Love the camera - hate the output Locked
This thread is locked.
BITPhotoSpace
BITPhotoSpace Regular Member • Posts: 276
The X100T is what put me off adopting Fujifilm as a system - I love the camera and still use it but just cant get the colours right - Capture One does a very good demosaicing  job to the point of almost no worms and colour artifacts are visible but sadly, the X100T became a forever B&W camera.
The true quality of a photograph can never be appreciated by gearheads..
 BITPhotoSpace's gear list:BITPhotoSpace's gear list
Fujifilm FinePix X100 Nikon D90 Nikon D200 Nikon D700 Nikon D3000 +16 more
Fujifilm X100T
drynn Senior Member • Posts: 1,134
Re: Love the camera - hate the output
I would like to have seen the colour versions because for most of these, I do not think B&W is doing them any favours.
BITPhotoSpace
OP BITPhotoSpace Regular Member • Posts: 276
Ehhh - alas....
GreatOceanSoftware
GreatOceanSoftware Senior Member • Posts: 1,222
I had the same reaction to the Canon M6II. Never could warm up to the color science, but it did some nice BW. I still wonder if I should have kept it for that reason.
#5 and 8 are my favorites.
Randy
 GreatOceanSoftware's gear list:GreatOceanSoftware's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +11 more
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
Examples... in color?
Well... maybe it's just me, but I find it rather odd that you would complain about problems with the color, yet only show B&W examples for folks here to look at. Maybe some SOOC color examples that illustrate the issues you're seeing might help you get a bit more guidance. Most of the comments I've seen here are pretty positive with respect to Fujifilm colors, so I'd be very interested in seeing some of your examples that illustrate the issue.
Jerry-Astro
Fuji Forum co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
BITPhotoSpace
Mainly because I like the form factor - the DR and high ISO are also very good and the res is far beyound my needs. I just "pretend" tis loaded with a B&W roll all the time
Mind, the pics posted were quick conversions using Capture One preset - you could generate richer B&W raf conversions were you to put thought/ time into it.
BITPhotoSpace
Re: Examples... in color?
Appreciate the offer -
I am sure lots of photographers appreciate the x trans output staright OOC and not having to fiddle about in post and/ or "pre"-capture wrt custom/ WB calibration etc. Both Capture One and Iridient now translate excellent output.
Love and hate are personal preferences - nothing to do with complaining -
Jerry-astro
Well, it’s your call, of course.  But if you have issues with the colors, then at least providing one or two examples might help others better understand your concerns.  You went to the trouble of calling out the issue, yet have provided absolutely nothing that illustrates it.  I think this is important because Fuji’s colors are actually one of the things that many people single out as a major advantage of the system.   Your own concerns with examples might at least generate some discussion that could prove to be useful.  Without examples, it’s just another opinion on the internet.
Jerry-Astro
Fuji Forum co-Mod
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
I second Jerry.
How would you like to get tips or other opinions without sharing examples.
It could be a matter of post processing for example.
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
sir_c Contributing Member • Posts: 740
If you shoot RAW and set C1 in linear mode, you can pretty much apply any color corrections you want and save those into presets. Also you can obtain many LUTs, some for free.
For SOOC images there are many recipes available to fine tune white balance and other settings.
With the scarce info you have us, that is about all the tips we can give you.
 sir_c's gear list:sir_c's gear list
Fujifilm X-T1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
Emile15 Senior Member • Posts: 1,769
I am not the OP want "help". He merely expressed an opinion and showed a few images of what he thinks the camera is good for. Surely that is valid?
 Emile15's gear list:Emile15's gear list
Fujifilm X100T Fujifilm X-T4 Canon EOS R5 Canon EOS R7 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +12 more
allineedislight Senior Member • Posts: 1,311
well, it really shouldn't. For many the X100 series is in fact the gateway drug
Regarding colours, the X100T has the Xtrans II sensor and more importantly the EXR Processor II. It's the same configuration as in the X70, X-E2, X-E2s, X-100S, X-T10 and X-T1, all of these will give you the some default colours and processing as your X-100T.
