Colorado Hiking with X-T3 & XF 16-55@2.8 & XF 50-140@2.8
Started 9 months ago | Photos
Collin T
Collin T Junior Member • Posts: 43
20
Great lens combo for hiking, I do wish that I had more reach but the 50-140mm will do the trick for now.
All jpeg straight out of camera, no post.
 Collin T's gear list:Collin T's gear list
Fujifilm X100V Fujifilm X-T3 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR
Comment & critique:
Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 50-140mm F2.8 Fujifilm X-T3
MrKazador31
MrKazador31 Regular Member • Posts: 174
Re: Colorado Hiking with X-T3 & XF 16-55@2.8 & XF 50-140@2.8
I didn't even know it was possible to get beautiful images like these straight out of camera. Very impressive!
 MrKazador31's gear list:MrKazador31's gear list
Fujifilm X-H2S Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR Fujifilm XF 80mm F2.8 Macro +3 more
Meeces
Meeces Contributing Member • Posts: 561
These came out great.  Really like the color and crispness.  Have you considered a 1.4 extender for more reach?
Matt
http://www.instagram.com/matticus390
http://www.flickr.com/photos/akita/
Fujifilm X-T2 and X-T4. 18mm f/1.4, 56mm, 16-55, 50-140 and 100-400mm, 1.4 ext. and MCEX-11.
 Meeces's gear list:Meeces's gear list
Fujifilm X-T2 Fujifilm X-T5 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR +4 more
Poefolk Regular Member • Posts: 202
#1 and #4 are superb.  Great images.
 Poefolk's gear list:Poefolk's gear list
Fujifilm XP90 Sony a1 Zeiss Batis 25mm F2 Sony FE 85mm F1.8 Sony FE 135mm F1.8 GM +3 more
Collin T
OP Collin T Junior Member • Posts: 43
I thought about it, but I feel the 1.4 extender wouldn't be enough to make a tangible difference, maybe I'm wrong.
I might be enticed to get the new 150-600 for when I know there will be wildlife. I already carry a tripod with me anyway.
Meeces
I can't claim to be an expert in hiking, but if the weight/size (or budget) aren't an issue, why not?  It looks like a great lens from all the initial reviews.
I'm actually looking to get the 70-300 to supplement my 100-400 and 50-140 for the shorter hiking I do. I use the 50-140 currently for shorter hikes, but also like the idea of a bit more reach while keeping reduced weight that the 70-300 would offer.  The 100-400 is usually a little too much weight/size wise.  The 70-300 feels like it would be the perfect  middle ground.  Reports/reviews seem to indicate that adding the 1.4 to the 70-300 helps with even more reach (minus any focus degradation) without too much of a quality hit.
It's nice to have options.
Matt
jhorse Veteran Member • Posts: 5,913
Excellent hiking images.
I too use the 16-55 for hiking (on a XT4). Great combo. For reach I use the newly acquired 70-300, which is proving to be an excellent lens. I also carry a 10-24 in a day sack.
Last year hiking in the English Lake District, I managed to set up the camera strap (a Peak Design Leash) by threading it through the loops on an Osprey day sack whereby the harness of the day sack took the weight. It was surprisingly comfortable and convenient.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
Collin T
I use the peak design clip on one of the shoulder strap. Here in Colorado I climb a few mountains and don't want any kind of weight shifting too much. It's been holding up so far and I have a very fast access to the camera (less interruptions while hiking).
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
Huh? Just wondering, what have you been doing with your gear? All post processing? Isn’t anything SOOC good enough at some point? I’m just wondering.
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
lewiedude2
Exactly. Best product PD makes. I use the capture clip v3 all the time. Best when immediate access is needed and it is stowed safely and securely.
Morris0
Morris0 Forum Pro • Posts: 32,181
The last two are lovely.  You might want to replace the 50-140 with 70-300 as it's light and provides much more reach.  Bring a 1.4x TC if you want even more reach at almost no additional weight.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
