Can the XH2S be a street photography camera
Sensibilist New Member • Posts: 5
I was told by camera enthusiasts that for street photography, we need to use street photography cameras such as GR3, XE series, X100V and other cameras often touted as “street photography cameras”.
Personally, I dont agree cos I hv seen many using Sony full frame cameras, and big cameras for street photography.
What do you guys think?
My thoughts are expressed in this video and I appreciate your viewpoints and constructive criticisms.
https://youtu.be/tkPQ2tx5V6s
Thank you.
Fujifilm FinePix X100 Fujifilm X10 Leica X1
NickDakota Regular Member • Posts: 152
Re: Can the XH2S be a street photography camera
I've been a street photographer for quite a while. I've been published and received paid assignments from my work. Also sold in galleries and private events. Not saying that in a show-off way, just stating my experience. Street photography is not camera specific. I've shot with Leica's, the GR, Sony gear and Fuji gear. I personally like to mix it up. I'm actually looking forward to using the XH2s for street photography. I love my Fuji's but the Sony tracking is incredible. The X2Hs has given me the confidence to sell my Sony gear off. I've really started to enjoy using my X-E4 more than GR and my XP3 with the Voigtlander 23mm more than my Leica lately. There's no true "street camera"
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 9,169
5
Hi,
I can't see your video but I agree. The camera has nothing to do with it. Depending on the location you will always stick out.
I find it funny that I should magically disappear just because I shoot with a small camera with a small lens. I'm still 188cm and white so I will always stick out in a temple in the South of India.
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Sony RX100 IV Fujifilm X-Pro2 Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R +7 more
a_c_skinner Forum Pro • Posts: 13,047
7
"I was told by camera enthusiasts"
Ask photographers not camera enthusiasts. These pages are full of people saying this is a lens/camera for street, portrait, landscape and so on when they are all disciplines that simply call for general purpose equipment. Yes, some stuff lends itself more or less to some subject matter but the dogamtic suggestions some people make are simply difficult to sustain.  So the H2 plus say 16-55 will be excellent.  I'd prefer something less conspicuous and lighter to carry but it is foolish to be more dogmatic.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
biza43 Forum Pro • Posts: 15,074
Of course it can.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
nurseMarty Regular Member • Posts: 326
The summary answer is YES.
A question you didn’t ask is should the XH2S be used for street photography? As mention by several responders, any camera can be used for street photography. Speaking for myself, when I’m doing street photography one of the primary factors in selecting which body to take with me is weight. I walk the street for hours. I don’t want my neck and shoulders to cry because I’m schlepping a heavy body. The same consideration is used when selecting a lens.
Traditionally a small body and lens is what many street shooters routinely use. A small body and lens, as also mentioned, will not make you invisible. Maybe only HCB was able to accomplish that trick. A small body and lens is less intrusive. It doesn’t scream professional photographer.
I’m not planning on purchasing an XH2S. I don’t need the feature set it provides. I also don’t want to spend what the body will cost. That is fine. No body is the answer for all photographers. I have several, maybe too many, bodies to choose from when I hit the street. The XPRO3. Of course. XT30. Sure. XT3/4. Not likely, but possible, if I want to do some short video clips. For me even these bodies are too bulky. It is all subjective. An X100S/T is perfect.
Not asked for but the lens. I have the 1.4 23&35 but I’m not playing with these lenses. For a long day out it is the crons. 23 and/or the 35. Maybe the 50 as a 2nd lens for contrast. Maybe on a 2nd body. I love the 18-55 kit lens. Especially for the multitude of focal lengths and OIS. That said, I prefer the discipline of zooming in and out with my feet.
So can you use the XH2S for street photography? Most certainly. Is it the ideal instrument for street photography? No. Ultimately, you carry your gear so you get to select what will accompany you on the street.
When you hit the street please show us some of your images and let us know what body you selected.
Mask On Nurse Marty
Craig268
Craig268 Senior Member • Posts: 2,005
And with regards to lenses, no rules there either.  Every venue is different.
