Connect xh-2s to Mac OS (as card reader or use tethered with Captureone)
Chris Glaudel Paris New Member • Posts: 4
Hello to all. I tried (and always failed) to connect via usb-c on Mac book pro 16 on OS 12.4 my XH-2s trying to use all different USB settings
Shooting tether :
using capture one, you need to choose tether shooting fixed AND REMOVE all the cards from the slots of the camera.
I would like to get the camera as a card reader
But it does not mount as a card when there is 2 cards, I tried with one card at a time and get the message on capture one :
Description: The request did not complete within the specified timeout period.The Camera did not respond within 10 seconds.
This can happen for several reasons. E.g.:
- Capture One does not support tethering for this camera brand or model
- Camera is not setup up correctly for tethering
- Camera memory card contains too many images. Removing memory cards could alleviate this issue
Domaine: com.captureone.captureone
 when you quit capture and tried the reader in the finder, it does not mount as a card.
(automatic called universal, conn. shooting auto, USB card reader) but none works except universal and the system opens Photo.app from apple to download raw+jpeg in the app...
Any Idea? Yours
 Chris Glaudel Paris's gear list:Chris Glaudel Paris's gear list
Canon EOS 5D Mark III Fujifilm X-H2S Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon TS-E 45mm f/2.8 +11 more
21William Contributing Member • Posts: 866
Re: Connect xh-2s to Mac OS (as card reader or use tethered with Captureone)
Have you thought of transferring images over Bluetooth? Just a thought.
 21William's gear list:21William's gear list
Pentax K-5 Fujifilm X-H1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Shooting tether :
Any Idea? Yours
I don’t use Capture One but also haven’t been able to get MacOS to recognise the camera as a USB card
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
fujiframe
fujiframe Regular Member • Posts: 104
Shooting tether :
Any Idea? Yours
The only way I've achieved this with my X-T4 is to set the connection setting in the menu to USB card reader and use the native macOS 'Image Capture' application as mentioned here:
https://fujifilm-dsc.com/en/manual/x-t4/connections/computer/index.html#copying_pictures
 fujiframe's gear list:fujiframe's gear list
Fujifilm X-T4 Fujifilm 50mm F2 R WR Fujifilm XF 27mm F2.8 R WR Fujifilm XF 23mm F1.4 R LM WR +1 more
