X-H2S subject tracking miss
Morris0
Morris0 Forum Pro • Posts: 32,175
Re: X-H2S subject tracking miss
RobertMachin wrote:
Morris0 wrote:
RobertMachin wrote:
Morris0 wrote:
RobertMachin wrote:
Morris0 wrote:
RobertMachin wrote:
Morris0 wrote:
RobertMachin wrote:
BernhardRos wrote:
Greybeard2017 wrote:
I'm not surprised to hear someone report having problems like this. I'm not saying the X-H2S has an issue. I'm not saying that this is user error.
What I am saying is that you have a relatively low detailed subject, a gray body and head at too long a distance, sitting in a sea of very detailed and high contrast grass.
I would expect an advanced camera like the X-H2S to be able to easily nail this shot. But I'm also not surprised in the least if someone reports that it's not working.
The Nikon Z9 also has many reports of scenes where the camera's AF system will fail to grab focus on what to the photographer looks like an obvious subject and instead locks onto the background.
Nikon has been making continual tweaks to the advanced AF system of the Z9. I'm sure we can expect to see many refinements to the X-H2S AF system.
I'm waiting for the OP to answer my questions to understand what happened with this relatively easy subject. Cameras require instructions to understand what the photographer wants to do. If this was wide tracking the camera would have to guess the subject and your are correct, contrast is going to play a part. Had the photographer used zone or single point and placed it on the subject I suspect we would be looking at sharp images.
Morris
You don't need to mess with zone or single point with the X-H2S - just wide/area tracking with the focus square over the subject you want it to identify.
You are right. That’s how it’s supposed to work.
However, what I’m saying is cameras like the Z9 and X-H2S have little flaws in their AF logic that sometimes miss in certain situations. Nikon is continuing to tweak the Z9 and I’m sure Fujifilm is tweaking the X-H2.
Until these tweaks are released the solution for the time being is to know your camera and AF system and intervene as needed.
Certainly a good idea to know your camera - but my perception is that you have to turn off subject detection in order to intervene with the X-H2S.
If you want to use subject tracking then zone and single point won't have much benefit over wide/area and using the focus square.
I made some trials with a decoy bird and compared Single Point Largest size, Zone 3x3 and Wide/Area. Every time with Bird recognition turned on. Bad lighting, just quick and dirty setup. Bird eye was detected, then with 40fps released.
Funny thing is, even there was no difference in the detection itself, you can clearly see during the shooting phase that the AF point jumps sometimes to the middle of the frame (and consequently away from the eye) with Single Point and Zone setting. With Wide/Area the focus never lost the eye.
As I mentioned, it was a quick and dirty test. I'll try the same soon on real birds outside. But it looks like, that the AF Mode setting has serious impact on the Subject detection.
Maybe someone else is also interested in testing and can confirm or deny my findings.
Want to chime in with my experience with shooting sports.
Subject detection was not reliable enough. As you observed, the camera would confidently follow the eye of the player, but end up focusing somewhere else, in the background most often (a net is a background for example, would trigger a sure miss).
Only AF-C with Wide Area/Tracking (detection turned off) is giving me reliable results.
Are some modes plagued with a contrast detection post processing step that produced the inconstancy we observed? Would be great if Fuji was more transparent with their technology choices so we don't have to fiddle around....
Even when there is someone closer than the player you wish to focus on?
Morris
I tend to place myself such as the tracking box unambiguously cover the player I want to shoot.
I can't see how you would do this for sports like basketball, football, volleyball and others.
Morris you wanted. In the second, to me #10 is in focus. What is controlling which player is chosen?
Morris
In both cases, 17 is in focus (17 is running in the first shot). I've put the tracking box on that player. It may be harder to see on this downscaled version, but it's very clear on the full res file.
That's also why I found the tracking mode to be more useful, in subject detection mode you cant choose which person is selected by the camera. And I faced many issues with the camera wanting to choose somebody else in the stands or something like that.
So you are using Wide Tracking in AF-C. To select the subject you are either leaving the selection at the center and pointing at the subject or using the joystick to select the subject. Once the camera focuses, it tracks the subject. This was totally useless on my X-T3. I have not tried it on the X-H2s.
Correct, I either place my box where I think the "face" should end for a pleasing picture and move my camera to match this composition, or quickly react with the joystick. This mode has improved from the X-T3.
Have you tried using the combination of Wide Tracking and Face/Eye detection? If working properly, I'd expect this to work great. It's the same concept as what I do using zone and subject detection.
Yes I have tried because I would much prefer for Face/Eye detection to work. But when activated, the frame rate suffers and focusing has then the inconsistency I mentioned earlier. It seems to be an entirely different that takes other when activated.
Morris
Do you have Release/Focus Priority set to Focus?  That would cause the frame rate to drop.  I have not experienced reduced frame rates when using Face/Eye detection with zone.  I used to use Focus priority with the X-T3.  It's not needed with the X-H2s, at least I don't need it.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
