong vignetting. Does have IS though and nice stopped down.
Sigma 16mm is nice  and not bad at edges even wide open and less vignetting- suggest get a good 2nd hand copy from a dealer and that way still get a warranty and also avoid some of a potential future price drop if selling on.
 KevinRA's gear list:KevinRA's gear list
Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon EF-S 60mm f/2.8 Macro USM +14 more
Re: EF-S 24 mm f/2.8 STM?
Thanks everyone for the replies, I do own a gimbal and the 24mm 2.8, I just need a wide lens because I use it for music videos and a lot of night video too, I don't think I can run away from the the sigma 16mm
shuutrr Regular Member • Posts: 472
I use the sigma 16 all the time and like it very much, the M6 II and sig 16 is probably my favorite set up
shuutrr
 shuutrr's gear list:shuutrr's gear list
Canon EF-S 55-250mm f/4-5.6 IS STM Samsung NX20 Canon EOS 6D Canon EOS 70D Canon 6D Mark II +11 more
KEG
KEG Veteran Member • Posts: 4,909
The EF-M system is NOT dead, not by a long shot because nothing has replaced it.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
Nothing replaced Samsung NX and I think we can all safely call that system dead.