If you don't like it why not try a later generation camera for example:
X-trans III with X-Processor Pro: X-T2, X-100F, X-T20, X-E3 etc
X-trans IV with X processor IV: X-T3, X-100V, X-T30, X-E4 etc
the colour output from these will be different from the second generation cameras like your X-100T.
I've tried all four generations and I personally prefer the first generation and the fourth in terms of colours out of camera. The default second generation colours I don't like very much, they are too contrasty for me and also the auto white balance is too cool for my taste. Maybe that is your issue with the colours (e.g. if you are used to the warm Canon colours)?
and if you like black and white, starting with X-trans III all cameras have the ACROS film simulation which many highly regard as giving one of the best out of camera black and white pictures (so another reason to try a later generation camera!)
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
Jerry-astro
It would have been a lot more useful both for him and others in the forum if he were able to show examples of the issues he's raised. As I said, earlier, it's just another opinion on the internet. If one shares an opinion here, but is unwilling to back it with something that demonstrates the issue, then it stands to reason that some people might question whether the opinion is valid. I'm not questioning his right to post this... only whether it adds any value either to the forum or to resolving his issue. I can't speak for others, but from my standpoint, posts that highlight issues but offer no corroboration or examples are, IMHO, pretty well ignorable.
Jerry-Astro
Fuji Forum co-Mod
rla1022 Contributing Member • Posts: 762
NICE SHOTS…especially the 2 cemetery shots. Did you take comparable shots with the M,4/3 gear? How does the B/W render. I see posts like yours and others that use every software under the sun to try and do better but to me its is sometimes just the hassle. I love the in camera output of BW especially Acros on the new cameras. On the xpro It has in camera TIFF output with the editor and I have used that a few times as well.
 rla1022's gear list:rla1022's gear list
Fujifilm X-E4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 16-80mm F4 Fujifilm XF 27mm F2.8 R WR +1 more
BITPhotoSpace
Hey thanks didn't mean for this to be a fully blown out tec debate but appreciate the input nonetheless.
No a friend of mine actually lent me a X100IV for a test drive once - wonderful kit but same impression. Strangely, the older I get the more I'd rather let the machine do the work (Film?) rather than coping with the uncertainty of my decisions - I am relying on quality JPEGs more and more and that's why I choose another system as my main.
The X100T became a dedicated raf  > B&W kit. For the form factor and a colour output I "love"  I still keep 2 1st gen x100esses.
My very personal wishlist:
- Put a "normal" sensor inside please!
- Stop betting on the moire thing and faux film simulations - the build quality, ergonomics and lens lineup is good enough to persuade wannabe adopters.
BITPhotoSpace
Hey thanks - the X100T has somehow better tonality in B&W than MFT for straight forward processing - more subtle transients. I do not use fujifilm own profiles for this - I used to convert in iridient > ACR BW3. But nowadays I use Capture 1 express Fujifilm base B&W profile with minimum contrast and curve adjustments if needed.
Jerry-astro
Fair enough… but I wouldn’t hold my breath waiting for it.  Some of the areas you have issues with are actually seen as advantageous by others.  Different strokes……
Jerry-Astro
Fuji Forum co-Mod
Polybazze
Polybazze Contributing Member • Posts: 735
I use Capture One for the X100F.  When I had the X100T I used SilkyPix which I found rendered the images better. Give it a try.
I would like to know what he does not like. Is the white balance off, are the color profiles not to his liking, are the contrast levels the problem.
Why else make a forum post about this topic? If no advice is requested, then just better sell the camera and get something else.
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
Have you tried the white balance tweak adjustment in the camera?
You can also do white balance bracketing in-camera.  It might help, I don't know.
Tom Schum
"Beware of taking advice from anonymous wise men." Quote from Anon.
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