This shot was taken with the very conspicuous 100-400 in an Italian neighborhood during a festival:
 Craig268's gear list:Craig268's gear list
Fujifilm X-T1 Fujifilm X-T10 Fujifilm X-T4 Samyang 85mm F1.4 Aspherical IF Fujifilm XC 16-50mm F3.5-5.6 OIS +11 more
j tokarz Senior Member • Posts: 1,387
Any camera will do street photography. I use anything from Olympus on 10 up to Fuji X-H1.  No problem.
EuropeanGhost New Member • Posts: 4
Nah its all rubbish, pretty much any camera can be good for SP.
ant
DirkPeh
DirkPeh Contributing Member • Posts: 520
Street cams don't have to be small to be inconspicuous.
Pentax with 90° mirror adapter installed. Pentax catalog 1976
 DirkPeh's gear list:DirkPeh's gear list
Panasonic LX10 Ricoh GR III Fujifilm X100V Sony a6400 Sony E 50mm F1.8 OSS +5 more
(unknown member) Regular Member • Posts: 442
ant
..this is a myth. Some. like names, don't even fit the owners that use them.
I can think of many cameras that are not suitable for Street Photography. Plenty of EVFs are 'tricky' in complex light. And some that have a shutter delay before they trigger. There is one, that if you leave it on ..the battery drains. I've had photographers stand next to me that were unable to take the same photograph simply because of the camera they used.
Some (like candid and travel photographers) have trouble defining what Street Photography is ..but somehow their camera is best for it.
Hey ..be sure to check out OP's other video.. Are You Imitating Someone?
ant
could you expand on this ..the theys must have said why. They must have said more than just defining a camera by its styling. Maybe they just meant access to controls, like ISo and +/- exp or split prism viewfinders. Some with fixed lenses are cheaper than some slr lenses too. A nimble street camera can be like carrying a 2nd lens except with a camera attached.
Thank you.
I like this other one too
ant
rla1022 Contributing Member • Posts: 762
This shot exemplifies what I detest about street photography. Sorry Craig , if this was my wife or daughter and I saw or knew you took this I’d have kindly asked you to delete. You’d probably have said no and spouted off about a bunch of well I’m in public bs. I personally see no artistic value in a shot of a random woman’s backside.
To quote Ian Malcom , you street photographers “ were so preoccupied with whether they could, they didn’t stop to think if they should.”
 rla1022's gear list:rla1022's gear list
Fujifilm X-E4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 16-80mm F4 Fujifilm XF 27mm F2.8 R WR +1 more
That Pentax appears to have a large male appendage. I would say that lens is not invisible much less subtle.
Mask On Nurse Marty
CasperMarly Regular Member • Posts: 181
Successful street photos can be had with most anything. Have seen good work from 4x5 speed graphic, 2 1/4 Rollei twin lens down to Kodak Instamatic cameras.
If you are comfortable with it - what does it matter?
Craig268
Your comment exemplifies what I detest about speed readers.  If I may suggest, please re-read my post (Italian festival) or read the young lady's t-shirt.  Presumably you're not Italian and/or don't understand the Godfather.
DirkPeh
Mask On Nurse Marty
It shoots around the corner 90°! Made for very creepy street fotographers.
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
And… both of these comments exemplify what I detest about making things personal in the forum. Please keep comments focused strictly on the issues that you perceive and keep it impersonal. Also recognize that “artistic value” is a very personal thing. If you don’t “get it” than consider the fact that your tastes and preferences are likely very different from someone else’s. Frankly, I find most street photography to be curiously uninteresting, but TBH, that’s simply my own perspective and of little value to most anyone else here. I’m sharing it not because it’s in any way relevant to the issue I’m raising here (or that anyone should give a rip about what I like or don’t like), but it’s more about respecting other people’s preferences, even if they might differ from your own.
Jumping off the Mod pulpit and ducking in preparation for incoming fire.
Jerry-Astro
Fuji Forum co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
Bill 10 Forum Member • Posts: 95
I prefer my Nikon FE2 + Nikkor 105mm f/2.5
 Bill 10's gear list:Bill 10's gear list
Canon EOS R6 Sigma 150mm F2.8 EX DG Macro HSM Canon RF 24-105mm F4L IS USM Canon RF 70-200 F4 L +5 more
Craig268
While a bit off topic (Fuji), I too still use my film gear and that particular lens is one of Nikon's best. Wonderful shot also.
